Question about Campbell Hausfeld Garden
Power washer starts for a instant one time and thats it.
F21 code displayed> cleaned water trap next to water pump that had lots of stuff plugging the filter but now power cord GFCI plug shuts off when I try to Start washer...
Hi you could have a clogged drain pump or obstruction in it. Remove the lower bottom cover. Have a container or towels to catch water. Removed the drain cover by turning counter clock wise. Sometimes you have to remove the pump to fully and clean. You also need to plug the washer into another outlet. If possible use an extension cord use the extension for test only.
Apr 25, 2014 | Whirlpool Duet WFW9550 Front Load Washer...
Hotpoint tcl 770 aquarius tripping electrics
REMOVE TOP OF WASHER AND CHECK WIRING ON FRONT RIGHT SIDE AS IT IS PRONE TO CHAFFING CAUSING AN INSTANT TRIP.
Jul 27, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Kenmore serie 80.does not stop filling water in and does not star
Yeah I've seen that happen a many of times. Take the back of the control panel off and where your load size selector is you'll find a little hose that's suppoed to be attached to the side of it. just reattach it and you'll be back up and running.
Almost all washing machines use a pressure tube that tells the washer when to stop filling with water. If the tube comes off for some reason the washer will never stop filling and that's an instant flood if you don't notice it quick enough. Also a hole or puncture of any kind can be causing ti to never stop filling as well.
Hope this helps
Jason
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
My frigidaire will not go through any cycles>
It may have defaulted to 8 hour delay, ours did after a storm and the power went off, see if the 8 hour delay button is lit, if so press to return to instant wash.... hope this helps
Dec 18, 2008 | Frigidaire GLTF2940ES Front Load Washer
Creda W120VW Intermittently not starting when door is closed.
I don't know if you are still having a problem with your washer, but a new door lock is needed to put it right.
Sep 09, 2008 | Creda W120VW Front Load Washer
Power loss - 95 honda accord
Fuel pump might be the problem. But it also might be a weak battery.
Sep 03, 2008 | 1995 Honda Accord
Maytag Performa Washer spins fine but stops instantly
Check the unit next time it is in the spin open the lid up does it do the same thing?? if so it is working ok that is the Brake in the unit doing it Job but if it is really loud it maybe going out??
Jan 26, 2008 | Kenmore 22422 Top Load Washer
F11 code washer locks up
We've had this problem for about a yr when i finally firgured out how to correct it. the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get. How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Garden Logo
21 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
