Question about UST GG2300 Portable Gas Powered Generator
Cant start my ust 2300w generator
I checked the spark plug ,sprayed engine starter and it still wont start.
    Prodigy:
    An expert who has answered 500 questions.
  • 573 Answers
If there is a spark at the plugs ignition is fine, spraying starter in the intake should allow it to at least fire?? even if you had a carb / fuel issue. I would recommend a compression test and better still a leakdown test to determine if you have weak compression
Posted on Nov 20, 2013
2 Suggested Answers
ozark333
  • 396 Answers
SOURCE: when I start my generator
OK, you have a hard to find info on model. My first thought is that your choke is still on.
Does it have a manually activated choke? If so you know what to do, after she kicks, turn it off.
If it is one of the new Auto-choke units you may need to find the choke linkage and disengage
it that way. I have asked for a manual for your from UTS. We will see what they send, or dont!
As with all engines, if left in storage for long periods of time, use fuel stabilizer and try and start
the engine every 30 days and let it run for 10-15 minutes just to warm up and keep everything moving.
Posted on Mar 29, 2011
What spark plug is supposed to be in the UST 1200 1200 watt 79.5 CC generator
Pssst! We sell all the parts and spares for UST Generators on our website.
http://www.generatorguru.com/ust/
Need more advice? We have Generator Engineers happy to assist. Contact us, we are always happy to help!
http://www.generatorguru.com/ask-the-guru/
Regards
The Generator Guru Team
May 02, 2016 | Electrical Supplies
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
My ust gg2300 gas generator installed new carb runs 3to 4 minutes then dies
Maybe when the ignition coil heats up it will not produce any spark to the spark plug. Run the engine until it stalls and remove the spark plug and put the plug wire back on and ground the plug to the engine. See if you get spark at the electrode of the spark plug when you have some one pull the starter rope with the switch on the run position.
Jun 30, 2014 | UST GG2300 Portable Gas Powered Generator
Mower wont start
you will have to check a few things to diagnose it:
1) check the spark plug. check it for spark with a spark tester (best way) or by holding it against the engine metal somewhere and give a pull to see if you see a spark. If no spark go to #3 else go to #2.
2) if you have spark, you need to see if it turns over. get some starting fluid and just give it a quick spray in the intake (air filter usually) to the carburator. try starting it fairly quickly before the spray evaporates. If the engine turns over, then you have a carburator, fuel or fuel tank problem.
3) if you have no spark, replace the spark plug. if you still have no spark likely you need a new starter coil.
Remember you could have a combination of both of these types of problems.
RayRay
Jan 21, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Wont start
its either the fuel, spark plugs, or not enough air to complete the combustion cycle. Check the air filter to ascertain its not dirty. Check spark plug connections to ascertain there's a current from distributor cap to spark plugs when the starter motor turns. Spray starting fluid for half second before turning engine, and don't give throttle until engine starts, then increase throttle to 2,000 RPM. Once a month, pour a bottle of fuel injector cleaner to keep the injectors clear of debris buildup on the injectors' tips.
Nov 29, 2013 | 1997 Plymouth Voyager
My 1993 oldsmobile bravada engine will turn over but wont start
you need fuel, compressen, and electrical , make sure you all of the above dose it make any noise like it is trying to start ?
Dec 06, 2011 | 1993 Oldsmobile Bravada
I have a new batiere in my 1991 vino 50cc tow stroke, And the starter wont work and it wont kick start even with starter fliod. Anything that I can check or replace?
Check fuses. Get a new spark plug then check for spark by hooking up the plug wire then hold the metal side of the plug against the cylinder. Have a friend kick the engine over while you look for spark. Remove the carb, then remove the float bowl from the bottom of the carb. Use spray carb cleaner to clean the carb. How old is the gas? Flush the tank and fill with fresh fuel if old gas is present. Please rate my answer. Thanks.
Apr 06, 2011 | Yamaha G5 Motorcycles
When I start my generator it just lugs and shakes and will not get going. I have a UST 2300w generator modle GG2300. thanks jeffery
Mar 29, 2011 | UST GG2300 Portable Gas Powered Generator
We have a Honda GX160 powered generator. It just won't start. We have changed the spark plug, air filter, checked the fuel lines and all look ok. We have checked the on/off switch and that is ok too. The...
Sounds like the carburetor is plugged up on this generator since starting fluid starts the engine.
Rebuild the carburetor to get it to start.
Jan 19, 2011 | Garden
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
UST GG2300 Portable Gas Powered Generator Logo
246 people viewed this question
Top UST Electrical Supplies Experts
Steve
Gene Haynes
Are you an UST Electrical Supply Expert? Answer questions, earn points and help others
