Question about Husqvarna Rose
Help I am missing one of the original software disks the the embroidery and digitizing program.
I am missing one of the original software disks the the embroidery and digitizing program. can I get the software some where. I have the dongle and all other parts. I also want to know how to connect the dongle to a lap top with USB no serial port available.
    Champion:
  • 243 Answers
The software has been upgraded many times and now uses a USB port. Which version of software and which disc are you missing? I may be able to help.
Posted on Nov 21, 2013
SOURCE: Connecting Reader Writer Box To New Computer
After checking with the Dealer, I was told my old Reader/Writer Box & embroidery software is not compatible with Windows Vista. I will have to purchase a new R/W Box which has a USB cable & a different type of dongle.
Posted on Feb 24, 2008
  • 192 Answers
SOURCE: husqvana designer1 embroidery machine
If you are using the 3D version of the Husqvarna Viking software, you may need to download the latest dongle drivers.
If it is 4D, you may need to update the dongle and you can do it yourself.
Check for support at:
http://www.husqvarnaviking.com/us/8588.htm or go to your local Husqvarna Viking dealer.
If you are trying to run 3D on a Vista computer it can be a little complicated. Let me know if this is the case.
Posted on Jun 12, 2008
Ajkill
  • 2035 Answers
SOURCE: Loaded 3D Embroidery software on
Try to install the software from the download as its latest version its will prompt you to remove the old version on your computer and follow onscreen instruction you be able to install the software...........
Posted on Jun 27, 2008
  • 371 Answers
SOURCE: No Dongle Attached Error Msg
You might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 13, 2010
  • 6 Answers
SOURCE: Have a new computer with windows 7. my old
The problem is that the software is so old it was written for 16-bit Windows 3.1 back in the early 1990s. Windows 95 and Windows XP maintained compatibility with that old software, but Windows 7 no longer does. A competent computer nerd could create a Virtual PC running Windows XP inside your Windows 7 box, and this would give you an environment in which to run your old software without keeping two computers around.
Posted on Jun 16, 2012
How can I send designs from my PC to my Toyota 830 embroidery machine when my Pantograms software/hardware is no longer working?
Some of the Pantograms software programs require a USB dongle connected to the computer. However, the driver for this dongle has to be installed before you install the software or connect the dongle. I suspect you may not have installed the driver or the dongle is missing.
Assuming that the dongle is connected:
Close your embroidery software program and all of the Pantograms software, including the Network C software, on your computer and remove the USB device. Put the software install CD into your machine's optical drive. (If your new machine doesn't have an optical drive, get a USB optical drive or copy the files from the CD to a 1GB+ USB flash drive at another computer with an optical drive.) If Windows XP starts the autorun routine for the CD, click Exit. Then double-left click on My Computer to launch File Explorer. Go to the CD drive (or USB drive if you used the work-around) and double-click on it. Open the Rainbow Drivers folder and then open the XP folder. Double click on the program: setup.exe . Choose Complete install as the program executes. Then close File Explorer when the install is done. Now insert the USB dongle and follow the on-screen message about New Hardware found to install the Rainbow driver from C: .
If you do not see the New Hardware found message, try putting the dongle into a different USB port. (Make sure to avoid USB hubs - they can add to USB device issues.) If the dongle doesn't work at any port, you may need to use a different method. There is a flash reader available for connecting a USB flash drive to the Toyota 830 here: http://www.plrelectronics.com/lab/usb_reader.php . (Scroll down to the Toyota machine section. This isn't cheap but it is cheaper than some of the newer embroidery software packages.)
I hope this helps.
Oct 26, 2014 | Sewing Machines
Transferring DVD designs to USB stick for my Husqvarna Designer 1
First you need your 4D software installed on your computer (or which ever version you are using). Insert the DVD into your drive. Then open your embroidery program and then click File and Open. When the new window opens, search for your DVD drive then find the embroidery you want and click Open. The embroidery yoiu chose should open in your embroidery program with the hoop displayed on the screen. Then save the embroidery under a new name in your embroidery design folder on your computer. Then insert your USB into your computer, Open Disk Manager and Read your USB. Then click on one of the empty squares and then click File then Open. In the new window find the embroidery file you saved under a new name on your computer and choose it. It should show up in the empty square you clicked on. Then Write to your USB. Now you are ready to move your USB to your machine and the embroidery should be there. Hope this helps. Good luck.
Oct 17, 2013 | Husqvarna Designer I
I just bought a used Designer 1 ESS machine and I do not know how to use the dongle
You don't need a dongle for the sewing machine. You either have a dongle for the computer embroidery software in which case it goes in your computer when you've installed the software, or you have a USB stick that has the Husqvarna designs on it.
