Question about LaCie Electron III 22" CRT Monitor
I have a Samsung 27" sync master and when playing games and high usage the monitor shuts off thme comes back on
I was thinking it was the video driver but I have installed an older version and the problem remains. I also have my 40" LG TV hooked up to the same video card and the issue is only happening with the Samsung
How to hook up a tablet to a tv?
It would go into the RGB input port.
Jul 07, 2017 | LG Televison & Video
How do I hook-up Netflix through a Sony Blu-Ray player and a LG television
If your Sony Blu-Ray player and LG TV are recent models, each should have an HDMI cable connection. HDMI is an method to connect your digital video and audio devices with just a single combined cable. In the case of your LG TV, using an HDMI cable will allow you to send the HD video signal to your TV's screen, and allow you to hear the sound through the TV's speakers.
Your LG TV may have multiple HDMI connectors, to allow other devices to send signals to your TV, such as a cable box or satellite box or digital video recorder (DVR). Your Sony Blu-Ray player will usually have just a single HDMI connector.
Purchase an HDMI cable from your local electronics store. There are different versions of the HDMI specification, and you should get a cable that you can verify is certified for the HDMI version 1.4 specification.
Plug one end of the HDMI cable into the Blu-Ray player, and the other end into one of the HDMI connectors on the TV, noting which one you selected.
When you turn on your Sony Blu-Ray and your LG TV, you should use the remote for the LG TV to select the input source. Your LG remote should allow you to select the HDMI input connector you used, at which point you should see the display of a DVD playing on the Blu-Ray player. If you cannot hear the sound, use the LG remote to increase the TV volume.
Mar 02, 2015 | Netflix
Can't get the words for the songs to show on the TV screen
Check whether the output taken from from the Vocopro is from video/audio out. By mistake, if you had connected the RCA cable to the 'input', you won't get any audio or video and also stand a chance to damage both the devices, as video in/out is a very sensitive line.
Aug 05, 2012 | Televison & Video
I am having trouble with my skype video. When I make a call I can see and hear them, but my party cannot see me. I have a logetic webcam250. Please help!!!!!
You should install the drivers before you try to operate the webcam, unless the instructions state otherwise. If the drivers are not installed, unplug the webcam and install the drivers, and plug the web cam back in when promoted. If you have the drivers installed already, or can confirm the web cam works, open up skype and navigate to tools then options. Once in the options menu go to the video settings tab. In the "select webcam" drop down menu select the webcam of your choice.
It's also possible you are using an older version of skype that my not support new protocols for video, OR it's possible you are using a new version of skype which doesn't automatically start video. If you are using an older version of skype (current version is 5.1) update to the later version. If you have the latest version, you may need to manually start video chat. When you start a call, look towards the lower area of the screen for a button that says "My video" and click on it. This should start the video chat.
Hope this was of some use!
Mar 29, 2011 | Skype IM
Desktop compaq d51s, pentium 4 2.5/512/40 windows xp sp2 drivers. the graphics are actually very poor, only 4bit
This indicates the correct video driver was not installed and the generic VGA driver was installed.
You can download the drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
www.compaq.com/country/cpq_support.html
Jan 01, 2011 | HP Hewlett Packard Compaq D51S Intel...
Hi i have archos 705 new. hard drive keeps sticking when watching video
I have older version of this, lovely machines. you could try this: hook it up to a computer, move ALL the files that you have added (eg mp3, video, pictures, etc) off the machine and onto the computer. then hook up something like DiskWarrior or Defrag (depending if you are pc or mac) and let it sort the drive out. Then, copy back the stuff you want to remain on the archos, That should fix it.
Dec 30, 2009 | Music
No video output
for the ps3 i know why u are not gettin any video. make sure the ps3 is off with the red light showeing in the front then hold down the power button for (i think) 30 sec. u will see the light blink a bunch of times them you might have to re start it but it should show the vedeo againg
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
LG 22" TV with Geforce nVidia 5500 FX 256MB AGP card
Try getting a new video driver. Foreware = motherboard drivers and such, not video.
I saw this driver on Nvidia.com
http://www.nvidia.com/object/winxp_175.19_whql.html
Its the XP driver for those 5000 series FX cards like yours. Try installing that and checking out the Nvidia Panel after.
1680x1050 is an odd resolution for TV, that is what normal 22" monitors have but I guess it will do up to 1680x1050 only when hooked up to a PC.
Feb 21, 2009 | LG 26LX1D 26 in. LCD HDTV
LG KP220 PC SUITE?
Finally, after spending 2 days on this issue, I am now able to back up my phone book on LG KP220 to my PC!  Hurray!
I have now used the pc sync software on Windows Vista as well as Windows XP (SP3) without any issues.
For Windows XP (SP3): ----------------------------------
After installing the driver, all you need to do is make sure that USBSER.SYS file has the following specs:
Size: 22,768 bytes     Version: 5.0.2195.4858
The newer one (which has the following specs) does not work and needs to be replaced with the older one with above specs.
Size: 26,221 bytes      Version: 5.1.2600.5512
(yes, for some reason, the older version works and newer does not)
For windows vista: -------------------------- When you first connect the phone in COM mode, let vista download the driver from the internet.  Then run PC Sync and viola it'll work!
For both: ------------ For running as a USB flash drive (data mode), you don't need any driver in either o/s. For running as a COM port (phone mode), you need a driver and a software.  The driver I'm using is USBSER.SYS and the software is called "Phone Suite" by MediaTek.  I've also tried a slightly older version of the same software called "PC Sync Manager" and that also works.  Other software should also work, as long as the driver is working correctly!
If you still need any help, drop me a mail at amoizpatgmaildotcom (you know what to do with "at" and "dot")
Feb 02, 2009 | LG CU500 Cellular Phone
S-video dont work on latitude c600
there is a needed interface for the tv. the video signal your laptop generates is not compatible with the input circuits of the tv.
Dec 27, 2007 | Dell Latitude C600 Notebook
LaCie Electron III 22" CRT Monitor Logo
18 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
