Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Replacing rubber gasket - Admiral 26 cu. ft. Side-By-Side Refrigerator
    New Friend:
  • 31 Answers
The issues is easy to solve, all you need to do is look at the model and serial of the refrigeration unit and we can match up a gasket for you at www.coolergaskets.com. Once you get it they either push in or screw in, typically screw in. So you would unscrew the old gasket and install the new one. Probably looking at about 1 hour to fix it. We have tech support available that can assist also
Posted on Dec 03, 2013
Rubber gaskets for timex watches
The rubber gasket is the waterproof seal, to get the proper one you need to go to Timex or an approved repairer!
Nov 02, 2014 | Watches
2004 chevy impala overheating, loosing coolant, smell coolant sometimes
Intake Manifold gasket replacement fixed my very similar issue. New ones from GM are aluminum w/rubberized gasket - old ones plastic with a rubberized gasket - common failure in the 80-100k mile range. My mechanic did it for $620 included sealant,thermostat,valve cover gasket, gasket kit, coolant,pipe,pipe, manifold t and supercharger gasket.
Dec 15, 2012 | 2004 Chevrolet Impala
The tank leaks from the two bolts that hold tank to bowl. I replaced bolts and the rubber gasket (it has ears). Slow dripping from two bolts.
Under the heads of the two bolts (inside the tank) there should also be rubber washers. Remove the bolts, clean the bolt holes (in the tank) thoroughly (a nylon scouring pad works). If the rubber washer aren't new, replace them. If the bolts aren't new, replace them too. While you have it apart, thoroughly clean the surfaces where the large rubber gasket seats too, in case your leak is coming from there. If cleaning and new bolts and washers doesn't fix it, you might try some plumbers putty or bathtub silicon caulk (not on the large gasket). Coat the two rubber washer generously all over. Good luck.
Nov 01, 2010 | Eljer 141-0220-00 Toilet Tank White
Replace boot gasket
Hello, Remove the door hinges and plastic covers on the unused hinge screw holes on the opposite side of the door opening (door is reversible, so there are places to mount hinges left and right). Front panel will now snap out at top and lift off lower spring clips. One screw on each side will now release top panel and it will hinge up. Prop up with broom handle or something. Now you can get at everything. Rubber gasket is held onto drum with a cable loop and very strong spring. It rolls off the lip easily to disassemble but is VERY difficult to get back on without special tools or at least two people. Door side of rubber gasket is easy in comparison with rubber tabs inserted into slots and working the gasket into a groove. Hose clamp at bottom of rubber gasket to connect drain hose.
Thanks
Jun 10, 2010 | GE WSXH208A Front Load Washer
The rubber gasket inside the door falls off.
The gasket will have to be replaced. I've had customers with this problem and the only way to correct it is to replace the gasket
Jan 23, 2009 | KitchenAid 24 in. KUDI01TJ - Multiple...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
