What size central a/c,heater do I need to cool-heat a 2400 sq/ft house in west Texas
I like to run the ducts under the house so the cool air or heat will come from the floor up and go through the house.
  • 739 Answers
You haven't included enough information to give you an accurate number. Things to consider are:
- R value of attic and wall insulation
-cubic footage of the living area
-are the windows single double or triple paned... low E ?
-how many hours of direct sun?
-how many points of return air do you have?
Its better to over size your system than to undersize.
One more thing to consider.... heat rises, cooled air falls and if you want to run your ducting under the house? insulate the crawlspace walls.
Posted on Nov 20, 2013
4 Suggested Answers
  • 12 Answers
SOURCE: amps needed to run a central air unit
Central air requires a 2 pole 30 amp breaker or fuse. You may be able to get by without it but 200 amp service is recommended.
Posted on Jan 31, 2009
  • 146 Answers
SOURCE: AC not cooling
first off you should have a four ton unit. what is your super heat? is it pulling attic or outside air?
Posted on May 28, 2010
SOURCE: Air condition unit of sufficient size??
You currently own a 2.5 ton AC Unit
500 square feet equals a ton of cooling/ you need a 3.5 ton unit.
If your home is well insulated, good windows and doors and pretty good
shade that covers your house, then I can see a 3ton unit cooling your
house.
Thats another 6,000 btus you do not have and that is a best case for a
energy effcient home.
Posted on Jul 08, 2010
I just had 'goodman gpc1336h41ab' 13.00 seer unit installed , I have a 1250 sq. ft. home and it just doesnt seem to be cooling. The unit runs constantly. So my question is , is my unit big enough...
There are a few variables that determine the size needed to cool your home - the size of your home, type insulation, are just two. I have a 2600 sq ft home - about 1300 sq ft per floor. I choose to cool the entire second floor (bedrooms and baths) and two of the largest rooms on the first floor (kitchen & living room) via flexible ducts from an air handler installed in my attic. My house was built in 1960, and at the time had electric heat. This means it is fully insulated. I replaced all the windows with energy efficient types, and vinyl sided. I installed soffit, ridge and gable vents to keep my attic well ventilated. I can cool my house in Boston, MA to 70 degrees (when it is 85 degrees inside) with a 4 ton unit in a little over an hour with no problem (one ton of cooling is equal to about 12,000 BTUs). Your condenser should not run non-stop. If it is not cooling then it is not a thermostat problem, but could be a gas charge problem. If you haven't paid the contractor in full yet - that may be the reason why. The contractor should know how much cooling you need for the space you have and installed a properly sized unit. Make sure your air filters on the return are clean and replaced regularly. Call the contractor and explain the problem - he should be able to solve it for you very quickly.
Aug 03, 2011 | Heating & Cooling
Eddfx24fa2 model # on furnace of central air unit in my basement I am trying to calculate wattage of this central air unit On compressor outside: 220 volts, 60 amps??? Does amps sound correct? amps x...
It is a two ton system. and without doing a heat load Calculation and not knowing the heat load It would not be anything but a guess. But if everything is working properly and the system is clean and with good duct work, than it should be big enough for the size of your house.
Jun 06, 2011 | Airtemp B6Y12F2A Air Conditioner
Gas Furnace Model GMH 95070, installed May 09. Air flow from registers noisy. Installer reduced it one level -still noisy. Said it cound not be cut lower because it would get to hot due to slow air flow. I...
Seems to me, the problem is not with gas, it's with the size of the duct work. 4" diameter is way to small if the entire duct work system is only 4". The trunk line may have not been sized proper,y. so the volume of heat has now been translated into high pressure, which is why the registers are noisy.
Also 6" ducts coming off a larger trunk line to each register is the norm for 1000 sq ft home.
Also, are your registers in the floor or the ceiling? Ceiling registers historically are a little noisier than floor registers. Mainly because, they're overhead and closer to your ears. But, if they were up-sized to 6", the noise would decrease quite a bit.
Hope this helps.
Feb 10, 2011 | Goodman Heating & Cooling
Does not seem to be sufficient cool for a 1600 sq ft manufactured home coming from the Coleman unit installed. Some vents more air, others less air. Unit runs without stopping ever. Can you give us some...
Hi John, depending on the size, I would need the model number from the outdoor unit if it is a split system, you should have 400 cfm per ton of cooling. If you have a 1600 SQ' home, and a 3 ton unit, 3 x 400 cfm is 1200. It would be to small. There are 12,000 B. T. U.'s of cooling per ton. 2 tons would be 24,000 b t u's. 3 tons would be 36, 000 b.t.u.'s. Also, most contractors put lever dampers in the duct work that can be adjusted. They will put a red flag where the lever is and we can adjust the flow to balance out the house. I don't know where your ducts are, under or above, but with a good light find the crawl space and check it out. Get the model number and call it in to get the tonnage or send it to me and I will tell you. It will have a 024, 030, 036, 042, or, 060 in the number, MODEL number and figure like I told you above, 12,000 per ton. 060 would be a 5 ton. This will let you know if the unit is the right size or not. Please rate me on this and I know you will be kind. Thank you John.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
PS CFM is cubic feet per Minute.
Aug 05, 2010 | Coleman Heating & Cooling
I'm looking to purchase a Rudd 2 stage model, 16 SEER, 5 ton along with a 100000 BTU 95% furnace. I have a two story home and will only be using the 1 AC. Will the Rudd cool both floors?
Assuming that there are ducts ran upstairs and downstairs, it all depends on the square footage of the living spaces, i.e. bedrooms, living room, dining room, etc. You need an average of 1 cfm per sq ft. For every 1 ton of air, you have an average of 400cfms. So your 5 ton unit will cool/heat 2000 sq ft. A 16 seer unit with a 95% furnace is a nice buy and you will notice the difference for sure. Hope this helps!
Aug 03, 2010 | Ruud Central System Air Conditioner
Im installing an 2.5 ton package heat pump into a existing house running reduced supply trunk in crawlspace 1200sqft home and dumping 750 cfms to 850 cfms into conditioned space . i need to know what the...
400cfms equal 1ton of cooling/ 500 sq. ft equals a ton of cooling. It also depends if you are starting from one end of the house or in the center.
Count how many 6inch leads you have or registers you have in the entire house. If you have11 leads on one side of the house and 11 leads on the other side of the house. Then you need 24x8 duct on both sides of the plenum.
Take 11 times 2= 22 plus 2= 24x8 duct. If you have a ductulator this always comes out right if you selct .01 static pressure.
Good Luck
Jun 24, 2010 | Heating & Cooling
How many sq feet will a 41 model heat?
It all depends on how well your house is insulated. A Monitor 41 has the same output rating as a Monitor 2400. It should heat around 2000 sq. ft.
Feb 08, 2010 | Heating & Cooling
I have an '06 model combination cooling and heatin
For every 500 sq. ft. house or a 1-bedroom size new house you need 1-ton of cool . An old house you need a ton worth of cooling for every 400 sq. ft. house or a 1-ton per 1 bedroom size house.
Dec 22, 2009 | Whirlpool Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
