Question about Starrett D125 Digitape 1Inch x 25 Electronic Tape Measure
The display is always on when I insert the battery- How do mI turn it off?
I installed a larger 3 volt battery and put a micro switch on the positive side.
Posted on Jun 13, 2016
When i power on 5030 then it directly goes to insert sim , i have always put a sim in it
If it displays insert sim then there may be problem with the middle pin of the battery connectors or with the sim tray...
Sep 20, 2011 | Nokia XpressRadio 5030 Cell Phone
Tip
How to correct sim card error / insert sim card Procedure to follow Step 1:...
Procedure to follow
Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it
Step 2: If the sim seater/tray is not broken, clean the entire terminal.
Step 3: If the sim seater/tray is not directly on the board, trace the broken led and solder it, or you replace the broken led with another sim tray.
Step 4: If it is still not working, change the battery and put a new battery, because a virus infected battery will always give such problem.
Step 5: Finally, if the problem still persist, then check the sim card and replace with another sim card if the former is bad because a bad sim card will always display such message as insert sim card or sim card error.
on Jan 19, 2010 | Cell Phones
Mi coper machis displays, Insert the key. but the key is inserted in to the machine.
The copier has a key hole on the right side of the copier. You need the key to allow you to use the copier. I've never had to try to by pass it. It's basicly just a switch... Good Luck with that one????
Sep 04, 2010 | Canon CLC 1120 Color Copier
Sim card promblem
Procedure to follow
Take care
May 07, 2010 | Pantech Slate Cell Phone
Insert Smartchip
Your smartchip is fried. You need to replace it and can get it from your carrier.
Sep 29, 2009 | LG Vu CU920 Cellular Phone
When the camera is off the display still shows the memory card info
It is meant to.
The D90 always shows this even when off.
It explains it on page 35 of my manual.
Camera Off Display
If the camera is turned off with a battery and memory card inserted, the number of exposures remaining will be displayed.
Jul 04, 2009 | Nikon D90 Digital Camera with 18-105mm...
I had d problem where mi dvd was unable 2 eject cuz it was locked, so i uplugged it den pluggd it bak n held d power button and it suddenli went off as i was holdin d button n now it doesnt wanna ***...
Normally when the VCR is plugged in, the display should blink. If not, it could be broken. Since I am not sure about this model, do an experiment. Unplug the unit. Wait for a few minutes. Plug it back in and insert a video cassette. If it powers up and the display turns on, VCR should be OK. The unit may be reset to factory default and the remote might be set to different code. The remote can be reset to factory setting by removing the battery for a few minutes.
Feb 18, 2009 | JVC HR-XVC19S DVD Player/VCR
N70 Problem
Try a reset:
First turn it OFF, take the SIM card out.
Press * 3 send at the same time and turn power on. Keep them pressed untill the reset screen appears.
Give it time to work.
This might not work but it's worth a try.
I think your phone has been Black Listed.
It must have been reported stolen.
Jan 11, 2008 | Nokia N70 Cellular Phone
Nite Pix on Samsung SC-D353 ???
Did you try going to the menu and selecting auto? I have found that I need to remove the battery prior to doing any additional options. I think this camera is good but tricky.
Jun 14, 2006 | Samsung SC-D353 Mini DV Digital Camcorder
Starrett D125 Digitape 1Inch x 25 Electronic Tape Measure Logo
261 people viewed this question
Top Starrett Measuring Tools & Sensors Experts
ray gallant
Mark Schmit
Mark Schmit
Are you a Starrett Measuring Tool and Sensor Expert? Answer questions, earn points and help others
