Question about Garden
Hosed down my new Craftsmen riding mower after it got all mud and wet grass on it and I wanted to store for winter. There is NO activity in the ignition..I assume water got in electrical system. What can I do?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 103 Answers
Waters not guna do that, my customers leave theres in the rain all the time check ur battrie maybe u left ur key on and it drained the battrie and check ur fuse to see its not blown its under the hood behind the dash give me more details and i can help even more, thank you
Posted on Nov 27, 2013
  • Dan Williams
    Dan Williams Nov 27, 2013
    Thanks for advice...turns out I left the chute off and there's a sensor that won't allow engine to turn on if chute not in place
SOURCE: Husqvarna Ride Lawn Mower does not want to start
I've discovered that if you leave key on battery will be drained to dead. Checking battery with meter shows +12v. When key is turned to start position nothing happens. When you connect meter to battery terminals and put key to start position the meter reads about .250 VDC. Even after taking battery to Advance Auto and have it checked it still does same thing. Eventually I jumped my mower with another battery that was being used in my scooter. Bingo! all worked well with jump. You would probably be able to jump with car battery with no problem.
Posted on Mar 26, 2009
  • 125 Answers
SOURCE: A row of uncut grass left between blaces when mowing
Mowing too fast for the blade speed. Use higher engine speed or lower gear.
One or both blades too short?
Posted on Jun 16, 2009
perpetually
  • 360 Answers
SOURCE: uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
Posted on Sep 21, 2009
bbreton
  • 437 Answers
SOURCE: I have a yardman 46 in cut riding mower, it is
Well one of the spindle assemblies, could be running a little slower on one side then the other. But I would take a guess that you are trying to cut grass, way too fast for the mower. Try running a ground speed a liitle slower and see what happens.
Good Day.
Posted on Oct 07, 2009
mickey813
  • 472 Answers
SOURCE: Husqvarna gth 2448t 48'' 24 hp riding mower 2007
YA IT SOUNDS LIKE YOUR SEAT SWICH IS BAD THATS THE MOST COMON THING I SEE A LOT OF LET ME KNOW IF THIS HELPS YOU
Posted on Oct 08, 2009
Do the graphics on the blade face up to the mower or down to the grass when fitting a new blade?
Many blade has grass side stamped into the metal.
You want the cutting to be on the leading edge either way; otherwords, the cutting sharp edge leading. Most blades also turn clockwise when viewed from the top and counter clockwise when viewed from the grass side
Apr 06, 2015 | Garden
Simplicity Problems overheats after 1/2 hour of use
remove the tin cowling over the fins of the motor and clean out debris. Grass -mud -ect
Jun 12, 2013 | Simplicity Regent 22 44 Riding Lawn Mower...
My ride on mower is not cutting the grass as the belt keeps on breaking after doing one strip of the garden iv bought 3 new belts in the space of 4 days it seems to only wear in one side then stretch and...
Have the pulleys checked for worn bearings and improper alignment which can cause this to happen Also the cheaper belts do break when cutting wet grass. Example.... My John Deeres belt cost $75 for a new factory one. A generic Goodyear belt runs $15. Guess what happens when I cut wet grass witha Goodyear belt? Yes it flies off. The Deere belt will stay on for it is made with a protective rubberized coating incased in fabric. If you are using a inexspensive belt you will get a lot of grief from it
Jul 09, 2011 | Husqvarna Garden
I have a single cylinder Ranch King riding lawn mower. Model # 133K6796205. Bought in 1993. I need to know what type of oil to put in it? I am also having a problem with the grass collector. Even if...
Hello You can use straight 30 w oil most engine manufactures agree for summer equipment now for winter where it gets cold like in a snow blower the request you to use 5-W30. As far as your grass collector check your blades #1 to see if they are the correct blades for that mower. #2 yes the engine will overheat as the clumped of grass will slow down the blades causing more load on the engine.This is not a uncommon problem wet or damp grass will clump up even if you do not have a grass collector,it will stick under the deck again causing problems.Hopefully this helps.
Thanks Ben
May 02, 2011 | Garden
The mower is mowing uneven in the front. what can i do? it seems that it is scalping the grass but both sides are level
Look under the mower deck. If you can't see well and work on it, you may have to remove the mower deck and flip it over on the ground. Grass and mud buildup in the decj could cause a blade to pinch grass, 'scalping' the lawn. Clean it all out. Dull blades cause cut grass to look torn and brown. Remove and sharpen. Bent blade will cause uneven cut. Replace it. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Is it safe to cut wet or damp grass with this electric lawnmower? Does it have rcd?
Yes, the electrics are well sealed from the wet grass, although wet grass may clog the mower or slow performance.
May 20, 2010 | Garden
Bog when trying to mow
you are cutting to much grass & it isn't kicking it out fast enough out of deck which will bog it down it might help if you clean out the bottom of the deck & also dont cut really low if grass is really tall also cutting wet grass will aslo cause the bogging if i can further help e-mail me wade at wadembly@aol.com
Jun 26, 2009 | Garden
Motor has low torque
common complains for electric & cordless mower is that they are not ment for cutting on wet or dump grasses or long tall grasses they will bog down. for this type of unit blade should be extremely sharp. also clean the under the deck so you can better air flow for the blade. if your switch & rectifier are new & in right connection then have you armature check for short circuit..
Jul 27, 2008 | Black & Decker 19" Electric Lawnhog...
Mower won't start
13 to 15 amps electric or battery operated mower may runs slow when cutting thick grass. also recommended not to cut grass when it's wet & need very sharp blade to do the lawn. may overloading it, cutting grass too thick also draws too much power. check house breaker first.
Jun 11, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
