Question about Hardware & Accessories
I need a class 2 TDC transformer model no. DA- 06-24. Can you help?
The transformer is for a string of 120 Christmas lights. I have swopped transformers with another string and the lights work so the transformer is the problem, but I don't know where to find another. Can you help?
2 Suggested Answers
  • 5089 Answers
SOURCE: TDC low voltage transformer model DA 150 12 W reset button trips
There is a short circuit.
Copy following link to identify possible problem and download manual
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Posted on Jul 17, 2012
How do you program a da-150-12w-1?
150 Watt Transformer TDC Power DA-150-12W-1 - eBay
www.ebay.com > ... > Outdoor Lighting > Walkway & Path Lights
eBay150 Watt Transformer TDC Power DA-150-12W-1 in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting, Walkway & Path Lights ' eBay.
New Free SHIP TDC Power Da 150 12W 1 Low ... - eBay
www.ebay.com > ... > Outdoor Lighting > Other Outdoor Lighting
eBayNew, Free Ship, TDC Power DA-150-12W-1 Low Voltage Transformer, 12v 150watt Max in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting ...
[PDF]SECTION H - Etlin
www.etlin.com/pdfs/Outdoor_Transformers.pdf
1-800-661-9610 (Canada) 1-888-762-5384 (USA). OUTDOOR LOW ... DA-XX-12WSeries - 60 to 150VA Small Case Low Voltage Outdoor Transformers.
Da-150-12w-1 Manual ' downloadthingsfast.com
Dec 09, 2015 | Malibu Hardware & Accessories
May 02, 2012 | Hardware & Accessories
How to cut to size christmas light strings
If you cut the line it would reqier less power so inturn may blow the globes.. it can be done but i woulden advise it if you dont know your electronic basics...
Oct 21, 2011 | Christmas Lights Etc Santa's Toy Truck
Hi, I have to reset the points on my RM6 Raleigh Runabout. Could you tell me how many mm's before TDC they should begin to open. Thank you. Lawrence Curley.
When the engine is not running, ideally the points open at TDC...they will advance once the engine is running.
If you don't have a timing light, an old trick I used to use was to get a string of christmas tree lights that had 10 of those tiny lights in series. Why 10? 120V / 10 lights - 12V/light.
If you have a string with 20, you can take 2 in series, but the idea is to clip out one of the lights and put it across your points. slowly rotate the crank in the direction of normal rotation, and the light should come on as you hit TDC (ignition must be on, so remember to remove the sparkplugs!)
If they are off, adjust them, and either come full circle, or go back at least 1/2 revolution and then come back to TDC slowly.
It's an old poor mechanics trick, but I tell ya, it works well!
Mar 14, 2011 | Triumph Speed triple Motorcycles
1/2 strand of christmas lights do not come on
There's a blown bulb.. take a spare globe & pull out one of the lights that is'nt working on the strand and put the spare one in if the string doesent light up try the next one and so on..
Dec 31, 2009 | Christmas Lights Etc Santa's Toy Truck
We purchased an Everstar pre-lit Christmas Tree and we can not locate the manual or instructions that came with the tree any help since half the tree doesn't light up and all the plugs are plugged in....
I have a 3 piece Everstar 7/12 slim pine and here are the plug portion of the assemblly instructions . "1) connect the plug(A1) of string with the end cord (B1) of string. 2) Insert the plug (B2 & C1) of string into the wall outlet. 3) After the plugs are plugged into the wall outlet your entire tree should be lit. If some bulbs do not light, search for any loose plugs, broken, loose or missing bulbs that may have caused the problem."
My illustration shows the A1 in the top section of the tree while B1 is in the middle section. Both the middle section and bottom section get plugged into the wall or extension cord. Hope this helps
Nov 28, 2009 | Solar Christmas Tree 6 Outlet Foot Switch...
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
Power transformer broke
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Jan 05, 2009 | Tech Solution TS-4500 Shredder
I need a power transformer for roland sde -3000
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma.
(UL) US Ite powuer supply made in japan
Dec 11, 2008 | Music
Hardware & Accessories Logo
76 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
