Question about Roland SOLJET PRO III XJ-540
Banding and gray turns either mixed pink or blue
There, Good afternoon, can you help please. I have a roland XJ 540. Lately I have terrible banding and gray turned out either mixed with pink or blue on my banner. I have checked the test print and Calibration and they are fine. The heater control is Preheat 35 C (95F), Print heater 35 C (95F), Dryer 50 C (122F), Other control Vacuum power 50, Dry time 0, Head height: Low. Third party ink. Room temp 16C (61F). Please advise, Thanks and much appreciated, Regards, Quinn
2 Suggested Answers
SOURCE: Low Volume on CDs - Roland 2400 CD
Hey Rick, There are a couple of places to look; I'll assume you have a decent input level near -12db average without peaking. First, ensure during playback upper right meter labled MST is near peak without going over, if you have room push the master level above 0db to +1 thru +6db and recheck for peaks above 0db. (You never want digital recordings to hit above peaks, you lose quality or resolution of the sound) As you find the sweet spot, master rec to 23/24-16 using the elevated level on the master fader. The manual suggest editing and mastering with the master fader at 0db however if you don't compress your tracks individually or reprint them at higher levels, you may have a great mix at an overall lower volume, pushing the master fader should help for a quick fix, but if this cures the level issue, try compressing and leveling each track to peaks prior to the first mix only lowering tracks which are too loud, when you get to mastering, all your signals are at their top potential for the CD. Spend a few minutes burning samples at low, just below peak, and just above peak levels on separate tracks and playback in your boombox for reference to a commercial CD. You'll find little to no difference when you are in the sweet spot. Another trick is to mixdown to a separate pair of tracks (not 23/24-16) and compress again during master mixdown rec. (ultimately 23/24-16) Good Luck Jeremy Yates, Radio World LLC.
Posted on Feb 07, 2009
I have just recently purchased a BMW ci328i and do not yet have the manual. The coolant sign is starting to flash up on dash. What coolant can I use?
There are many different coolants and if you mix 2 different ones together they can react and turn into a gel which don't do the car much good! the best way is look what colour coolant is in the system already and as long as you use the same colour coolant it will be fine, main colour coolants are green,blue pink and orange, green and blue can be mixed together as can orange and pink but Pink cannot be mixed with blue or green, i would guess the coolant in your car will be the pink stuff but please check 1st, hope this has been usefull to you.
Ash
Jan 09, 2011 | 2000 BMW 3 Series
I HAVE LOST THE INSTRUCTIONS TO MY COMMTEL MOD X1 EXTENSION SOCKET AND NEED TO KNOW WHICH COLOUR WIRE GOES WHERE ??? PLEASE HELP
I lost mine too, saw this post, and then they turned up, so here you are:
COMMTEL
Surface Mounted 2/6a Slave Wall Plate - with ADSL Filter
Instructions
  • Remove wall plate back box by removing the two screws on the front face
  • Fix wall plate to skirting board or wall with screws supplied, allowing adequate space for cable entry
  • Insert exisiting telephone wires into screw connections on the ADSL face plate, following cable colour coding according to the list below, and ensure screws are correctly tightened
  • Screw wall plate onto the back box with the screws supplied, ensuring screws are sufficiently tightened
Cable Colour Coding
1. Not Used
2. Blue with white banding
3. Orange with white banding
4. White with orange banding
5. White with blue banding
6. Not Used
Information
  • No need for external filter
  • Surface fitting, replaces existing wallplate
  • Quick set-up
  • With back box
* If more than one phone or fax IS required to run off the same line, simply add more filters where required. Each individual piece of equipment will require a seperate ADSL filter
* Multiple telephone connections, long runs of cable (over 20m) or low quality telephone cable can adverely effect the performance of your connection speed
Safety Information
Before carrying out any electrical work, always switch off at the mains. If in doubt consult a qualified electrician.
Item Code: 41603016
Distributed by Commtel UK Ltd
www.commteluk.com
It might be worth mentioning that this filter swaps the polarity of the telephone wires: I don't know why. I rewired mine to use it as a master socket, and I have connected the other extensions to the filtered output. This can improve broadband speeds: see
http://www.rob-r.co.uk/other/UKphonecatwiring.htm
Oct 23, 2010 | Computers & Internet
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Blues are pink?
either ur blue cartridge is empty or maybe the nozzle of ur blue are clogged .normally the dark blue colour is made up by mixing of blue and pink . because ur nozzles of blue are clogged or maybe the blue is empty it prints only in pink when u command for blues.replace the blue if its empty or clean the nozzles if its clogged.
Sep 15, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Optoma H30 Projector: color banding
Most DLP projectors have a colour wheel. It's usually hard to get at, and you may have to actually remove everything including the optical block from the projector to access it. This wheel turns on a motor just like a fan, and if it gets dirty it can act up just like a fan.
They are expensive to replace, so you might want to try taking it apart and cleaning it out. Add a small amount of 3 in 1 oil to the motor if you can.
Aug 22, 2008 | Optoma H30 Multimedia Projector
Soun connections
did you turn off onboard audio in the bios
Jan 14, 2008 | Logitech X-540 Computer Speakers
Banding on LCD TV
you need a new motherboard
Dec 09, 2007 | Televison & Video
Horizontal Banding
From the Microtek KB: www.microtek.com Scans that produce lines, fading, and discoloration generally result from a corrupt scanner driver installation or a burned out lamp. To determine if your problem is caused by a burned out lamp, simply open the scanner lid and check the color of the lamp. If the color is a shade of red, pink, or green, then the lamp is burned out. Perform a scanner preview to get a clear view of the lamp. If the lamp is a bright white and the problem still exists, please contact technical support.
Jun 06, 2007 | Microtek SCANMAKER 4850 Flatbed Scanner
Roland SOLJET PRO III XJ-540 Logo
51 people viewed this question
Top Roland Office Equipment & Supplies Experts
Chas Peters
Level 1 Expert
Michael Harrier
David Payne
David Payne
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
