Pat dearston can't find the sign in page always get someone wanting me to download a program of theirs
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
Sign-in page to what/where? You obviously found the sign-in page to FixYa,
Posted on Nov 20, 2013
I cannot block William Smith Sr. his name is on my fb page help
From Facebook's Help Center
How do I block someone? To block someone:
  1. Click 851548_427268774075825_1014901409_n.png at the top right of any Facebook page.
  2. Click How do I stop someone from bothering me?
  3. Enter the name or email address of the person you want to block and click Block.
  4. If you entered a name, select the specific person you want to block from the list that appears.
People will not be notified when you block them.
If you can't find someone using this method, try going to the person's profile and selecting Block from the 851583_139707006236950_404610498_n.pngmenu on their cover photo.
If you still can't find the person you want to block, it's possible that this person no longer uses Facebook or has restricted their privacy settings. Keep in mind that you can always control the audience of stuff you share.
More info
Get help for mobile apps and browsers
Help Center
Nov 23, 2014 | Computers & Internet
I want to login to facebook on someone else's computer
Log out of the other account and then log in on yours.
Feb 07, 2014 | Facebook Social Network
Delete someone else;s account from my computer
Point your web browser at http://www.gmail.com
If another user account comes up, sign out of it by clicking the avatar in the upper-right then clicking "Sign out."
If you then still can't sign in to your account, click the "Can't access your account?" link on the sign-in page.
Dec 24, 2013 | Google Gmail
My f-450 2008 diesel has a continued problem.. signal work with out key and flasher unit stay on continuous while key off.
PATS Transceiver
The PATS transceiver is located under the steering column shroud and communicates with the PATS ignition key. During each vehicle start sequence, the PATS transceiver reads the PATS ignition key identification code and sends data to the IC. The IC validates the code, and if it is the correct code, will send a message to the PCM to ground the starter relay solenoid coil and to also allow the fuel injectors to operate.
PATS Operation
NOTE: If the IC or the PCM is being replaced (or both), the parameters must be reset in both modules or the vehicle will experience a PATS no-start. This will occur even if the vehicle is not equipped with PATS. PATS vehicles and non-PATS vehicles have parameters in the IC and the PCM and they must be reset whenever either (or both) module(s) is (are) replaced. Refer to Passive Anti-Theft System (PATS) Parameter Reset in this section.
The PATS function is controlled by the IC. When the PATS key is turned to the ON or START position, the IC initiates the key interrogation sequence by sending a voltage signal to the PATS transceiver. The transceiver then uses its antenna to bounce a signal off the transponder in the PATS key. This process "reads" the PATS key identification code and sends the key identification code back to the IC, which interprets it and determines if it matches one of the stored key codes. If it does match one of the stored key codes, the IC will send a message to the PCM to ground the starter relay solenoid coil and to also allow the fuel injectors to operate. If it does not match one of the stored key codes, or it is only a partial key read or no key read, the IC will send a message to the PCM to not ground the starter relay solenoid coil and not allow fuel injector operation. The anti-theft indicator in the IC will flash (or may glow steadily) and the IC will store one or more DTCs. All elements of PATS must be functional before the vehicle will start. If any of the components are not working correctly, the vehicle will not start. If the IC must be replaced for any reason (PATS concerns or IC concerns), the PATS keys must also be programmed into the new IC. Refer to Key Programming Using Diagnostic Equipment in this section.
PATS disables the vehicle from starting if there is:
  • a damaged PATS key.
  • a non-programmed PATS key.
  • a non-PATS key (key has no electronics).
  • damaged wiring.
  • a damaged transceiver.
  • a damaged IC.
  • failed parameters between the IC and the PCM.
PATS Parameter Identification (PIDs)
Monitoring the PATS PIDs in the IC can be very useful in determining which diagnostic steps to follow. Viewing the MASTERKEY (verifies if the key is programmed) PID (with both keys) will determine if the key is a programmed key and will also prove out the transceiver, circuitry and the IC. A master key is any key that is programmed into the IC (the MASTERKEY PID must display PRESNT). If the MASTERKEY PID reads NOTPREST, it may mean the key in the ignition lock cylinder is not programmed, is not a PATS key, is damaged or the transceiver, circuitry or IC may be at fault.
Viewing the MIN_KEY (minimum number of keys) PID (this PID does not change) indicates the minimum number of keys that must be programmed into the IC. There must be at least 2 keys programmed into the IC in this type of PATS before the vehicle will start.
Viewing the N_KEYCODE (number of keys programmed) PID will determines if the minimum number of keys have been programmed into the IC. If the N_KEYCODE PID reads 0 or 1, additional key(s) will need to be programmed into the IC in order to meet the minimum of 2 keys. If the N_KEYCODE PID reads 0 or 1, and the MASTERKEY PID reads NOTPREST, that particular key must be programmed into the IC. If the N_KEYCODE PID reads 1, and the MASTERKEY PID reads PRESNT, that particular key is already programmed into the IC.
