Question about Samsung CLP620ND - CLP-620ND Color Laser Printer
Printing double and blurred - Samsung CLP620ND - CLP-620ND Color Laser Printer
Our printer will not print It is like the computer and printer do not connect
go check on the control panel. Double click the Printer & Faxes icon. See if the your printer icon is on the list. Verify that the icon image is clear and not blurred. If blurred then usb/port connection is not established. If image is clear, then its is connected properly.
If image is clear, double click on it.
Printer window will appear. On top of it click the Printer menu then scroll down. Leave uncheck the Use Printer Offline. Click OK and close window.
Feb 08, 2011 | Dell P703w Printer
Printer is offline and will not print. Restarting does not help.
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 10, 2010 | Office Equipment & Supplies
I have a cannon inkjet mp560. when ever I try to print it says "printer is offline" or "printer is not responding. I've tried unplugging the usb cord and turned it off and restarted it, but it will not...
I have a Canon Pixma MX330 color printer. It gets used only occasionally, usually to print brochures and the like. I recently switched it to copy mode by pressing the "copy" button on the front; now it...
Aug 05, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
When printing it comes out all double writing
have you tried printing on a different TYPE of paper? I have found if you use the same paper as your printer you get much better results.
Also sounds like you are low on Magenta. the double writing sounds like you need to clean the rollers with a Qtip and a small amount if alcohol. good luck
Aug 14, 2009 | Office Equipment & Supplies
Double vision
If you are printing color and you have color blurring like streaks. it mean the registration of the colors are off. Usually using the internal cleaning function from the panel will clear this up. You should restart the copier as well. If it continues check all the feed rollers.
Feb 12, 2009 | Canon imageRUNNER C3220 Color Copier
Phaser 8560 blurr
There is an encoder on teh drum motor that picks up lubricant from the maintenance kit and causes those blurs. It eneeds cleaned or replaced
Jul 11, 2008 | Xerox Office Equipment & Supplies
Blurred print
what ink cartridges are you using, what does the nozzle check look like?
May 23, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Samsung CLP620ND - CLP-620ND Color Laser Printer Logo
27 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
