RUUD UBHC-21J11SFC: Where do you change the air filter?
  • 20 Answers
SOURCE: Wiring Diagram
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Posted on Jul 23, 2008
  • 4 Answers
SOURCE: How do I change the filter in my Ruud Achiever series
I'd look in one of 2 areas.
1. often there is a central return in the house. This is the place where the air gets pulled back to the unit and is likely very close to your thermostat. Check for a filtered louvered grill there and see if your filter is located here. If so, you can access the filter by opening the filter frame with a screwdriver or even a coin.
2. Otherwise I would expect that your filter is on the return-air side of your air handler (where the blower is) Older models have the filter actually inside the air handler in the blower compartment. Newer models may have a small separate filter door. I'd look in these areas.
hope this helps
ghoff
Posted on Mar 21, 2009
  • 233 Answers
SOURCE: RUUD UBHC-17J14SFA HEATING PROBLEM
you may have airflow issues, verify the inlet and outlet temps with the unit running on start up, if the unit exceeds the "rise" allowable then the safety devices "overtemp" will take the firing circuit off line until it cools down. The acceptable mfg. rise is listed on the nameplate inside the burner chamber, (generally on the side wall)
Posted on Jul 20, 2009
pilungu
  • 30 Answers
SOURCE: Air Conditioner (RUUD model: UBHC-14J06NFD) is
1) you probably have a clogged drain line and
2) your air handler coil may be dirt.
Solutions:
1) Using a dry/wet vacuum cleaner, attach it to the drain line outside and **** all the gunk out of a drain line; or using a water hose, attach it to from inside right by the air handler and push the gunk out with the force of water - be careful using this method. Or simply pour draino into the air handler pan, wait for 10 minutes and using a cup pour water in the pan to see if it drains fine.
2) if the coil is dirt and it ices up, call a technician to for coil cleaning.
Posted on Oct 12, 2009
  • 5125 Answers
SOURCE: My system uses a permenant
The Ruud UBHC-21J18SHG has a nominally 21" cabinet width. So the needed filter is 19.75" x 21" x 0.375" (502 mm x 533 mm x 9.525 mm). The Ruud part number for the filter is 54-23217-03 .
The specifications sheet for the Ruud UBHC series air handlers is available here: http://www.coburns.com/images/PDFs/h22-517rev1.pdf . The filter size information is on page 3 and page 12.
I've found the filter at one online vendor: http://www.patriot-supply.com/products/showitem.cfm/RHEEM_68_101807_03 . (This is a common filter that fits several manufacturer's air handlers.)
I hope this helps.
Posted on Sep 11, 2011
My system uses a permenant air filter. It's missing. It's a Ruud Model UBHC-14J11SFA. What size replacement filter can I put in this system?
You can measure what size and use any after market permanent filter. Measure the opening to the rear and across the opening. Should read as ?x?
Dec 03, 2014 | Ruud Heating & Cooling
Where is the filter in ruud model UBHC-21J11NFC
It depends upon configuration- or how it was installed.
In general terms, wherever the air from the structure is being drawn into the cabinet for air recirculation/intake- the filter will be in the vicinity of the ducting connecting to the Ruud heat pump/AC.. It will be before the "A coil" assembly (the copper tubbing with fins roughly the shape of an "A".
This assumes it was installed correctly. If not, the A Coil will collect a thick layer of dust on the side facing the incoming air flow.
The relevent Ruud documentation is here:
http://www.ruudac.org.ua/ubhc02.pdf
If there is any doubt about the integrity of the installation, contact an HVAC contractor familiar with your area to inspect and make corrections if needed.
Apr 11, 2012 | Ruud UBHC Air Conditioner
Need to know the tonage
Hi You have a 4-ton unit or 48,000 btu per hour cooling
Nov 08, 2011 | Ruud UBHC Air Conditioner
My system uses a permenant air filter. It's missing. It's a Ruud Model UBHC-21J18SHG. What size filter should I put in this system?
I hope this helps.
Sep 10, 2011 | Ruud UBHC Air Conditioner
My son has a Rudd air conditioner Model UBHC-17J11. Where is the filter located?
If you pull the bottom door off, or where the blower motor is, the filter should be with
sight.
Aug 28, 2011 | Ruud UBHC Air Conditioner
Where is the drain pipe on my a/c? Ruud #UBHC-21J11SFC. Do I have to take something apart? The pan under unit fills up and overflows. It is leaking through the ceiling under the unit. I am a woman. ...
The drain or drain piping (usually PVC piping) is under or on the edge of the drain pan, under the unit. It has to exit outside some where. Either down thru the wall into the crawl space and out thru the foundation wall. Or thru the attic to a gutter outside on the edge of the soffett. Look for white PVC piping outside the house where I indicated. Then you can use a garden hose and high pressure to unclog it from at it's termination point, by back flushing it.
Hope this helps you. Please let me know. Thanks
Jun 19, 2011 | Ruud UBHC Air Conditioner
What size filter do I need for a Ruud model UBHC-17J07SFE?
Hello You will have to measure the old one for the size.If it is in the unit itself I think it's 20X25X1"
Aug 31, 2010 | Ruud UBHC Air Conditioner
What air filter size fits a Ruud model UBHC Series?
well go to the forced air unite and open up the fan compartment and measure the size. or find out the air returns and there should be filter in there.
Jul 09, 2009 | Ruud UBHC Air Conditioner
hope this helps
ghoff
Feb 21, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
