Question about Continental Manufacturing Company Heating & Cooling
Flame rollout on boiler
Suddenly have carbon monoxide type smell, edges of heat exchanger are black from soot, looking at flame when running it is actually lapping outside the firebox. As i said, it suddenlt developed, check exhaust pipe up through the attic and roof where if has worked for years, no obstruction. Light a candle, blow it out, hold it near the exhaust and it sucks the smoke right up, reasonably certain I do not have a exhaust pipe problem.
  • 69 Answers
Is this a hot air system ??? if so does this problem occur when blower comes on if so heat exchanger is cracked.
Posted on Nov 20, 2013
  • Bob Myers
    Bob Myers Nov 20, 2013
    No, it is a boiler system, water recirculation system. On a whim i adjusted the pressure regulator to lessen the height of the flame, that seems to have squelched the problem for now. I guess the regulator is going bad?
5 Suggested Answers
SOURCE: 8 year old oil fired boiler with horizontal
Hello Change the ignition TRANSFORMER on the burner.
Posted on Sep 13, 2010
Testimonial: "Changed the transformer per your suggestion and it has been working great since then. Thanks for the help."
  • 2550 Answers
SOURCE: williams wall furnace fire box full of soot carbon monoxide.
Needs a service big time turn off do not use phone a gas fitter and get it serviced .
Not a job for your self to do .
Posted on Nov 06, 2011
  • 2550 Answers
SOURCE: Reznor UDAP 100 tripping Flame Rollout Switch
If the flame is rolling out of the heater then the burners of heat exchanger is blocked needs cleaning
Posted on Feb 20, 2013
SOURCE: I have a goodman gmpno 60. I have a lot of flame
This was my 1st thought after a crack. The fact the indoor blower affects it is a give away. I would get a carbon monoxide detector, if it goes off you have some work to do.
Posted on Oct 19, 2013
My furnace is putting out a fuel smell and my filter is black what could be wrong
If the black is soot and you have a odd smell then it may need a service .
Jan 19, 2017 | Heating & Cooling
Amana 80 sse flame rollout sensed what does this mean and how do I fix.
The flame rollout switch is located in the burner box on the left side on an upflow model. There are two wires connected to it .between the two connections is a small red button. Depress this until you here a small click. This should reset the switch. These
switches usually open because the flame is "rolling" back instead of being drawn into the furnace.start furnace and check for flame rollout.when the main blower fan comes on if you notice any change in the flame turn furnace off and call a qualified service person as this could indicate a cracked heat exchanger and could cause carbon monoxide to enter the house a potentially dangerous situation. I strongly urge anyone with a gas appliance installed to have a good carbon monoxide(CO) detector installed also. Hope this helps.
Dec 10, 2013 | Heating & Cooling
I have a goodman gmpno 60. I have a lot of flame rollout especially on ignition rolls all the way out the box. After ignition and before Blower kicks on still have flame rollout but is more after Blower...
Oct 19, 2013 | Heating & Cooling
Rollout switch continues to trip
If you have a cracked heat exchanger this will cause the flames to rollout and trip this switch. Its meant to stop the furnace from running and putting carbon monoxide in your home. Watch the furnace as it tries to light if when the gas valve opens and flame is established it should go into the tubes heat the heat exchanger and then your main blower motor will come on. When your main blower comes on is usually when you see the flames rollout and trip that switch. If this happens you can either buy a heat exchanger or new furnace if its a older unit Obama still has that awesome tax credit til 12-31-2010.
Dec 13, 2010 | Goodman Heating & Cooling
Opened pool. Rheem heater has the service light blinking
rollout switch is open, and sns is a sensor failure. replace rollout switch, clean out vents, inspect heat exchanger. water sensor senses too cold or too hot water
May 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Is there a way to adjust the size of the flame on a wall heater gas valve. The gas company says it is smothering. The flames creep over the side into the gas orfice output and is not completely burning all...
Hi, this is a very dangerous condition and is the cause of many carbon monoxide poisonings or deaths. Please do not use this heater. The smothering is caused by a restricted heat exchanger not an over fired flame. You need to have the heater serviced or replaced before using. The heat exchanger would need to be pulled and cleaned, it is possible that flu is also restricted with soot and would need to be cleaned as well. I'm sure the gas company red tagged this unit for good reason. Good luck.
Jan 14, 2010 | Williams Heating & Cooling
Black film from furnace/AC
I would be concerned that exhaust is not venting properly and the soot is getting into the fresh air side of heater. Have unit checked for carbon monoxide presence in fresh air ducting. Heaters use a heat exchanger the is heated by the furnace and fresh air is blown through yje exchanger to be warmed before it gets out the vents. If the exchanger is damage or rusted through the good and bad ai can exchange creating a serious/ life threatening condition. I recommend professional inspect and repair and have a carbon monoxide detector in place and functioning. Be safe and good luck
May 16, 2009 | Heating & Cooling
Smell Coming From Intertherm Furnace
It could be several things.
The most alarming being a cracked heat exchanger allowing the exhaust fumes to enter the living space.
Exhaust fumes that contain carbon monoxide.
I HIGHLY RECCOMEND that you purchase carbon monoxide detectors, and/or check the batteries in any you might already have.
Carbon monoxide can be deadly at high concentrations.
It could be burning wires, but would smell like burnt rubber.
It could be mold/mildew but would smell musty like dirty socks.
It could be a build up of dust oil etc on the heat exchanger, but that is usually only smelled when it is started up for the first time in months.
Make sure the filters are clean. Dirty filters can cause overheating of the heat exchanger and sometimes cause smells.
This is one of those times I will recommend you have a professional look at your unit.
Specifically the heat exchanger to look for cracks.
A pro will know where to look, where the usual stress points are etc.
Dec 10, 2008 | Kitchen Appliances - Others
Coleman Evcon Furnace Model G8T10012UHB11A
you probably have a cracked heat exchanger which is causing the rollout switches to trip.even the tiniest of cracks will cause the fan to blow the flame back into the unit and cause them to trip. check the heat exchanger for even the tiniest of cracks if so replace it. and be sure to have a carbon monoxide alarm in your home.
Oct 25, 2008 | Heating & Cooling
Heating & Cooling Logo
46 people viewed this question
Top Continental Manufacturing Company Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Continental Manufacturing Company Heating and Cooling Expert? Answer questions, earn points and help others
