Question about Toys
MY CITROEN BERLINGO HAS REAL TROUBLE STARTING I HAVE RENEWED GLOW PLUGS AND HAD INJECTORS OVERHAULED
    New Friend:
    Problem Solver:
  • 9 Answers
If you check the starter as it is a common problem but if it turns fast enough then check compression.
Posted on Nov 19, 2013
Market value 1983 citroen berlingo 2 door van. Manual
The Citroen Berlingo is produced by the PSA Peugeot Citroen alliance since 1996. So in 1986 it would be C15, not Berlingo.
Aug 07, 2015 | Citroen Cars & Trucks
Citroen Berlingo 1.9d. 2002. Fitted with DELPHI injector pump. Timing of cam belt & flywheel is by locking
I have been doing research on the Delphi pump and it apparently is associated with lucas/cav and as such is timed by the use of a dial test indicator that, through the use of a plunger and cam, runs on the cam block in the pump and determines when injection begins. Initial timing is to set the flywheel on the injection timing mark and the pump flange mark set on the timing case mark. To get it exact I would recommend that you have a diesel pump shop do the timing using the correct tools. As the pump is not electronic as such (from my research into Delphi ) it is basically a manual injector with a electronic controlled governor. Any way the best advice is to have a pump expert set the timing.
Jan 05, 2014 | 2004 Citroen Berlingo 1.9
Citroen relay van 2.0L HDI
Have a load test done on the battery as the glo-plugs should get very hot very quickly. Diesel engines have to have a high rpm crank speed or they will not start and will leave unburnt fuel in the cylinders ( wet glo- plugs). Every indication is that the battery is flat or is not the right capacity for the car.
Dec 01, 2013 | Citroen Cars & Trucks
I have a berlingo van with DW8 1.9 it starts and runs well but if iturn it off and try andstart it while it is wrm it will run realy rough if i leav it to cool right down it will run well.
H, first time using web related help but i have a problem withh a citroen dispatch 1.9 dw8 non- turbo, i have just changed water pump, timing belt, tensioner and idler pully, two injector seals, advanced solenoid actuator diesel valve on the bottom of the injector pump.
problem is now that i start the vehicle it runs very rough like a misfire or running on just 3 cylinders.
but when i unplug the advanced solenoid actuator diesel vale the engine the engine idles better but just louder and slightly higher rpm
any ideas pldase
Apr 02, 2013 | 1989 Peugeot 405
How to set timing on a citroen berlingo 1.9 diesel
How to set timing on a citroen berlingo 1.9 dieselThat's the question....butwhere's the answer? Diesel pump positioning? (Done Cam & Flywheel locked.....)
Aug 26, 2012 | 2006 Citroen Berlingo 1.9d
How to set timing up on 1.6 Hdi engine without reluctor after cambelt snapped
please state year and model of this engine as they do change ,i think its a citreon something like a berlingo or maybe a 306 or whatever but need the year as the common rail is different to the injector pump model or is it a dreaded my favourite motor and thats a renault
Feb 29, 2012 | Citroen Cars & Trucks
Hi just pick up a citroen berlingo van 2003/4
you dont need a tool mate just finger and thumb pressure
i have have been working on peugeots for 12 years and never needed to use one of them tools
Nov 22, 2009 | Peugeot 405 Cars & Trucks
Citreon berlingo 1999 diesel 1.9l need new spark plugs
You will need some decent spanners, the nuts are 8mm on the wiring and some will need a 1/4 drive socket, some a small spanner, get decent glow plugs, maybe citroen ones, there are som unreliable ones out there, even the Bosch ones sold by factors are not as good as factory! the plugs themselves are usually13mm and tight. You may have to take some air filter or emission stuff off but not the fuel injection pipes, leave them alone!
Dec 04, 2008 | Bburago Citroen C6 Diecast Model
Toys Logo
57 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
