Question about GE Profile WPRE6100G Top Load Washer
Dial won't set
When setting the load size dial (options range from small to super capacity, with reset option), dial now spins freely in both directions so that I am unable to select a setting. I usually hear a sort of fast clicking (for lack of a better word) noise as the knob turns), but now that noise is no longer there. This dial is supposed to turn without pulling the knob out or pushing it in. It seems as if there is no resistance, as if the "cogs" are no longer there to turn the wheel, although there was no indication that they might be wearing away, since the previous time I used the machine it worked fine. The machine is 7 years old, and is used approximately once a week, usually on the medium size, delicate, cold water setting. I think it is stuck on the small or smedium capacity setting.
    Champion:
  • 242 Answers
You can possibly remove the knob itself, and see if you can turn the dial itself. if you can, then you can probably see the knob is broken. if if the shaft turns, but doesn't move the gears, then you will just need a new dial switch.
Posted on Nov 20, 2013
Testimonial: "First of all, thanks for the help. But I'm a bit confused as I'm not a handyman by any means, so could you give me a definition? I know what the knob is (I assume that's the thing I turn that is visible on the front of the machine), but what what about the shaft, gears and dial switch? Thanks again!"
2 Suggested Answers
  • 17314 Answers
SOURCE: load size dial on washer spins freely instead of moving to setting
That setting has to do with how much water is let into the drum. You can get a new switch for that. If you post the model number.
Posted on Nov 18, 2013
Testimonial: "I know what the setting does, that's why it's called the load size dial, which is what I stated in my question post! What I want/need to know is how can I fix it, if it is possible for me to do so."
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
My washer wont turn on at all, wont fill up,spin or rinse on any setting
it sounds to me the lid switch problem. when it fails nothing works on some models
Dec 27, 2015 | Westinghouse WWS833ES Super Capacity Top...
Load size dial won't set anymore, just spins freely
Most likely the knob is defective, order a new one.
Apr 25, 2017 | GE Profile WPRE6100G Top Load Washer
Load size dial on washer spins freely instead of moving to setting
Nov 18, 2013 | GE Profile WPRE6100G Top Load Washer
Maytag centennial washer
Hello there and welcome to fixya
Here is the specifications on this washer
and this should explain why it dosent take much water to get clothes clean
This high-efficiency Centennial Top Load Washer features the IntelliFill automatic water level sensor and 11 automatic wash cycles to give you plenty of options. Low Water Wash with EcoConserve helps you save energy, while its spacious capacity means plenty of room for your largest loads. Inside, the stainless steel wash basket resists chips, scratches, and odors, as well as maintaining a smooth surface so it won't snag or pill fabrics. You get all that and still use 70 percent less water and energy in a model that pays for itself in four years. This no-nonsense machine does what you want.
  • CLICK HERE to learn more about Maytag Appliances
  • 3.6 cu. ft. capacity easily handles large loads and bulky items such as comforters
  • Rear panel controls provide convenient access to all cycle and option selections
  • IntelliClean impeller continuously moves clothes through the water for a thorough cleaning
  • 11 automatic wash cycles including heavy duty, casual, bulky and delicate to provide washing options to handle a variety of fabrics
  • ENERGY STAR qualified with a CEE Tier III rating: this washer is among the most efficient washers in the industry
  • Stainless steel wash basket resists chips and scratches and helps to protect fabrics from snags and pilling
  • Automatic Temperature Control monitors and adjusts incoming water flow to maintain the selected temperature for more consistent cleaning results
  • Low water wash with EcoConserve: use less water and get better cleaning performance through concentrated wash action, Low Water Wash technology enables the detergent to penetrate better and pre-treat soils with a concentrated mix
  • The IntelliFill sensor regulates the amount of water being used, making automatic adjustments based on the size of the load and type of fabric
  • MaxExtract Extended Spin option accelerates the load's final spin to remove moisture and reduce drying time
  • Deep Clean option uses a additional cleaning action and a deep rinse to ensure load is clean the first time
  • Click Here for details on the services included with Delivery & Basic Hook-up and Installation options for Major Appliances
  • MFG Model # : MVWC400XW
  • MFG Part # : MVWC400XW
May 25, 2013 | Maytag Centennial 7.0 Cu. Ft. Super...
The font on just my text messages in both sent and received is super small, how do I return to the normal size?
dear sir,
1.please metion your phone
2.fro nokia phones please follow this method
select main MENU - MESSAGING - OPTIONS (left bottom of screen) - SETTINGS - FONT SIZE and select appropriate size
thank you
Dec 26, 2010 | Cell Phones
How to use the dryer rack in dryer ??? how to set up so doesnt spin.
The dryer rack should hook to the bottom of the door opening(using the lip of the door). If the rack is properly placed the drum should be able to turn without touching the dryer rack. Some dryers have the option of turning off the drum. If your dryer does not have this button or a dryer rack position on the timer dial then you cannot turn off the drum.
Jan 22, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Washer will not fill all the way. Even when set on super it only fills to small load setting.
hi i can help you. to reset the fill level you have to move the dial all the way to reset, or as high as it will go and then back to what u want.
Jun 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
GE Profile WPRE6100G Top Load Washer Logo
128 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
