Question about C3RS730 LCD
How to remote start with a manual transmission
How do i get the remote start to work with my manual transmission. ive installed the alarm and that works fine, the car wont remote start.
    Problem Solver:
  • 18 Answers
The alarm and the start remote have to be wire together, other wise will not work never ever, because the alarm should disarm the electrical system or the power to the car download the electrical car diagram in the internet. some times there is forums under the brand of your car and some one else already deal with these before and they can provide you the diagrams and all you need.
Posted on Nov 20, 2013
Manual transmission won't remote start even though Ive followed all the steps to leave it in reservation mode and car remains running until Ive exited and closed driver door. Error code is Sta
If your getting 7 flashes from a Compustar brain there is something not working right with the manual reservation mode. Double check to make sure it is 7. If it is then go see an authorized Compustar dealer and have them go over the installation and programming of the unit.
Nov 07, 2014 | 2-way Remote Transmitter - Dark Navy/gray
Car remote start
hi
you need to find the wiring diagram
bcz remote starts normally have 3-5 replays
however there are other types on the market that can be operated via the factory remote only
no alarm module required
maybe the manufacturer of the device can help
cheers
Nov 07, 2013 | Vehicle Parts & Accessories
Remote start/ 09 Camry installation
what brand is alarm? hood pin IS required,ground hood pin lead try to remote start
Jan 18, 2013 | Brand Remote Start/keyless/car Alarm Very...
Remote starting diagnostics says "Manual
A tach MUST be connected for manual transmission installation. Start there.
Jul 01, 2011 | 5301 Responder LE 2Way Remote Start and...
Should I intall a Viper 5701 remote start on a manual transmission Mustang?
Honestly, you would be taking a risk. You have to remember that if you do, you will always need to keep the car out of gear in order to start the vehicle. You will also need to install an extra relay in order to bypass the clutch switch. Very unsafe, but good luck.
Feb 19, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a new prestige car remote installed recently and i have a problem how to shut off the alarm coz the installer did not or forgot to give me the manual. When i start the car remotely i press the...
You did not mention the year/make/model of your vehicle but, the issue appears to be the factory alarm. The installer failed to make the connection. If you intend to make the connection yourself I would need information pertaining to the vehicle. The (-) pulse before start wire for Prestige remote starters is black with a blue stripe. It is in a 4 pin connector at the module. This wire can be used to disarm the factory alarm before the remote start sequence.
Jan 23, 2011 | Prestige Remote Start
Cannot get to work with manual transmission please help with any ideas?
There are several steps necessary for the unit to function with manual transmission. Now,the unit comes programmed for manual transmission out of the box. Next, the neutral safety wire (thin black with white stripe) MUST be connected to the parking brake wire. Also, the tachometer wire MUST be connected. Check the neutral safety switch as well. Did you install a clutch bypass? All that is left is the system setup for remote start: Start the vehicle with the key,make sure all doors are closed, put the vehicle in neutral, press on the brake, apply parking brake, release brake, within 15 seconds remote start the vehicle, the parking lights will flash to confirm the remote start activation, turn the ignition off ( the vehicle should stay running.Exit the vehicle. Arm the alarm ( the vehicle should shut off). You are now able to operate the remote start. This process must be done each time you exit for the remote starter to function on a manual transmission vehicle. Don't worry ,you'll get used to it.
Oct 12, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have manual transmission car and I installed the
this is working proper, you have to set the system to ready mode everytime you want to be able to remote start it, this is a safety feature
Dec 27, 2009 | 1996 Honda Accord
Car starts with remote starter. The start procedure with key?
That car together with the alarm,have a "starter kill"relay. The alarm works fine but when the relay is "resting" the electrical contact is no letting the appropriate signal go through. Locate the relay and change it. Will cost you 8 dollars or less in any auto part.
Dec 05, 2008 | 2000 Toyota Corolla
C3RS730 LCD Logo
166 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
