Question about 2008-2013 Dodge Grand Caravan Designer Auto Mat Floor Mats DM-DD-350-1031 - Carpet
Uconnect 430n Will not pairing with my cell phone LG
When you press the phone key do you hear the instruction
Posted on Apr 22, 2014
Want to repair Toyota cavalier trunk key barrel 1999
Posted on Nov 24, 2013
Why won't uconnect work in 2013 chrysler200
There are a few things to note. The pairing has to occur between the Uconnect device in the Chrysler 200 and the Samsung S3 using bluetooth. I noticed there are 4 possible Uconnect systems available. Depending on which one you have you can check the recommended cell phone to go with it. Samsung S4 is defnitely compatible to all of the of them and SIII also with some. But that does not mean SIII will not work with others. It just means it may not have been tested.
Go to this link and select the vehicle model and year and then follow the instructions to get to the correct pairing instruction. If SIII is not listed I would still check S4. Should not be much different.
Chrysler Uconnect
Aug 07, 2014 | Chrysler Cars & Trucks
I have a Samsung SGH-c417 cellphone and a 2011 Jeep Grand Cherokee Laredo with Uconnect. What is the pin number to pair the bluetooth with the UConnect?
If your UConnect system is Mopar's, the passkey is hardcoded to '0000' (four zeros). Nevertheless, if it is factory mounted (i.e. the one which comes mounted in the internal mirror), you will be prompted to choose any four-digit number you can think of (e.g. the same '0000'), provided that you enter that same number on your phone when pairing them with each other.
For further instructions, please, take a look at this page, select your car's year and model, click on the 'OWNER SUPPORT' tab and select the UConnect system present in your car.
Hope you are able to sort your problems out soon.
Regards, Carlos
Nov 07, 2010 | Samsung Cell Phones
Need set-up Information for Blue Tooth phone in Chrysler Pacifia 2005
I found the link below containing a download of the .pdf file and also pasted the phone pairing portion below it. These instructions are exactly the same as when pairing to my system in my '08 Caliber,so they're probably universal. Keep in mind, though, that the system just may not be fully compatible with your phone. EVERYTHING that Chrysler makes is EXTREMELY finicky-and you may be doing everything right! Before you begin, set your phone into its pairing or "find me" mode, then press the UConnect button. I hope this helps! Good luck.
http://dcxtraining1.com/dcxtraining1/docs/ExperienceFreedom_UConnect.pdf
Linking to UConnect – Required for First-time Use of Each Mobile Phone
To complete the pairing process, the mobile-phone owner’s manual will need to be referenced. One of the following vehicle-specific Web sites will also provide detailed instructions for pairing with the phone: www.chrysler.com/uconnect, www.dodge.com/uconnect and www.jeep.com/uconnect.
• Press the Phone icon button to begin
• After the Ready prompt and subsequent beep, say Set Up Phone Pairing
• When prompted, after the voice or beep, say Pair a Phone
• You will be asked to say a four-digit PIN that will be needed later to enter into your mobile phone. You can use any four-digit PIN. You will not need to remember the PIN after the initial pairing process
• For identification purposes, you will be prompted to give the UConnect system a name for your mobile phone. Each mobile phone that is being paired should be given a unique phone name
• You then will be asked to give your mobile phone a priority level between one and seven, one being highest priority. The priority allows the UConnect system to know which mobile phone to use if multiple mobile phones are in the vehicle at the same time
Making a Phone Call
• After the Ready prompt, say Dial
• The system will prompt you to say the number you wish to dial
Making a Phone Call Using Your UConnect Phonebook
• After the Ready prompt, say Call followed by the name and designation of a phonebook entry you wish to dial – for example Call, then John Doe, then Work
Terminating a Phone Call
To end a call in progress, press the Phone icon button. All calls in progress will
be terminated.
Phone Redial
• After the Ready prompt, say Redial
• The UConnect system will call the last number that was dialed on your mobile phone. This may not be the last number dialed by the UConnect system
Answering or Rejecting an Incoming Call - No Call Currently in Progress
When you receive a call on your mobile phone, the UConnect system will interrupt the stereo audio to ask if you would like to answer the call. Press the Phone icon button to answer the call. To reject the call, press the Phone icon button until you hear a single beep indicating that the incoming call was rejected.
UCONNECT
CHRYSLER GROUP TECHNOLOGY 17
Dec 29, 2009 | 2005 Chrysler Pacifica
My 2006 Jeep Grand Cherokee uconnect will provide prompts-voice or otherwise so I cannot connect my compatible Samsung Phone. My phone shows Uconnect on screen but when I do search on my phone it fails to...
check jeep.com/uconnect just to make sure the model is ok. Sometime your cell phone provider can update the software to make it work better with the device.
Oct 28, 2009 | 2006 Jeep Grand Cherokee
Uconnect auto pairing
Check with jeep.com/uconnect to make sure it is compatible. The phone is the problem 9 time out of 10. The cell phone provider can upgrade the software to make it compatible with the uconnect.
Oct 24, 2009 | 2006 Jeep Commander
Samsung sch-s870 not pairing with uconnect on my cell
same phone same problem, possibly software update might help
Feb 01, 2008 | Samsung SCH-a870 Cellular Phone
2008-2013 Dodge Grand Caravan Designer Auto Mat Floor Mats DM-DD-350-1031 - Carpet Logo
153 people viewed this question
Top Intro-Tech Automotive Vehicle Parts & Accessories Experts
David Harrelson
David Harrelson
Lawrence Oravetz
Timllfixit
Are you an Intro-Tech Automotive Vehicle Part and Accessory Expert? Answer questions, earn points and help others