If the IC was replaced, the parameters in the IC, then the parameters in the PCM will need to be reset. When the parameters in the IC are reset, that clears (erases) the PCM ID from the IC. A parameter reset of the PCM will send a PCM ID to the IC that is necessary for the system to operate. Make sure to make 3-5 attempts to start the vehicle for 3-5 seconds each before attempting more procedures. The extra key cycles are necessary for the PCM ID to be sent (by the PCM) and then stored by the IC. If only a PCM parameter reset occurs, the IC may encounter 2 PCM IDs (the original one and the new one) and may cause a PATS-related no-start. If a PCM parameter reset occurs first, then the IC parameter reset occurs, there will be no PCM ID stored in the IC, and a PATS-related no-start may occur. Carry out the IC parameter reset first, then the PCM parameter reset next. If the PCMID PID reads STORED, the IC has a PCM ID stored. If it reads NOTSTRD, a parameter reset of the PCM may resolve this issue. If the PCMID PID reads STORED, the PCMVER (the PCM ID has been verified) PID will read YES.
If the PATSENABL PID reads DISABLE, and the N_KEYCODE PID reads 2 or more and the MASTERKEY PID reads PRESNT, the IC and the PCM will need to have their parameters reset.
If the PATSENABL PID reads DISABLE, and the N_KEYCODE PID reads 1 and the MASTERKEY PID reads PRESNT, or if the N_KEYCODE PID reads 0 and the MASTERKEY PID reads NOTPRESNT, a minimum of 2 keys will need to be programmed into the IC. Refer to Key Programming Using Diagnostic Equipment in this section.
If the MASTERKEY continues to read NOTPRESNT after programming, this may indicate a defective key. The SPAREKEY (spare key) PID is defaulted to ENABLE. With the SPAREKEY PID displaying ENABLE, the IC will accept more than 2 keys (up to a maximum of 8) being programmed into the IC. Refer to Key Programming Using Two Programmed Keys in this section. It can be toggled to DISABL if the customer does not want any more than 2 keys programmed into the IC. Refer to Key Programming Switch State Control in this section. This switch state control does not affect the Key Programming Using Diagnostic Equipment procedure.
In summary for the IC PATS PIDs and their correct state in order for the vehicle to start:
  • N_KEYCODE must read 2 or more
  • MASTERKEY must read PRESNT
  • PCMID must read STORED
  • PATSENABL must read ENABLE
  • PCMVER must read YES
Aug 24, 2011 | 2008 Ford F 450 Super Duty
Hello I am trying to install CUBASE LE4 for usewith my Zoom H4n recorder but having diffultity getting the ZOOM H4 ASIO driver as mentioned in the setup guide. thanks pat
Hello Pat, you will probably have to download driver from the internet. I had a similar problem with another synthesizer software program. Even though the HD series Zooms come with cubase cds, they are not always compatible with the pcs. You should be ok after that.
Mar 23, 2011 | Computers & Internet
I want to download yahoo messenger
Download Yahoo Messenger
  1. Proceed to the Yahoo Messenger Web site. You will click the 'Messenger' link on the Yahoo home page or you can head directly to the Messenger Web site (see Resources below).
  2. Click the 'Get Started' link on the Messenger home page. This will redirect you to the download page for the latest version of Yahoo Messenger.
  3. Wait a few seconds for the download to automatically begin, or press 'Click Here' in Step 1 of the Yahoo Messenger download page. This will open the dialog box that begins the download.
  4. Double-click the Yahoo Messenger executable once the download completes to begin the installation process.
http://ph.messenger.yahoo.com/download/ Tips & Warnings
  • Use Yahoo Messenger for voice-chat, conferencing, chat and a host of other communications options. It's even possible to send important documents to your contacts using Yahoo Messenger without having to send an email.
  • If you're having trouble getting Yahoo Messenger to work, get your questions answered by visiting the Yahoo Help Web site.
  • Be aware that there are some less than honorable people who use Yahoo Messenger. They are capable of crashing your services using boot programs or they will continually send you spam messages. Remember you can always choose to block, or ignore, other users so they can't continue to contact you.
Feb 07, 2011 | Yahoo Messenger
Need to download lexmark x2600m copy scan print photo printing
Hello Mellisatippe,
When ever you are looking for printer drivers, always check the companies home page. Printer companies always offer their printer drivers online.
Here is the link for the drivers for your printer
http://support.lexmark.com/index?segment=DOWNLOAD&userlocale=EN_CA&locale=en&productCode=LEXMARK_X2600&page=recommendedDownloads#2
Thanks,
Pat
Mar 30, 2010 | Lexmark Computers & Internet
How do i sign up someone else on this computer for facebook
You can help someone else sign up for facebook by going to facebook and entering their First, Last Name, email, a passord, and birthdate on the main page.
They will need to check their email to confirm the creation of the account afterwards.
Mar 30, 2010 | Facebook Computers & Internet
Downloading file error. help?
Well, it could be one of the trackers that you're downloading from requires an account on their site. So you MAY have to sign up to be able to fully download from one of them.
If you want to try another download managing program, you could always try Vuze ( Formerly Azerus
Jul 06, 2009 | Microsoft Windows Vista Ultimate Edition
I have a problem error 81003005 how can i remove that error ?
You could try uninstalling the messenger and then doing a clean download and install(meaning make sure when you download that all of your running programs are turned off, including your virus control.) Also, you might want to check your virus control under interent content or whatever yours may call it and see if you have been prohibited from using yahoo messenger there. Someone may have accidentally prohibited any chat or messenger programs. Good luck and let us know with a rating. thank you.
Aug 13, 2008 | Yahoo YHT-630 System
Computers & Internet Logo
David Payne
David Payne
