Question about Asko D1716 Built-in Dishwasher
D 1716 not working
Well I finally figured out how to get the bottom panel off of course the guy
who installed stripped all of the screws
and I had to cut them off. Finally got the machine out got all of the water out, and there was not a plate except
the one that actually held all of the pumps and switches.I did pull out a huge mouse nest, and a ton of droppings. So if anybody has the D1716 and they have a problem like
not running clean out the bottom of
the machine completly and shake the
machine sometimes the water valve sticks ( we have well water and its hard
and it might just help. Also we are getting a new stainless steel water hose, and getting rid of the copper one. The D1716 now works and thanks for everyones help Ron
3 Suggested Answers
  • 14 Answers
SOURCE: Our Asko D3112 was not draining, so we had
Check your manual to see if you have a drain pan at the bottom of the unit, and a 'float' that checks for water collecting there. On at least some Asko models, water collecting in the pan causes the float to rise, which then changes the operation of the dishwasher. Once that float switch turns on, the diskwasher will always run the drain pump whenever power is applied.
If this is the case for your machine, remove the kick panel. There likely is another panel behind that which covers the 'internals', including the drain pan area. You'll have to remove all of the water in the pan, and that will lower the float and return the controller to normal operation. THen you will have to diagnose the cause of the water collecting in the pan.
Another possibility is damage to the float such that it has turned on it's switch despite no water collecting in the drain pan. I've heard that in some cases a mouse will chew on the float and damage it, causing such machine operation.
In another thread, I posted my solutions to one cause of water collecting in the drain pan. In that case the drain pump was no longer reliably moving water out of the sump area inside the dishwasher. I had thought it was the manual dial control on my d1706 unit, until I learned that the dishwasher has this 'special' drain pan mode.
Posted on Jul 08, 2009
  • 10865 Answers
SOURCE: The pump on my ASKO 1716 dishwasher will not stop
Simple fix. It appears that your anti-flood feature has activated due to water pooling under the tub of the machine. You may be able to remove the water yourself or you may need help. If you want to try to remove it yourself you will need a syringe with a tube attached and you will have to get under the drum. Joe
Posted on Mar 25, 2010
How to change the freezer gasket on a Sub-Zero 650?
In my opinion this the easiest sub zero door gasket to install.The main reason for this is because of the way its packaged in the box from the factory.Not being twisted up makes it way easier then any of the others. And yes the first thing to do is remove the food and then pull the drawer out. Then loosen all the the quarter inch screws holding the metal strip that keeps the gasket in place but don't remove them just loosen. Once those are lose remove the old gasket. You should also remove the screws on the end of each metal strip. This helps when re-installing the new gasket. Now put freezer door face down with both rails sticking straight in the air and you can drop the gasket over the rails. The gasket has a small round bead that tucks in behind the metal strip. As you tuck this behind the strip work your way around the door snug in the screws be sure not to tighten them to much.Once in place take a hair dryer and warm any places that look wrinkled or need straightening. Finally tighten all screws including the eight corner screws now re-install freezer door and your finish.
Mar 25, 2014 | Sub-Zero 650 / O Bottom Freezer...
How to quick fix Stripped Sheet Metal Holes Without a Sweat!!!
Have you ever been there??? Been where you ask??? Well been at the end of a job with just one screw left to be installed as a last and final touch to a door skin or some other type of trim molding and found the hole was stripped out and the screw you have to put into the hole is "swimming" in the hole due to it being oversized? you try using a self tapper screw and same results too loose not dependable to secure anything appreciable.
Ok I have a quick and easy savior for all you guys out there in
Go into your tool box or small parts/screw cabinet and pull out a cotter pin and that same self tapping screw that is a bit smaller then the stripped out hole, bend the cotter pin out straight and form an "L" shape with it...insert the small L angle shape into the hole... then with a little finess work the self tapping screw into the hole at the same time allowing the screw to be buffered off the cotter pin on the side of the hole, thread the screw into the hole holding the cotter pin steady and "Walla" screw goes down tighter then it ever fit before, if need be get your dykes and clip off the excess cotter pin material left outside the hole.
