Question about Bosch 2607022999 Direct-Current Motor
Bosch 2607022999 chamge brushes
  • 5 Answers
Can't replace the brushes on t his DC motor. Have to get a replacement motor. They run about $70 at ereplacementparts.com at this writing. Direct Current Motor
Posted on Jul 14, 2014
Bosch 2604320913 Carbon-Brush Set
No If the saw is running the brushes must be working. Maybe the front end grease has dried causing too great of load on the motor. if not the motor must be defective (lost a winding in the feild) don't know how much you paid but unless its worth is greater than $150 I sugest buying another
Sep 18, 2012 | Bosch 2604320913 Carbon-Brush Set
I've just purchased a Bosch BX1 1600 vacuum cleaner in Spain, and already I've lost the hard furnishing brush, the crevice nozzle, the upholstery nozzle, and the hard-floor brush that I think were...
Hi Dave,
Are you in the USA? If you are, try this web address: >>>> http://www.bosch-eshop.com/eshop/bosch/us/brushesfloortools.htm
Copy and paste the address into your browser and the tool page will open up for you.
Should you want to shop in the UK, there are a lot of shops that carry them. Just do a google search for your make and model plus the word "attachments" and you'll see several from UK.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 02, 2011 | Bosch Vacuums
The brush doesn't turn when I tried to clean the carpet.
Easiest fix would be to check to see if the belt is broken or not moving. If it is not broken yet not moving then most likely the brush that it turns is frozen. Follow the directions to change the belt. Once you get the brush out of the unit clean it as best you can. Spray some WD40 on the plastic tabs at the ends that hold it into the vacuum head. When reassembling, might as well add a new belt.
If you find this solution to be of help, I would appreciate a Thumbs Up rating from you. Paul
Oct 11, 2010 | Bosch 12-Amp Formula Canister Vacuum with...
Bosch premium Duo 'H, brush won't spin
Hi - this procedure may work.
Switch off the Bosch and take off the main power head. There should be screws or a flap on the base in which the roller brush can be taken out or inspected. Check the internals and make sure nothing is clogged - if there are toothed wheels at the end of the beater bar on each side, take it out and clean it if it is clogged with dust. Alternatively check the main turbine as it may be stuck down with dust that needs to be de-clogged. Then check the main hose mount that meets the floor head in question - check that the metal strip connection has not corroded. Hope this info helps.
Don't forget to rate, thanks.
Mar 04, 2009 | Bosch BSG81370UC Premium Duo Health Guard...
Which direction should the brush roller rotate?
take back to repair shop that is most likely the case thank you for useing fixya please rate me
Feb 24, 2009 | Vacuums
Siemens/Bosch Vacuum cleaner
I ordered both a motor and belt by calling the Bosch service number in the manual and installed them myself, but quickly they failed again, the nylon cogs burned off (wish I could just get the cog wheel, but they have to sell you the whole motor). I bought a second Vax branded machine, which worked okay at first but now it constantly needs to be emptied for suction. Now I'm hoping to swap the bottom of my new machine with the top of my Bosch which doesn't have the suction problem. Good luck. Susan
Nov 09, 2008 | Vacuums
Drive belt on upright bagless cleaner
if its like mine there is a rod that comes out f the moter usually on the upper left of the power head put t the belt around that and then slip the belt over the beater bar. Then replace the beater bar. You will have to pull a little to stretch the belt.
Jun 13, 2008 | Bosch Vacuums
Bosch hepa 2000w vacuum - burning smell coming from appliance
I it is an electrical smell, then you have a bad motor, if a rubber smell, you may have a bad belt and/or brush roll.
May 12, 2008 | Vacuums
My bosch turbo jet vacuum
open the head. there is a dc 120 v motor with a belt.
check for ac power going in to the rectifier board and dc comming out.
sometimes the black wire breaks inside the motor housing.
it is hard to open and close the motor housing side where the wires run and closing the power head is fun as well.there is a transformer for the light and wires have to be routed just right to close it up.
good luck
Paul G. Canada
May 07, 2008 | Bosch Turbo Jet Bagged Upright Vacuum
Bosch vacuum
check the belt, it might be stretched or broken
or carpet fibers and hairs may have clogged up the brushes to keep them from rotating
let me know if this isn't the problem
Mar 22, 2008 | Bosch Turbo Jet Bagged Upright Vacuum
Bosch 2607022999 Direct-Current Motor Logo
Top Bosch Vacuums Experts
Cleverer2
Billy Detlefsen
ray gallant
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
