Question about Nokia Cell Phones
C7 Display Is Not Working / It Is Showing Pop Up Clock
Samsung range with digital display not working properly. Clock shows half of the numbers.
Replace the display board. There will be a segment driver that has failed.
May 06, 2017 | Samsung Ovens
Stove clok is not showing time
try pressing the clock button after setting the clock .^-^
Mar 09, 2015 | Kenmore Kitchen Ranges
My alcatel pop c7 soft keys has a problem it keeps on responding eventhough im not pressing it keeps on showing the apps,wallpaper,manage applications settings.what can i do to fix this problem??
Hello, First remove the battery and let sit for 2 mins. Replace and powerup to see if fixed. If not then will have too be sent back for repair.
May 16, 2014 | Alcatel Cell Phones
My nokia c7 in not starting
Dear sir my nokia c7 installed antivirus then i will go to application and open gallery no chance then mobile off and again on again restart screen showing but no open all gallery
Feb 11, 2014 | Nokia C7 (8 GB) Smartphone
I need unlock code for nokia c7 movistar spain locked
u can get the unlock code for your nokia c7 model from by using this link http://www.theunlockarena.com/
following instructions makes u easy to unlock your mobile
1 - Switch on your Nokia C7 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C7.
3 - Compose #pw+CODE+1#.
4 - The Nokia C7 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C7 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia C7
Each Nokia C7 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia C7 mobile phone using the form above.
Feb 21, 2011 | Nokia C7 (8 GB) Smartphone
The screen is showing display for clock adjustment but none of the touch screen buttons working
this problem is due to loss of connection between main board and lcd unit replace FP-185 flex cable
May 20, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Feb 18, 2010 | Clarion Car Audio & Video
Baking oven
if you got no display form clock assy ck the power lines leading to that control, unplug and relpug unit might have just glitched out, no clock no bake on this model all oven function run throughthis clock/control
Feb 28, 2008 | Tappan TGF363 Gas Kitchen Range
Timex T116T operating instructions
try: http://www.jongsclub.com/tt/tag/%C1%A4%B1%D4%C7%A5%C7%F6%BD%C4 or: http://www.jongsclub.com/tt/tag/?₪±??¥??½? the second link my browser "cleaned" so best try that one first, however it may be a swell idea to translate the page first. good luck.
Sep 25, 2007 | Audio Players & Recorders
Alarm clock/radio
Cut the power / batteries off and back on again to see if it will work, if not, go to www.easylifestyle.us to get a new one you need.
Jul 21, 2007 | RCA RP-3765 Clock Radio
Cell Phones Logo
97 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
