Question about Dell Latitude D610 Laptop Computer - Intel Pentium M 750 1.86GHz, 802.11b/g Wireless, 1G PC Notebook
Internal hdd hard error
After i press f1 it says no bootable devices
    Sergeant:
  • Dell Expert
  • 464 Answers
Using the F12 Diagnostics
* Reboot and press F12 to enter the Boot Menu
* When the boot device list appears, highlight Diagnostics and press Enter
* The computer begins to run the Pre-boot System Assessment, a series of embedded diagnostics that perform initial testing on your system board, keyboard, hard drive, and display
* If the Pre-boot System Assessment completes successfully, you receive the message Booting Dell Diagnostic Utility Partition
* Press any key to continue
* Press any key to start the Dell Diagnostics from the Diagnostics utility partition on your hard drive
* After the Dell Diagnostics loads and the Main Menu screen appears, click the button for the option you want to run -
Express Test = Performs a quick test of devices. The test typically takes 10 to 20 minutes and requires no interaction on your part
Extended Test = Performs a thorough check of devices. The test typically takes 1 hour or more and requires you to answer questions periodically
Custom Test = Tests a specific device. You can customize the tests to be run
Symptom Tree = Allows you to select tests based on a symptom of the problem you are experiencing
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen
Posted on May 02, 2014
HW_Dude
  • 87 Answers
SOURCE: Internal HDD hard error
By your description it is very likely your hard drive finally failed. You probably looking at total data loss unless you have made recently an backup of it. You will have to get a new HD and then you can install your OS and software.
Another more remote possibility is that when you opened some covers, you accidentally disturbed the HD connection causing this problem.
Just for clarification, was there a lot of dust inside ?
Hope this helps.
Posted on Jan 12, 2009
  • 336 Answers
SOURCE: no boot sector on internal hard drive. No bootable
A boot sector is a sector of a hard disk that contains booting programs stored in the other part of the hard disk. You boot sector might have been deleted or corrupted and you can't logon until you repair or recover the boot sector. To do this you must have your OS cd. Boot from OS cd the follow below steps...
Windows Vista
1. Insert the installation disc.
2. Restart your computer
3. If prompted, press any key to start Windows from the installation disc.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7.
On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Boot from you hard disk then you're done!
Regards,
Jeep Brainy
Posted on Jul 29, 2009
  • 916 Answers
SOURCE: Won't turn on
No bootable device usually means that your hard drive has failed. It is either not connected properly to the computer or the drive needs to be replaced.
Posted on Oct 27, 2009
  • 8909 Answers
SOURCE: i have no picture. all
It would appear that the hard disk has failed and because the BIOS cannot find a drive, it is getting confused and continually resetting.
Fit a new hard drive and install your OS. Don't forget you will need to install all drivers that are not included on your OS disk.
Hope that helps.
Posted on Nov 19, 2010
  • 4 Answers
SOURCE: internal hard disk drive not found To resolve this issue, try to reseat the drive. No bootable devices--strike F1 to retry boot, F2 for setup utility Press F5 to run onboard diagnostics.
it looks like your hard drive has crashed but before i confirm you need to try these steps first.1:remove the hard drive if its a SATA make sure the connectors on the drive and laptop are clean, if not clean it. if its an IDE check for any bent or broken pins.2: connect your hard drive to another pc or laptop using an external cable and if it is detected try and retrieve as much information from it as possible and format it with the quick format option deselected.3:if you dont have an external cable to connect it after you have physically cleaned the hard drive, mount it back in the laptop and check to see if it still gives the error. if it does run a windows installation setup from a disk and see if it recognises your hard drive. you can then format it from there and reinstall the operating system on it. 4: if non of the above methods dont work you should consider replacing your hard drive.
Posted on Feb 06, 2012
Dell inspiron 2330 AIO shows no bootable device. i installed a new hard drive and it still says no bootable device
Please Install OS correctly or if it is installed than repair your OS with Bootable OS disk or USB stick
Apr 21, 2017 | Dell Computers & Internet
Get message internal hard disk drive not
This may mean that your computer is trying to boot from a non-bootable drive. Try hitting f12 when you restart the computer and select which drive would have your OS on it. You want to change the boot sequence to diskette drive as your 1st choice. The order should be Diskette Drive, Internal HDD, USB storage Device, CD/DVD drive.
Apr 08, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
Presario v2000 wont boot it powers on then screen says press F1 or F10 but can go no farhter
Sounds like it is not seeing a bootable device, maybe bad hard drive, could be a bad setting in bios. Click here for tech support
Mar 26, 2013 | HP Compaq Presario V2000 Notebook
Starting my laptop i get this message internal hard disk not found To resolve this issude . try to reseat the drive "which i did" no bootable devices stike f1 to retry boot , f2 for setup utility...
Hi ajmedina89,
If your system wont boot up and has a no "bootable devices" message, is often caused by a defective harddrive. I recommend to try a different HDD before replacing your system HDD to isolate the issue.
Hope it helps.
Thank you for using FixYa.
Apr 25, 2011 | Dell Inspiron 1545 Notebook
I turn it on and it says no bootable device press f1 to reboot ir f2 for setup
start it up and keep pressing F* until the screen appears with the SAFE MODE showing. Choose that to start. If it shuts off the hard drive is shot
Dec 19, 2010 | Dell Latitude D600 Notebook
I am trying to format my acer aspire 5735z laptop. I try it with my recovery disc but its not happening, i am trying by putting disc and pressing f2 even but when i go to boot menu and try to press cd/dvd...
To change the bootable device you need to go to bios setting. Depending on your computer make and model the way to go to bios could be different though generally you can go to bios by continuously tapping on F1 or F2 or F9 or F10 or F11 etc The moment you press the power button and you see flashing brand scree like dell, hp etc. start tapping on F1 or F2 or F9 or F10 or F11 only one key at a time.
The best option is to install any version of windows is to use Wintobootic search and download it on a computer. Use any storage device like external hard disk or pen drive. make sure the storage device is completely blank when you make it bootable. insert your windows CD and Open wintobootic, select source and make bootable storage device.
for more info Visit : http://leadingpcfix.com/
Feb 25, 2018 | Acer Aspire 5735 Notebook
I have no picture. all i see is the words internal hdd hard error! it also says strike f1 key to continue or f2 key to run the setup utility. when i press f1 it say s no bootable devices
Hope that helps.
Nov 19, 2010 | Dell Latitude D610 Laptop Computer -...
Says my computer has no bootable devices--strike F1 to retry boot. F2 for setup utility. Press F2 and the computer advises no hard drive is present. There is a 100gb hdd installed.
But unfortunately the HDD is not detected in the computer.
Reset BIOS.
Check your hard drive connections.
Change the cables if it is a desktop.
If all these fail to resolve the issue, check the hard drive.
Nov 18, 2010 | Computers & Internet
My Laptop is Dell Latitude D600 (A16) Everytime I tried to power up, Splash screen appears with blue bar and when going into next screen this message appears " No bootable devices--strike F1 to retry...
Check your BIOS, by pressing F2 and see if the hard drive is recognized. It should indicate the MFR next to the hard drive listing. If it's not there, then you might have a bad hard drive. If it is there, try re-installing the operating system with the set-up disk. You can also go to the Dell website, enter you service tag number, and get technical support for your particular laptop. It might have a recovery partition in the hard drive to recover to factory settings.
Oct 26, 2010 | Dell Latitude D600 Notebook
Dell Latitude D610 Laptop Computer  - Intel Pentium M 750 1.86GHz, 802.11b/g Wireless, 1G  PC Notebook Logo
112 people viewed this question
Alun Cox