What colour is it? The USB sticks are blue, the 3D software dongles are red. Only problem is, I think the 4D software dongles are blue too!! My Husqvarna Designer 1 USB embroidery stick (blue) has "USB Embroidery Stick" written on it - have a look for that. The dongle will have Hasp or something like that written on it.
If you are pretty sure it is a USB stick, put it in your machine and turn it on. Then touch the disk/stick icon on the lower right hand side of the screen. Your machine should start to read the stick and you will get a pop-up menu where you can choose from the folders on the stick. If you don't, go into the PROG screen. Touch MENU, touch the disk/stick icon and see if the embroidery files on the stick come up then. Each machine came with a set of designs called Embroidery Disk 100 and three alphabets - Palace Script, Kaligraphia and Clarendon. These should all be on the USB stick.
In the event that it is a dongle you have, but not the software, you need to contact the person from whom you purchased the machine.
You can download the Husqvarna designs from the Husqvarna website, but you will need a Husqvarna formatted USB stick to do this. Therefore, you do need software on your computer. There are some low-cost alternatives to the Husqvarna software - Embird and Sew What come to mind. However, a Husqvarna program called 3D Disk Manager USB came with every USB Designer 1 machine, so you should have got that when you purchased the machine. This will be enough for you to load designs from the HV website and from other websites where you purchase designs.
Nov 25, 2010 | Husqvarna Designer I
The 3-D embroidery system seems to be only compatible with downloading the designs to a floppy disk. I have a Husqvarna Designer I that has a USB port. Is there any way to download designs to an USB...
USB Designer 1s use Disk Manager, just like their floppy disk sisters, but it needs to be Disk Manager USB. New USB Des1s came with this program on a CD, and this software was also included free when a floppy disk Des1 was converted to USB. If you bought your D1 USB new, check the disks that came with it - one should be Disk Manager USB. If you purchased the machine second hand, contact the seller and ask for the program. It is a free standing program and you don't need a dongle. Check your 3D software - you might already have what you need. Open 3D, click down arrow for Accessories (far right-hand side) - what does your Disk Manager say? If it says Disk Manager USB you are okay to go.
I am not 100% sure of this, but I think that maybe the last update for 3D software (version 7.25) might have included Disk Manager USB. Go to the Husqvarna website and make sure your 3D is updated to the latest version.
If none of the above helps you, there is always the cheap cost embroidery software alternatives: Embird or Sew What. I believe they can write to Designer 1 USB sticks now.
Nov 09, 2010 | Husqvarna Viking 1
I bought a reader /writer for my husk. Platinum 955E. Now I have changed my computer and have lost the disc that is neded to install the program. I did register the reader/writer..but of course can't...
Have you tried asking your Husqvarna dealer to help you out? They very likely would have the software available. Another place to try might be an online group specializing in Husqvarna embroidery machines e.g. Yahoo Groups. One of the members there might be able to assist you with a spare copy of the software disk.
I can understand how frustrating these sorts of things can be. I've owned Husqvarna embroidery machines and software for about 15 years now and have experienced a few problems. However, be assured that other brands are not without their share of problems too. Husqvarna did make using their products somewhat awkward in those early years of embroidery machines, wanting to protect their property from being pirated and having to use the reader/writer and associated software was one of the prices to be paid. Technology has since moved on and these kinds of problems rarely occur these days. That's no comfort to you in your present predicament, I know, but your machine is a quality machine and worth getting it set up so it works for you the way it should. Good luck in sourcing a disk.
Oct 13, 2010 | Husqvarna Designer I
Downloading designs from the internet
Disk Manager is part of Customizing software, in case you were wondering if you needed to buy more software. Ask again if you are having trouble locating it. You also need to format your floppy disk in Disk Manager before writing your designs to it.
Jan 22, 2009 | Husqvarna Designer I
Husqvarna 1 Embroidery software
Use program compatibility wizard and you'll be able to use the same program in Windows XP also.
  • To start the Program Compatibility Wizard, click Start, click Help and Support, click Find compatible hardware and software for Windows XP, and then, under See Also in the navigation pane, click Program Compatibility Wizard.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Dec 20, 2008 | Husqvarna Viking 1
Futura CE-100 software
I did and they gave me no answer to the problem. They had told me I could buy a new software disk from them. Buy?!?! I got the disk with my machine! I still can't figure out this problem, I uninstall and reinstall the software everytime I use the embroidery part of the machine. This is driving me nuts..
I am a seamstress and a costumer, having this problem with the machine is bad for my business. If I would have known then what I know now about the machine I would have never bought it.
Jan 13, 2008 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
56 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
