Question about E-Machines eMachines Desktop PC
Will not boot windows - E-Machines eMachines Desktop PC
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Tip
Windows 7 will always boot to drive letter C: in multiboot configurations.
When configuring a Multi-boot configuration using Windows operating systems, you need to install Windows Versions oldest to newest on separate partitions. In doing so, Windows 7 is going to be installed to Drive D: or E: or such. In all previous versions of Windows, if you have a multi-boot configuration, the drive letter for that OS is always the same as the drive where it was installed.
Windows 7 does things a bit differently. EXAMPLE: I have 3 partitions on my hard drive. C:, D: and E:. XP on C: Vista on D: Windows 7 on E: When I boot to XP, the boot drive letter is C: When I boot to Vista, the boot drive letter is D: (Simple) Well, I learned the hard way that when you boot to Windows 7 from a partition other than C:, it will show the boot drive as C: in Windows 7 (It swaps drive letters with the boot drive and C: transparently). When you boot to the other partitons, the drive letters are as they should be and the change is only effective while booted to the Windows 7 Partition.
on Dec 03, 2009 | Computers & Internet
Dual boot xp with windows 8
No solution now, Install Windows XP again on first partition, Make sure BOOT.INI, NTLDR, NTDETECT.COM in the same partition in which Windows XP is loaded. Then install WIndows 8.
OR in the current scenario you've to do much technical work using third-party tools.
Feb 27, 2014 | Microsoft Windows XP Professional With...
Install windows 95 from floppy
Microsoft Windows 95 employs the use of a bootable floppy disk to begin the installation of the Windows 95 operating system or to troubleshoot problems with the system. Microsoft Windows 95 uses the MS-DOS system to boot the computer first and then loads the Windows 95 operating system onto the machine. Windows 95 Boot Disks may be created in one of two ways: The Startup disk may be created from within Windows or a boot disk may be created from a free downloaded boot disk image. After the boot disk is created the disk may be used to boot the computer and install or troubleshoot Windows 95.
Click "Start" and then click "Settings" in Windows 95. Click the "Control Panel" option. Click "Add and Remove Programs." Click "Startup Disk" and then click "Create." Insert the blank floppy disk into the disk drive. Click "OK." The operating system will create the Windows 95 boot disk. Click "OK" when the disk is finished. Create the Windows 95 Boot Disk using Downloaded Boot Disk Image Open a Web browser and navigate to the boot disk image site (See "Below"). http://www.bootdisk.com/bootdisk.htm Download the Windows 95 boot disk image and save the .EXE file to the desktop. Click the .EXE file to unzip the enclosed files. The formatting application will start. Insert the blank floppy disk into the disk drive and click "OK." The Windows 95 boot image will be created on the blank floppy disk. Use the Windows 95 Boot Disk Insert the Windows 95 boot up disk into the computer's floppy disk drive. Power the computer down by clicking "Start" and then clicking "Shutdown." Power on the computer with the Windows 95 boot disk in the floppy disk drive. The computer will boot up into MS-DOS to enable installation or troubleshooting of Windows 95.
Feb 13, 2013 | Dell OptiPlex GX270 PC Desktop
I have 2 HDD's in my PC - both with Win XP Prop
Boot.ini is correct, but looks default is booting from Disk2 and partition 1 which is your G:\ 500 GB.
Try Copying boot.ini from c:\boot.ini to g:\boot.ini It might help
In your example I see missing "\" after partition(1), may be typing mistake, but in real time can generate error.
You boot.ini looks exactly same in both drive c:\ & G:\
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(2)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="GUY DRIVE XP Professional" /noexecute=optin /fastdetect
Note: boot.ini will be hidden and readonly file. You need to unhide the file and remote the read only option and then only you will be able to save the boot.ini file
Hope this helps
May 22, 2010 | Microsoft Windows XP Professional SP2
What can i do to fix my volume boot on my laptop
Best answer I can think of if you have a version of Windows installed is boot from the CD and use the Windows repair utility, Boot from the CD and press F8 as it boots then select repair installation.
Nov 15, 2009 | Dell Latitude D600 Notebook
Windows doesnt start
you need to restore your boot system by booting from windows installation disk.
whenyou boot fron CD and ask for repair , select install windows
after you accept the disclaimer by pressing F8, installation will search for current windows installation
after the search select RESTORE
Mar 20, 2009 | HP Pavilion Media Center M9402f PC PC...
Hello, I have 2 Operating Systems in a computer namely Windows XP(SP3) in C:\ & Windows Server 2003 in D:\ . I've deleted the file BOOT.INI accidentaly form X:\ drive(X:\ means all drives like...
That's not a virus. Boot.ini is a default file needed for Windows OS to boot.
Fortunately, you can recreate the boot.ini files
This is a sample of the above Boot.ini file with a previous installation of Windows 2000 on a separate partition. [boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows XP Professional" /fastdetect
multi(0)disk(0)rdisk(0)partition(2)\WINNT="Windows 2000 Professional" /fastdetect
Simple way to add operating system on a separate partition:
At the command prompt, type: bootcfg /copy /d Operating System Description /ID# Where Operating System Description is a text description (e.g. Windows XP Home Edition), and where # specifies the boot entry ID in the operating systems section of the BOOT.INI file from which the copy has to be made.
Dec 28, 2008 | Microsoft Windows XP Professional
BOOT.INI deleted. How to re-create this file?
timeout=30
[operating systems]
Please rate this if you found this answer helpful. :)
E-Machines eMachines Desktop PC Logo
12 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
