Question about Logitech Cordless Mouse
CLEANING 848MN MOUSE
CLENING WHEEL
How to set the self clening feature on a very dirty oven
If you have a manual locking mechanism right above the oven door, make sure it is fully engaged or it will not go into cleaning cycle. Most of the time, as long as you pull out the oven racks, you should be able to select the cleaning cycle and hit start. some models might even ask how long of a cleaning cycle. most of them are automatically set for 3 hours of clean time. Unit will get very hot during cleaning cycle.
Nov 22, 2015 | Kitchen Ranges
Double dishdraw ss has ongoing bad residual odour problem on contents despite full and regular clening any suggestions
Buy Finish dishwasher cleaning kits from super market and clean each drawer according to the instructions on the kit.
Jan 07, 2013 | Fisher and Paykel DD605FD Stainless Steel...
I have an HP N3 optical mouse that was doing well until the other day when the middle little scrolling wheel stopped working. Can I fix it or do I have to buy something else? Thank you.
If the entire mouse stopped it probably time for new batteries. If it is just the wheel then it could be a driver issue or setting. If those are ok ie the middle button wasn't disabled somehow or your computer figured it only has a 2 button mouse then its hardware. That means its replacement time. It's possible the switch or the sensor for the wheel are dirty so if you want to you can take it apart and try cleaning.
Aug 11, 2010 | HP Wireless Optical Mouse Sl/Blk With...
Scroll wheel not functioning at all
Initially, go and buy some elctronic switch cleaning spray and spray all around the mouse especially the wheel and this may clear all the dust and skin particles that block mouse and leyboards during PC usage. If this does not work, re install it and see if that is any better.
Feb 17, 2010 | Manhattan Mouse
Have new logitech wireless mouse i can not scroll down whit wheel
Hello there:
If you remove the battery cover you will see 2 small phillips head screws remove them and this will allow the part that goes around the wheel to be removed now make sure that there is no lint or dust build up around the wheel assembly canned air works great for cleaning these out then reassemble the cover and test
Now if it still doesent work than you can assume that the controle sensor for the wheel is bad in this case if you still have the warranty i would take the mouse back and exchange it for a new one
To have this repaired would cost more than what the mouse is worth ok
I hope this is very helpful for you
Best regards Michael
Dec 11, 2009 | Logitech Cordless Mouse
It has become extremely hard to click with the left-mouse button
if your mouse is new then you can ask for a replacement but if its not its sometimes just need cleaning. open the lid of the scroll wheel then take the ball you can see inside if all the wheels inside are clean...if its not just use cotton buds then remove the dirt. hope itll help
Oct 02, 2009 | Saitek GM3200 Mouse
Mouse Wheel not working
with mouse controls so cheap and so readily available , why would you bother with cleaning/ pulling it apart
is it wireless mouse ( battery flat) usb mouse ( cable problem) or mouse driver ( stopped working)
Apr 12, 2017 | Razer Computers & Internet
Take apart a mouseman
is it a wheel mouse or a lazer mouse if it is a lazer mouse all you have to do is unscrew it all the way and it should come off easly
Apr 19, 2007 | Logitech MouseMan Wheel
Logitech Cordless Mouse Logo
19 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
