Question about Invicta Mens White Dial Watch 6088
Watch works fine except gmt hand doesnt move - Invicta Mens White Dial Watch 6088
2 Suggested Answers
escapement
  • 2334 Answers
SOURCE: I have a gmt hand on my watch, how do i set this?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all INVICTA watch manuals.Rate me, please.
Posted on Mar 30, 2010
What is the extra hand on fi watch for
Extra hand is for GMT (Greenwich Mean Time).
Oct 17, 2014 | Jacques Lemans F1 Gmt Watch
Set reserve indicator on invicta 6106
Here is how to set the Invicta 6106 Invicta 6107 and other similar models with the ISASWISS 8173 movement with the following functions:
TIME - DATE - DAY - ALARM - GMT - POWER RESERVE
DO THINGS IN THIS ORDER AND YOU WILL FIND IT TO BE VERY EASY! After you understand how to set ALL the functions you can skip steps later to set individual functions but for now just do it exactly step by step:
1. Unscrew the center crown (if it is a screw down crown) and pull it all the way out (this is position 2) and turn it until you see the DAY sub-dial at the 6:00 position set to the day BEFORE today. There is no QUICK SET for the day on this movement so you must just keep turning the crown and hour hand past 12 midnight and watch the day pointer until it gets to the day you want - the day BEFORE today.
2. Now set the time to 6:00 (am or pm doesn't matter at this point). This is very important because you do not want the time to be between 9:00pm and 12:00pm when you set the date later on - we are using 6:00 just to be safe.
3. Push the crown all the way in - you don't have to screw it down.
4. Now pull out the crown very gently to the 1st position - just one "click" out. Now turn the crown AWAY from you to set the date to the date BEFORE today - this appears in the small window at the 4:00 position.
5. Now pull the crown all the way out again to position 2 and turn it away from you until it goes past 12 midnight and TODAY's DAY AND DATE are showing and then adjust the hour and minute hands to the current time - be sure to set the hour to AM or PM and push the crown all the way in. If you wish to set the seconds exactly - with the crown pushed in watch until the small seconds hand in the sub-dial at 2:00 is exactly at 60 and then pull the crown out to Position 2. Set the time ahead a minute or so and push the crown in when the actual time is the time you have set - you can set it to atomic clock time on the internet or by another watch that sets itself to atomic time.
6. Now the DAY, DATE and TIME are set to current. Now when the hour hand passes 12 at midnight tonight the DAY and DATE will advance correctly.
YOU CAN STOP HERE IF YOU WISH - but you can continue on to set the ALARM and the GMT indicators as follows:
7. To set the GMT hand (the one with the red-bordered pointer) the crown is pushed all the way in and screwed down. Now simply hold the bottom pusher in for a few seconds until you hear a beep - now you can start pushing it and watch the GMT hand moving - one push at a time for small adjustment or hold it down to make it move faster. When you stop pushing it another beep indicates that it is OUT of the setting mode - so if you want to adjust it again just hold it in until short beep and start pushing the lower pusher same as above.
Understanding GMT (or second time zone): Note that the GMT hand time is indicated on the 24 hour dial (think in military time where 3:00AM is 0300 and 3:00PM is 1500) using the very small numbers around the very outside of the dial. When the local time is 3:00PM if GMT is adjusted for the SAME TIME ZONE as you are in now the GMT HAND will be pointing at the small "15" which is between the 7:00 and 8:00 hour markers. If the local time is 3:00AM and the GMT is adjusted for the SAME TIME ZONE as you are in now the GMT HAND will be pointing at the small "3" between the 1:00 and 2:00 hour markers. So lets say you are in Pacific Time Zone and it is now 3:00pm local time and showing on the minute and hour hands - and for example you want the GMT hand to show Eastern (New York) time which is 6:00pm (in military time that is 1800 indicated by the very small 18 which aligns with 9:00) - hold in the bottom pusher until you hear a beep - now start pushing it in short increments or hold it down to move it faster until it points to small 18 (large 9). Now the GMT will indicate the hour in the EASTERN time zone while the main hour hand indicates your local time.
7. To set the ALARM - unscrew the crown and pull it to Position 1. Turn it TOWARDS you (if you turn it way from you will set the date which you don't want to do) and you will see the hand with the white pointer and the word "Alarm" in tiny writing on it move clockwise. Set the ALARM to the time you want. Push in the crown and screw it down.
