Question about Miele CVA 4066 Stainless Steel
I have the plumbed in Miele coffee system CVA 4066 I am trying to use it for the first time and it's telling me to fit jets in central spout not sure what that. Means
Everything else set up no problem and the system told me setup was ok.
4 Suggested Answers
mpcheeseman1
  • 1400 Answers
SOURCE: Our Miele CVA 4066 coffee
Hello
Check that you have water available from your water line to the coffe maker,Also you may need to manually fill the tank first time around.
Here is a link for the manual check out pg 56.This is a pdf file.
http://mieleusa.com/manuals_pdf/Residential/Coffee_System/CVA4066_us.pdf
Posted on Jan 08, 2011
  • 128 Answers
SOURCE: I have a three month old Miele CVA 4066. I have
your brew unit is clogged. It will need to be removed and cleaned every 24 hours as per the owners manual. There is a yellow laminated card in the box with the accessories that shows step by step how to perform the 24 hour maintenance. To prolong the life of the brew unit, make sure the coffee grind size lever is in the middle or to the right of center, rather than the left (fine) side. Also, you only want to use dry beans, preferably espresso beans. Oily beans like french roast will clog that brew unit up very quickly.
Posted on Feb 24, 2011
  • 128 Answers
SOURCE: miele coffee machine is stuck
pull the stainless steel dispenser cover straight down as far as it will go. now push it firmly up as far as it will go. if the error message still appears, repeat, but push up faster and harder. there is a switch monitoring the position of the central jets to make sure they are installed. you have to push up hard enough to close that switch. sometimes you have to slam it pretty good, but dont go crazy on it. just give it a firm touch.
Posted on Jul 19, 2011
This is for a Miele CVA 4066 coffee system. When I press on nothing happens. It seems like it does not receive the message that I want to turn on the machine. Nothing happens.
Check power is connected to machine and the internal power switch is on. If this has been done then its an internal power supply/ECU fault. Reagrds
Dec 25, 2016 | Miele Coffee Makers & Espresso Machines
I have a built-in. There is no water coming out. Could it be the brew unit itself?
About 428,000 results (0.82 seconds) Search Results
    [PDF]Operating and Installation Instructions Coffee System - Miele
    mieleusa.com/MieleMedia/.../Coffee%20Machines/CVA6405_Coffee%2...
    Preparing multiple cups of coffee, one directly after another (coffee pot) . . . . . . 23 .....safety requirement be met. If there is any doubt, have the electrical system of ...ventilation around the coffee machine. .... nDrip tray with no-spill grid .... and out. ? Remove the lid and fill the container with fresh, cold tap water to the. "Max.
    [PDF]Operating And Installation Instructions - Miele
    www.mieleusa.com/manuals_pdf/Residential/Coffee.../CVA615_us.pdf
    Read all instructions before installation or use of the coffee system. ... there is any doubt, have the electrical system of ... The appliance must be built into cabinetry before operation to ensure that no electrical components ... towards your body or use this machine ..... Lift the water tank up and out of the ..... nothing comes out.
    Miele Products: Coffee Machines
    www.mieleusa.com/Product/List/21?filterByType=false
    24" CVA 2662 Built-In Nespresso Coffee Machine. Add to Compare Details ... 24" CVA 4066 ss Built-In Coffee Machine, with Plumbed-In Water Connection.
    Miele CVA4066SS 24 Built-in Whole Coffee Bean System ...
    www.amazon.com/Miele...Built...In.../B0025TLW6A
    Amazon.com, Inc.
Feb 08, 2016 | Miele Coffee Makers & Espresso Machines
Water isn't getting into the brew unit
Can you please clarify the problem. Are you saying that coffee no longer comes out the spouts ?
Jun 13, 2015 | Miele CVA 4066 Stainless Steel
Coffee makers Miele cva 4066 stuck on fit jets in central spout
You might need to reset the coffee maker by turning it off and then turn it on again.
Apr 28, 2015 | Miele Coffee Makers & Espresso Machines
My miele coffee maker CVA 4070 dispensing tubes are clogged
I had this problem ... you need to remove the dispenser from the rear of the door. Then once removed clean in running water. Its a sealed unit but you can squirt high pressure water inside to dislodge the coffee sludge. When clean .. fill with water and make sure the 2 spouts drain evenly. regards
Jul 09, 2014 | Miele CVA4070 Coffee Maker
My cva 4066 will not make coffee, I descalled it, that function worked fine,all it does is make the grounds a little wet and the rest of the water goes in the drip tray. Can you help me?
Have you Cleaned the Brew unit? The descale Tablets are to clean and descale the internal plumbing - the cleaning tablets are to remove the oils from the brew unit. If clogged the water will not flow through , instead it will dump into the drip tray.
May 11, 2014 | Miele Coffee Makers & Espresso Machines
Only one spout dispenses coffee
Same for my CVA 5060 : the right spout seems to be blocked...
I tried a cleaning cycle and a descaling one with no success.
Any idea of where to clean ?
Apr 13, 2014 | Miele Coffee System
My machine says " fix
It says fit jets in central spout, not fix. The stainless steel cover over where the coffee comes out sits on top of the central jets. pull the dispenser down as far as it will go. Now pull it straight out to you. reach up and grab the black plastic piece that holds the central jets. pull it straight down. Now fit the central jet housing into the stainless steel cover. put the cover back on and push it firmly up into place. if it still says fit central jets, pull the stainless steel cover down and slam it up a little harder. there is a switch up inside that needs to feel the presence of the central jets so it doesnt spray coffee and milk everywhere. You should be cleaning those jets every 24 hours anyway. Get the manual out and go through the maintenance proceedures. that milk will start to turn into green cheese if you dont clean the jets and pipework every night.
Jul 14, 2011 | Miele Coffee System
I have a three month old Miele CVA 4066. I have recently cleaned the unit twice (using little tablets in coffee grinder), as well as descled. The coffee, expresso, etc. is barely dripping out of the unit. ...
Feb 10, 2011 | Miele CVA 4066 Stainless Steel
Getting error message "fit jets in central spout"
You need to pull down the metal thingy in the middle where the coffee comes out of (the thing that goes up and down to accommodate different cup sizes). Pull off the front plate, then put it back on and make sure it slides all the way up. The message goes away.
ML Spider
Sep 11, 2010 | Miele Coffee System
Miele CVA 4066 Stainless Steel Logo
24 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
