MF50B Hydraulics when lifting back hoe is very slow there is oil in tank full ?
5 Suggested Answers
lindsay836
  • 677 Answers
SOURCE: 3350 on cold start hydraulics ok then after a
Does the pump make any noises, if you touch the cylinders are they hot ?
Posted on Feb 08, 2010
  • 251 Answers
SOURCE: ALLIS CHALMERS 190 GAS -HYDRAULICS ON TRACTOR ARE
hi , replace your hydraulic oil filter and pump and renew the oil .
hope this helps
Posted on Jun 21, 2010
judy_kitson
  • 8 Answers
SOURCE: Hydraulic failure
Check out your Ferguson Tractors Information Headquarters, sponsored by Ferguson Enthusiasts of North America (FENA) at www.fergusontractors.org
Posted on Feb 16, 2014
  • 44283 Answers
SOURCE: how do i fix my bobcat 825 skidsteers hydraulics ? the right steering leaver works fine but the left does very little to nothing.
basically there are 2 points of control
1---is the control valve for that side which may not be opening the system
2--- the drive motor for that side which may be passing excessive oil and not turning
for the lift action to be slow indicates excessive pressure leakage in that circuit
early units had lever action to the control valves where as later units use electronic controls from joysticks to operate the valves
If this is your type of machine, I would be looking at faulty electronic control mechanisms or corroded wires and contacts
Posted on Dec 15, 2015
Testimonial: "thank you for the help. its the early model so how would i fix it to make it turn ?"
Why can't hydraulics on tractor lift bucket and slasher?
Filters maybe plugged or need more hyd. oil
Jan 31, 2016 | Garden
WHAT TYPE FLUID IN HYD SYSTEM
If your hydraulics and trans are one using the same oil then use ATF oil, if your hydraulics is a separate tank then you can use a hydraulic oil, ATF, or a light weight oil
Jan 12, 2016 | Garden
How do i fix my bobcat 825 skidsteers hydraulics ? the right steering leaver works fine but the left does very little to nothing.
Dec 15, 2015 | Bobcat Garden
Where can i get a hydraulic tank
Hi I'm Peter, You can purchase a hydraulic tank many places the problem is what is it for . Is it a replacement tank due to your original being damaged or is it a project you are doing? Is there a leak in the tank? Tanks can be welded a LOT cheaper than buying a new one. With a little more detailed information I can direct you to where you need to go. Are you putting Hydraulics on your vehicle to make it jump or are you replacing the hydraulic tank on a John Deere 310D back hoe? See what I mean . I 'll wait to hear so we can get the correct size or part for your needs.
Apr 23, 2014 | Cars & Trucks
My 3000 ford tractor lift arms take 5 min. to work the first time in the morning then they are ok the rest of the day
I personally have a 1974 Ford 3000 diesel, and have had trouble with the rear hydraulics. I believe that you likely have the wrong weight oil in the reservoir. It sounds like it is too heavy, so when it is cool, it is too thick to cycle through as quickly as it needs to and you have slow reacting lift arms. By the time the tractor warms up the oil thins out and cycles more quickly. Try draining the rear reserve and using a lighter weight oil. If that doesn't solve the trouble then I would check the filters to see if they are intact.
Mar 23, 2012 | Cars & Trucks
I have a ford tractor and hydraulics are slow
not so fast,, yes thick hydraulic oil can cause slow hydraulics and if the hydraulics speed up when warm then this may be your problem. if they dont then you need to look at possible problems with the pump, the spool, or linkage to spool. remember that speed is flow, a pump can have good pressure but lousy flow. also there should be some kind of pressure relief valve in system if this stuck open then it will let oil go back to tank causing your problem. there is no quick answer to your problem but there are a lot of possibilities. need to do some diagnosing!
Feb 08, 2010 | Parat 1:32 Scale Diecast Replica: 1920...
Log splitter how to flush hydraulic system
removing hydraulic oil from the system
  • fully extend the cylinder. and shutdown.
  • remove the one end of the hose that is from the rod end of the clylinder.
  • two ways you can go here. either: detach the one end of the hose that is attached to directional control valve and leads to the cap end of the cylinder and place the end in a pale then retract the cylinder by physically forcing the rod back in and all the oil will drain out of the cap end into the pale and the rod end will fill with air.
  • or u could hold the directional valve in the position to let the oil flow back to tank while physically forcing the rod back in. the oil in the cap end will drain to tank and rod end will fill with air.
  • drain the tank of oil.
  • if you wanted to be extra thurough remove the remaining lines and drain the oil out of them.
  • reattach all lines.
  • replace oil filters/strainers. should be one on the return line going to tank. and one on the suction line before the pump. But there may not be a second filter.
  • fill tank with new oil.
  • extend the cylinder using the pump. allowing the air to bleed off the rod side. may chatter at bit while extending. if excessive chatter remove line end to allow the air in the rod side to bleed to atmosphere and continue till fully extended.
  • reattach line. probably a good idea to run a couple cycles.
  • and repeat the entire process for a thurogh flushing.
  • ! note: dont be dissconnecting lines with pressure in them or while the system is running.
  • ! note: be sure to have enough oil in the tank so the pump is not sucking air. this will eventually cause unrepairable damage to pump if sucking air for too long.
  • i just wrote this off the top of my head and ive only worked on industrial hyraulic systems and never on a log splitter before so just keep that in mind. hope it helps
Dec 04, 2009 | Plumbing
Where do i put 2 stroke oil? do i mix with petrol or is there separate canister?
alright it is under the fuel tank.
steps
1) take off seat
2) remove bold to lift up fuel tank (found near handle bars )
3) you will then see oil tank there
4) remember use good quality 2stroke oil
Feb 21, 2009 | 2000 Honda NSR 125
Computers & Internet Logo
David Payne
David Payne