8. To activate the ALARM push the TOP PUSHER once - the small hand in the POWER RESERVE sub-dial will move slightly and then it will move again (give it a second or so) and you will hear a BEEP - now the alarm is activated and the small hand points to the "ON" label. When the alarm sounds if you wish to stop it push the top pusher. But it will stop on its own and then repeat a few minutes later - you can just leave it alone if you wish. Note that the Alarm will turn OFF after sounding - so if you want to wake up for work on time tomorrow be sure the ALARM indicator is pointing to "ON".
9. To deactivate the ALARM when the small hand is pointing towards the "ON" label simply push the top pusher again and and the small hand will move clockwise down to the "OFF" label.
10. POWER RESERVE sub-dial. To align the Power Reserve sub-dial hand (after battery change) pull the crown out to Position 1 and push the top pusher until the hand points to 0%. Push the crown back in and screw it down.
11. Reserve Indicator - the instructions for this movement states that holding down the top pusher for 3 seconds will move the POWER RESERVE hand to the power reserve scale - but this is confusing because the hand never actually stays on the power reserve scale - it will only stay on "ON" or on "OFF".
However - I believe that this is the way it works. When you push the top pusher with the small hand in the "OFF" position it will momentarily move to the power reserve scale and stop for a second before it moves again to "ON" - I believe that this reading indicates the POWER RESERVE just before it moves again to the "ON" position..
Jan 03, 2012 | Invicta Reserve Watches
Invicta 0223 i see the hour hand , min. hand and sec. hand... what is the other hand for?
It is for GMT.
What is GMT? GMT is an absolute time reference & doesn't change with the seasons
Jul 30, 2011 | Invicta Pro Diver Sport Collection GMT...
I have an Invicta watch Model #6193. My question is does the second hand supposed to not move? And how does the power reserve work on this particular watch? My second hand doesnt move. I wondering is this...
As to the power reserve.....It's just there to give you an estimate of how much power is left in your battery. As far as your question about the second hand.....My guess is that you are looking at the hand for the GMT function (which stands for Greenwich MeanTime...Greenwich is a place in Great Britain where the prime time zone is located, but most people just use this function as a second time zone). Can you confirm or deny that my supposition is correct or not? (in regards to you thinking the GMT hand was the second hand?? Use clarification request if I am mistaken and when you explain again what you need answered, please also post whether or not the watch is keeping correct time or not. Thanks!! and Best of luck to you!
Jun 30, 2010 | Watches
How do i set the the 24 hour hand in a rolex 16758
Yours is the original GMT Master. The GMT Master II allows the GMT hand and the regular hour hand to be set differently but not on your older model. On yours, the regular hour hand the the GMT hand are fixed so that if the triangle on the rotating bezel is at the top, the GMT hand will indicate local time. To indicate time in a 2nd timezone, rotate the bezel to orient the time to the GMT hand. There's a copy of the original instructions posted at: http://www.rolexforums.com/showthread.php?t=45269
Apr 30, 2010 | Bulova Watch
How to set and use the subdial on my invicta model 5749 gmt watch
While I'm not familiar with that particular model, most GMT hands are set by turning the crown "backwards" in the date setting position. IOW, if you set the date by pulling the crown out to the first detent and turning it clockwise, turning it counter-clockwise will set the GMT indicator.
Apr 10, 2010 | Bulova Watch
Set 24 hr hand
first click changes the date if you turn one way, but turning thr other way should change the 24 hour hand.
Nov 30, 2009 | Watches
I just purchased an Invicta Sea Wizard Chronograph Watch, and after taking it out of the box I noticed the large second hand does not move. The watch seems to keep time, but the scond hand is frozen in...
The large second hand is actually the GMT hand for a second time zone. The second hand is the small sub dial at the 2 o'clock position. The large hand with the red arrow is the alarm time.
Nov 18, 2009 | Angel Invictas-More Styles - ELITE...
Problem with second hand
I need to know what type of oakley is this .. i mean what model .. because they have different specifications..
Dec 26, 2006 | Oakley GMT OAK0531 Wrist Watch
Invicta Mens White Dial Watch 6088 Logo
26 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
