Question about Vtech Remote Racer Smart Car
Gear teeth missing
Not moving
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 148 Answers
Sorry about your problem but you may need to replace that broken gear to fix your toy , or find a way to build up on that broken gear back to the way it was before, hardening epoxy may do the job, just use a small amount to build up on missing gear tooth then file away to achieve original gear shape and size.
Posted on Dec 28, 2013
I got a 1998 nissan maxima se 3.0L wont start ive put new starter, solenoid, relays, and ignition sw.I used to jump solenoid now dont work just starter spins never engaging help
If the starter is working probably and is mounted correctly then you need to look at the flywheel. Sounds like teeth may be missing. The gear on the starter should move forward and turn. The forward motion allows the teeth on the starter gear to connect with the teeth on the flywheel.
Jul 18, 2016 | Nissan Cars & Trucks
Runs but doesn't take paper in and shred
IF the cutters aren't moving, then it's probably a broken/stripped gear or a gear with missing teeth.
Look inside the slot where you would place the paper and see if the cutters are moving. If they are not moving, then it will have to be taken apart to find out why. (Probably a gear problem.)
Good luck
Mar 12, 2015 | Office Equipment & Supplies
Yamaha ttr 125 kickstarter won't grab
sounds like the gears inside are stripped or missing teeth open up the side case and check and replace any gears missing teeth or stripped
Jun 26, 2012 | 2005 Yamaha TT-R 125 L
Third row seat won't move.motor can be heard but no movement
bad gear,,,either gear pinned or key'd to motor shaft has sheared-off,,or gear missing teeth,,check both and replace gear on attachment to motor shaft.
Jan 29, 2011 | 2005 Ford Explorer
Blades not moving on ss24 weedeater
I just disassembled a SS24 hedge trimmer that had the same problem of the blades not moving. The problem is that there are 2 or 3 teeth on the helical gear that are missing. Consequently, the small gear on the motor shaft cannot continuously engage the gear that moves the blades back and forth.
May 27, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Makes noise blades don't move
you have some teeth missing off of one of the gears, most likely the dual gear thats driven by the motor.
razors
Apr 23, 2010 | Fellowes 220C-2 Shredder
Paper red light is on
Check your printer with expert/proffessionals to replace the gear/roller. Contact nearest service center to replace the same.
Revert back for more assistance.
Jan 13, 2010 | Brother HL-2040 Laser Printer
The car will not move when engaged to Reverse. Transmission oil changed yet it will not move after first move. No DTC.
need a new transmission.... your rear gears are missing teeth mine did the same thing.... i have a 92
Aug 11, 2009 | Toyota Camry Cars & Trucks
Ford 8N has a broken tooth/teeth on ring gear. How
Hi..my name is Keith..and i restore 9N's,2N's and 8N's....and to replace the ring gear..you split it there at the back of the engine..and its kind of a big job..so i would check the starter 1st..to make sure its not a starter problem..i hope this helps..if not please write back..i love tractor problems
Jul 09, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Reverse gear
it could be that reverse gear has been partially stripped. when we talk gears we are literally talking of mechanical gears. sometimes teeth break off from normal wear and tear, after so many break off the gear has trouble engaging. you will either have to have the transmission rebuilt or have new one installed, hope its under warranty this kind of work can be costly. Most likely this is the problem. If your car is standard transmission it could be your clutch is having trouble engaging, but this would also affect forward gears so it is most likely your reverse gear is missing teeth
Aug 03, 2008 | 2004 Kia Sedona
Vtech Remote Racer Smart Car Logo
Top Vtech Toys Experts
relojmesa
cloudranger
Level 1 Expert
Are you a Vtech Toy Expert? Answer questions, earn points and help others
