Question about Bosch Dishwashers
C6 on a bosch dishwasher
Will not wash cycles
SOURCE: Bosch Dishwasher SGS5302 AU/12
The machine starts and enters wash cycle but will not move on from there and continues washing
Posted on Jul 13, 2008
ginko
  • 19396 Answers
SOURCE: my bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Posted on Feb 07, 2009
here2helpBSH
  • 27 Answers
SOURCE: Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Posted on Mar 19, 2009
SOURCE: my bosch dishwasher whistles when on washing cycle
it is your wash pump
Posted on Apr 16, 2009
Macmarkus
  • 2605 Answers
SOURCE: After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
Posted on Jul 13, 2010
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch she45 dishwasher code c6
Fan -Related Problem code c6 Means the Fan Rotation to too low Durning Operation
Jul 09, 2012 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
Feb 26, 2012 | Bosch Dishwashers
Jul 13, 2010 | Bosch 24 in. SHV4303 Built-in Dishwasher
Rinse agent cycle
Visit Bosch web site and get a user manual. Or tray the authorized service center
May 02, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
Replace cover on Bosch Dish washer> Now a C6 code is displayed in the window
I had the same problem after replacing the white panel on my Bosch SHE45M02UC with a stainless panel. I got the C6 error code. I called Bosch customer service twice and neither rep was helpful. One guy told me he didn't know what the C6 code meant. He suggested that I call a local appliance repair guy and he would know what the code meant. I replied, you mean to tell me you work for the manufacturer of the dishwasher and don't know what the error code stands for but a local repair guy that doesn't work for Bosch does?
After all this frustration, I took the panels off and tested the dishwasher with no buttons. It worked fine! Turns out, each identical button isn't identical. Each one is labeled A-G. After putting it back together, no more C6 code! On a side note, try reseting the dishwasher. With the dishwasher on and door closed, hold down the cancel/reset buttons for 5 seconds and release. The disher should drain and reset.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My bosch exxcel dishwasher will not drain after wash cycle
May 26, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwashers Logo
13 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
