Question about Water Heaters
Gas furnance 80PJJ07EAR01 comes on but burners will not light up
  • 148 Answers
Is your ignitor lit ?
Posted on Nov 20, 2013
Ao smith GPVH 50 100 BURNER WILL NOT STAY . EXHAUST FAN COMES ON IGNITER COME ON , BURNER LIGHTS FOR ABOUT 4 SEC. BURNER GOES OOUT
Low gas pressure, dirty combustion parts, bad gas control valve.
Following link has power vent troubleshoot:
http://waterheatertimer.org/power-vent-water-heater-troubleshoot.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 09, 2017 | Water Heaters
The water heating burner does not go out there is a small like pilot light burning after the temp shuts off on the main burner.
Bad gas control valve? Wrong gas control valve for water heater?
This is a dangerous condition... immediate repair needed ... fire and explosion hazard.
Call plumber... or replace heater
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
Oct 07, 2014 | Reliance 6 30 DORS 606 Series 30 Gallon...
Richmond direct vent water heater
The pilot lights then heats/sends a signal to open gas for burner then(burner)should stay on but if valve shuts the gas off,then have your unit checked. What ever you do,DON'T MESS WITH IT IF GAS/FLAME ON!!!!!. These systems come with a safety feature that allows gas to go on only when safe!!!!
Mar 30, 2014 | Water Heaters
Junkers manual gas hot water
What are you expecting to happen?
I assume the water heater and water inside it is cold (otherwise you would not be lighting it). You light the pilot. The main burner comes on and the pilot lights it. The main burner should stay on until the tank is hot, When the tank gets hot the main burner should shut off but the pilot stay on. If you draw hot water, cold water will run in and cool the tank. If yu do nothing the tank will eventually just cools off. then the main burner should come back on to reheat the tank.
Nov 05, 2013 | Water Heaters
Pilot light will not light
If your pilot on your gas water heater will not stay lit you need to take one step at a time.
Let's look at how you tried top light it. Turn the gas valve to the off position and then move it to the pilot position. If you can see inside under the heater and there is no glass view window you need to take a lighter or a match on an extended stick so the flame can sit right under the pilot tube. Push down on the red button and then the gas should light on the pilot burner. Hold the button down for a FULL 60 seconds.
Then slowly release the red button the main burner should then come on. Now if the pilot flame goes out right away as you're releasing the red button you have one or two more things you need to look at.
1st would be to replace the thermo coupling. You have to remove the whole burner tray to do that. If that does not work then the gas valve is bad and you need to replace it also. Make sure that when you buy a new gas valve you match up the gas type Natural gas to L P gas. They must match with the gas feeding your house or it will never work,
Thanks and best of luck
R J
Sep 08, 2011 | Rheem Water Heaters
I can light the pilot and the burner will come on, but it won't stay lit. I bought a new pilot assembly and installed it. the burner and the pilot light still won't stay lit. This is the unit that...
Most gas water heater problems can be solved by having service technician perform yearly maintenance. Or by doing maintenance yourself.
This maintenance includes cleaning burner parts and combustion chamber, checking gas pressure and supply, bleeding air out of gas line, checking vent draft, making sure air supply is adequate and not exposed to chemicals, cleaning air intake. Also adjusting flame sensor so it is positioned correctly. If water heater is connected to electric circuit, the outlet must have correct polarity.
You can get gas to appliance indicates the gas control valve and water heater are not locked out. But the gas control valve thermostat can still be bad.
Open following link for illustrations, typical service manuals, and maintenance information, and images of gas control valve thermostats.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 20, 2011 | Reliance & Pilot Assembly for Natural Gas...
The flame switch is making a clicking noise and is not igniting the burner on my rheem power vent. the glow light comes on but does not ignite the burner. how can I fix this problem
It sounds like you either have the gas shut off, or you have a bad regulator. Make sure the gas is unrestricted.
Hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 10, 2010 | Water Heaters
No hot water. Cold water coming out of the all the fixtures in the bathroom. The gas supply is ok.
Check the thermocouple. The pilot went out and so the burner will not light. Replace the thermocouple, then light the pilot light and the burner will come on and make you hot water.
Heatman101
Mar 15, 2010 | Rinnai Water Heaters
I had a water heater blanket installed on my gas water heater. The installers made a mistake and covered the air intake vents. Now I have removed the blanket but cannot get the water heater to light...
Since the pilot light stays on, and the main burner comes on momentarily, then goes out. This mean to
say that the gas supply is not steady, it also goes off.
You got to get your gas valve repaired or replaced to get
it working.
Nov 26, 2009 | Water Heaters
The pilot light blows out every time the main burner shuts off. It will light, the main burner comes on, everything seems ok until the main burner shuts off, then the pilot light goes off also as if the...
it's the thermocoupler ( about $20 ) that is bad replace it. if that doesnt do it it is the box with the on/off/ pilot button ( about $175 ) I found a complete unit at www.americanrvcompany.com for $275 plus shipping ($300 total) and that is how i fixed the exact problem with mine.
Oct 07, 2009 | RTO Atwood Water Heater - 6 Gal LP
Water Heaters Logo
18 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