Hope this works for you.
Happy Motoring!!
on Jul 17, 2010 | Chevrolet El Camino Cars & Trucks
How to take door panel to fix The Windows
Look for several hidden screws on panel. Take those screws out. There are a couple of push caps mounted to the panel along the edge. Ur going to have to pry straight out on those till they release. ( Make sure u have all hidden and visable screws out) There is a weather strip that is outside of window that lines bottom of window that comes off. Lift straight up on molding. This gives window a little room to move for panel to lift. Ok now that u got all screws out and those push pins released grab bottom of panel and lift straight up! After that u can figure out rest! It will still be connected to the electric window and lock mechanisms! Good luck
Nov 01, 2012 | Cars & Trucks
I no longer have a manual and need a fuse box layout to disable the automatic door locks
go to ebay motors and search your year make model then service repair manual obtain a cd repair manual it has extensive wiring schematics and electrical component locator in it along with repair procedures and illustrations for about $20.00
Dec 29, 2009 | 1992 Saturn SL
1) Remove the AC adapter, (Charger), if plugged in. Remove the Battery. There must be No electrical sources to the Notebook PC.
2) Turn the laptop over, going from Right to Left. Bottom of laptop is now facing you.
3) On the left side there is a rectangular panel. The rectangle faces up, and down in length.
4) In the Middle, to the right of this panel is another rectangular panel. This panel faces horizontally in length.
This is the Harddrive Compartment Panel.
There are two Philips head screws on the right side of the panel. One on top, one on bottom. Loosen these screws to remove the panel.
(You will see a finger tab on the right of the panel, used for lifting the panel up, and out)
5) You will see a cloth strip attached to the back end of the harddrive.
Slip the cloth strip out. Grab the cloth strip with your fingers, pull back.
6) When the harddrive has cleared it's pins of the interface connector, lift the back end of the harddrive up, and slide the harddrive out.
Use care as you do not want to bend those tiny pins.
Refrain from touching the pins. If the harddrive is determined to be bad, it's okay.
When installing the new one though, refrain from touching it's pins.
Dec 29, 2009 | Acer Aspire 9500 Notebook
One of the baffles broke off the tumbler and need to replace it
correct no repair guy neede unplug the unit so you dont get electrocuted happen to me once dont let it happen to you. remove the front panel than undo two screws at top of cabinet to release the top rotate the drum so the baffel you are replacing is at the 12 oclock position insert the baffel rub the screws thru the factory holes at top of unit if the holes are stripped dont be afraid to throw a washer in with the screw and dont over tighten because they will stripp out the plastic baffel . reasemble and your done takes about ten minutes
Aug 13, 2009 | Maytag HYE3658AY Electric Dryer
Can't get base off 26" Insinia 720p
On the back of the set you will see 8 screws just above the stand; remove the screws
and gently slide the stand out. Wiggle it alittle and the stand will come out.
Remove the metal tab you just pulled out by removing the screws at the bottom of the tab (attached to the pivit joint) place the tab back in the bottom of the set( same place you removed it from) and re-install the screws ( don't over tighten them). You are done.
I had the same trouble with this set and the tech support was of no help. Good Luck.
Jul 17, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Lamp replacement
You defiantly need to get the stripped screw out. When I encounter a stripped screw, I use my dremil tool with a cutting wheel on it to cut the screw off. After you do finally get the screw cut off ( and this can defiantly be a pain straken ordeal ) you should be able remove the remaining screw bottom with a pair of needle nose pliers. Replace the lamp at that point and find a screw with a bigger diameter ( a serf tapping would work well ) and tread it back. Good Luck. I do know you are in for a frustrating time, but with a lot of Patience, you'le do well.
NC Electronic
Mills, Wyoming
Jan 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Asko D1716 Built-in Dishwasher Logo
70 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
