Question about GE Profile PSI23NCR Side by Side Refrigerator
Refrigerator doesnt sem to be working right
Fride doesnt seem cold enough and freezer either, not sure if ice maker is working now either i cleaned underneat where everything was , and it was very dirt, but thatwas yesterday and didnt seemt ot help and temps are set correctly
  • 1 more comment
  • Anonymous Nov 19, 2007
    refrigerator seems not to be cold enough. I cleaned behind the unit..
  • General_Prob Jul 10, 2008
    My fridge is not freezing or cooling proficiently. It is not very old (maybe 2 1/2 years). This is the second time I've had this problem. The first time - it was still under warranty and I have no idea what the repair tech did to fix it. Could it be the compressor? This is crazy.
  • Anonymous Sep 01, 2008
    had same problem,replaced fuse and relay on compressor.
  • 291 Answers
Ice maker will not work if temp in freezer is not cold enough to keep activated
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting
Posted on Oct 31, 2007
SOURCE:
Have replaced everything and ice maker still doesnt work model ed5shaxmb10
An ice maker has 3 basic tasks:
1. Call for water.
2. Freeze.
3. Harvest.
Then the cycle repeats. There will always be some sensors that determine timing of those tasks. Home units usually have a bin level sensor (often an arm that's lifted as the bin fills) that can be locked in the up position to disable the ice maker.
If it's calling for water but not freezing, make sure the condenser is clean. (Sometimes they look clean but are plugged in the middle.) It has to get down to nearly 0 degrees to efficiently make ice, if it's not getting cold enough you may need a tech to figure out why.
If there's ice in the tray but it's not harvesting, clean the tray, hard water deposits can make the cubes stick in the tray.
May 26, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have the Sub Zero 550 Bottom Freezer Refrigerator. Just recently, the Freezer section started getting warmer and the ice maker stopped working...all at roughly the same time. It had been set to...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 31, 2010 | Refrigerators
Fridge and freezer doesnt seem cold enough. Things are cool but not cold. Ice cream is not as hard as usual (soft but not melted). Ice maker not making ice. Adjusting thermostat doesn't seem to make a...
Please check the timer the thermostat and the heater for the auto defrosting to work. Switch off the fridge and after all the frost has gone off switch on to see if the sooling returns . If so you can be sure that the timerr does not work and so reduces cooling on frosting. If there is still no cooling then you will need to check onthe compressor and the gas pressure. Get help to confirm and take an estimate before attempting, get an warranty assurance for work. Hope you try out and see first.Good day
Aug 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE refrigerator model # GSH25KGMB WW. It is a side by side with an ice maker and water dispenser. We have had it for about 9 years now. The ice maker hasn't been working right for about 6 or 7...
you could have several problems.
Since you mentioned your ice maker not working right - first check to see if your ice maker is hot (be carefull it can burn you if it is hot) - it is possible for an ice maker to hang in the heat cycle of the cycle producing excessive heat in the freezer. If this is the case unplug the ice maker and/ or just replace it.
The refrigerator gets it cold from the freezer so if the freezer is not working right, you'll soon notice it in the refrigerator side.
You can also check to make sure the evaporator fan motor is running(in the freezer) and the condenser motor(at the compressor) as well.
Also check the back panel of the freezer for excessive frost build up.
Jun 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker will not produce
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Feb 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water to ice maker leaking in freezer
I emptied out my freezer. Turned it off and made sure it was dry and clean. Then I turned it back on, but left the metal wire that controls the ice maker up so water wouldn't fill until freezer was cold enough. When cold enough, I dropped the metal wire down and kept a close watch of the filling process. Everything went smoothly. No problems in this first 24 hours. I think ice must have built up and letting it thaw and dry made the difference.
Oct 20, 2009 | Amana Refrigerators
Ice maker not freezing the water. teeth still appear to be turning but water only freezing due to cold freezer. water mostly overflowing and forming icicles all over the freezer section. have removed ice...
the freezer is supposed to freeze the water, the icemaker is just the form for the ice and the motor is to free the ice from the form, make sure water supply is cold water and not hot
Oct 10, 2009 | Whirlpool Refrigerators
Kenmore coldspot fride problem
The water line could be frozen. Take a hair dryer and heat up the tube where the water enters the ice maker. MAke sure it doesn't get to hot and start melting the plastic,
Feb 01, 2008 | Refrigerators
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
GE Profile PSI23NCR Side by Side Refrigerator Logo
199 people viewed this question
Top Refrigerators Experts
Brad Goodale
Tmik
Tmik
Level 1 Expert
R.A. Ellis
R.A. Ellis
