Question about Health & Beauty
Locating battery sunbeam sdl900 scale - Health & Beauty
Where is the battery in the sunbeam model 613 scale
Underneath. The compartment may not be marked or may have an arrow indicating direction of removal.
Jan 20, 2018 | Sunbeam Health & Beauty
Healthometer change kg to lbs
With scales off. Hold select button for approximately 5 seconds, lbs flashes hit select to confirm
Apr 28, 2012 | Sunbeam Healthometer Body Fat and Weight...
I am trying to locate an Owners Manual for my Sunbeam Controled Heat Sauce Pan model SP 5. Works fine as deep fryer but would like to know what else it can do.
I tried looking for the Sunbeam "SP 5" and came up with a digital scale. A web search for "Controlled Heat Sauce Pan" turned up a paper cookbook How to Get the Most out of your Sunbeam Controlled Heat Sauce Pan for sale for $9.95 (go to item 15 on the page).
Jan 05, 2011 | Sunbeam Crock Pots & Slow Cookers
Recently when I step on the scale I get and E
Try stepping off when you get the E and step back on after 5-10 seconds and see if it works.
Aug 12, 2010 | Sunbeam Healthometer Body Fat and Weight...
I have a Sunbeam digital scale and Model SDR520CO-01 We just recently moved. But somehow it doesn't work any more. Rarely we can get it work but very very slow and show strange pattern of showing letter E...
Incase anyone has this issue this is simply a case of not using the scale correctly.
You must first tap the bottom right corner of the scale for around half a second with pressure with your foot and then remove your foot. When the blinking has gone to 0.0 you may then step on the scale.
If you do not tap the scale and then wait for the 0.0 reading you will get an error reading. This was actually on a sticker on the product but I imagine some people remove it after purchase etc etc.
Jul 03, 2010 | Sunbeam Digital Scale HDL205KD01 ()
How do i reset each individual person
mcdevito75 here, There should be a button or knob close to the indicator you can press, turn, to return scale to zero for each person.
Jun 26, 2010 | Sunbeam Healthometer Body Fat and Weight...
Unable to pop battery compartnent in Health o meter EVERweigh
The whole top cover which is the part that you stand on (loading platform) comes off. Turn the scales upside down, pull the sides of the plastic cover to unclip the catches and the body can be removed from the cover. Remove the screws to the displlay and there will be a battery compartment underneath the display. Remove the cover to the battery compartment and make note of the battery orientation. Replace the battery in the correct orientation or you will destroy the scales. Repace the battery cover. Scew the display to the body. Press the cover on the body with the display showing through the window.
Jun 05, 2009 | Sunbeam Health O Meter Body Monitoring...
Scale build up problem in iron
White vinegar and a toothbrush. You can clean the whole steam path with 25% vinegar to 75% water. Steam it through. Run plain water afterwards to rinse it out.
Feb 06, 2009 | Sunbeam Irons
Health & Beauty Logo
115 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
