Question about Hoover AL120 Front Load Washer
Hoover al 120
Noisy spin
2 Suggested Answers
  • 15 Answers
SOURCE: Hoover AL 120 washing machine won't spin
i would check the motor carbons it could be your problem if it fills goes through the programme until the end but has motor action
Posted on Apr 12, 2010
Hoover washing machine very noisy on spin cycle, removed the back panel and black sooty deposits on rear of drum
when you open the back did you check if belt has jump out (as they are grooved) or is wearing out, any other rubbing surface rubbing around, locate where the black sooty is coming from and i might be able to find the right answer.
Aug 09, 2013 | Hoover Washing Machines
My Hoover 500M top loader is very noisy on the spin cycle intermittanly. It sounds like a faulty or dry bearing, maybe when the water pump is emptying the bowl. The noise stops as soon as the spin cycle...
First I would bench check the water pump and see if it is operational or not. If it is then I would check the transmission. When it is in the spin cycle it switches to the high speed, so if you hear the grinding only in the spin cycle it could be the high speed gear.
Do you have any indication of a transmission leak? Fluid on the floor or on the transmission?
Jun 22, 2011 | Hoover Washing Machines
Apr 12, 2010 | Hoover AL120 Front Load Washer
Nextra is shaking itself to bits and extremely
sounds like the bearing has gone possibly taken out the drum support to shaking could also be one of the wieghts has worked loose.
Mar 15, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Hoover SteamVac Al Terrain Spin Scrub motor running in reverse
if it dosent **** up the water send it back but some hoover steamvacs blow air to dry the carpet or floor faster
Aug 01, 2009 | Hoover F7431-900 SteamVac Vacuum
Hoover new wave1200f noisy on spin cycle
I had a heavy knocking noise and found it to be the counterweight ( or stabilizer) whiich looks like a lump of cement, had come loose and was slapping around. Managed to tighten bolts holding it to the drum whiich solved the problem.
Apr 07, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Smell from tub
Does it the first time you have this bad smell and for how long do you use this machine in its cuurent location ? Try to run an empty machine cycle with a quart of vinegar to clean the tub and pump. Let me know if it solve your problem ? Good luck !
May 27, 2006 | Hoover H120M Front Load Washer / Dryer
Hoover AL120 Front Load Washer Logo
22 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
