Question about GE JASRM24912 Remote Control
Need manual for sanyo hdtv receiver dP657 - GE JASRM24912 Remote Control
HOW DO I PROGRAM THE GE 24922 UNIVERSAL REMOTE TO THE SANYO 42" TV?
The manual you received with universal has clear instructions on what to do. Read it.
And if you have lost it, go to manufacturer of remote web site for a manual download.
Mar 05, 2016 | Sanyo DP42849 42 in. HDTV
Need a users manual sanyo dp19649
Typed "sanyo dp19649 manual" into Google, this is what came up on the first result:
http://us.sanyo.com/LCD-Televisions/720p-18-5-LCD-HDTV
below the picture of the TV there are 3 tabs, you want the "downloads" tab. There you can download the Owner's Manual in PDF format.
Apr 03, 2011 | Televison & Video
Help! My not so electronically inclined husband has a Sanyo stereo system (came with the marriage, the manual did not)..we just bought a HD Vizio, I want to hook it up to the Sanyo, but no manual and he...
I personally do not follow the route-everything-through-the-receiver model. Sound - ABSOLUTELY; Video? Nah.
Is the Sanyo a SOURCE of sound? More likely it's just the light show at the end of the Cable Box, which IS a source of high-end audio. Treat it as any digital source like a CD player for audio.
The Sanyo NEEDS a basic video output to the TV so you can use the Sanyo's menus. The Vizio NEEDS basic audio from the Cable Box (for watching news and other lo-fi content); and the absolute BEST video from everything.
As far as manuals for the Sanyo go, a model number would help.
Maybe run it by the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usersmanualguide.com
Mar 30, 2011 | Audio Players & Recorders
Need user manual for sanyo SAP C95AH5
The sanyo service center has stopped the manual for this model.But there is one on-line site dealing with the service manual.You will have to place an order for the service manual on this site and you will receive the manual. This is the direct link for the online site dealing with the service manual of your sanyo product. just click on the link below:-- http://www.nodevice.com/manual/sanyo/sap-c95ah5-szip/get74707.html To receive the service manual you will have to register on this site and place the order.Registration will hardly take any time. ------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 17, 2010 | Heating & Cooling
I need to hook up to digital cable
Connect the cable to your TV's antenna input jack. Through the TV setup menu, perform a digital cable search. This is a separate operation from the full channel scan. The TV manual says this may take up to 10 minutes, so be patient. The set should find the channels on your system. When you want to watch TV, press the INPUT button on your remote to select Digital RF as the source. Press INPUT again to select any other source (DVD, etc.) you have connected when you want to watch that.
I was wrong about needing a converter. This TV has a tuner that can pick up the cable channels if they use a system called QAM. Verizon says QAM-capable sets don't need a box for non-scrambled or premium channel, so you should be good once you have the TV scan channels.
I couldn't find the DP26648 manual at Sanyo's site, so my solution is based on the DP26647 manual. They should be similar. You can download the manual here if you don't have the manual for your set.
Apr 01, 2009 | Sanyo DP26648-R 26 in. LCD TV
Digital Television
You will need to use a converter box if you want to receive digital signals from an antenna as the tuner is not the ASTC (HDTV) type. Once you get a converter or cable box you can come out of it with component video cables and go into one of the inputs in the back of the set.
Feb 26, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
GE JASRM24912 Remote Control Logo
23 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
