Question about LG LRFD25850 French Door Refrigerator
We have an lg refrigerator model #ufc21760st. The vegetable drawers come unhinged and it is very difficult to replace them. Can you please advice us how to easily put them back in?
    Champion:
    Habit-Forming:
  • 279 Answers
Make sure the rails are pulled all the way forward, then lift the basket into place.
Posted on Nov 22, 2013
mgprice
  • 744 Answers
SOURCE: VEGETABLES FREEZING IN LOWER LEFT DRAWER
Hello, This problem is going to be the cold control, this can be located in the control panel inside the fridge. This part is also called the thermostat. What is happening here is it has opened and the freezer is getting to cold which is making the fridge too cold. This is why the food in your fridge is freezing. You should replace the cold control and you will be all set. Mike
Posted on Nov 09, 2009
  • 22 Answers
SOURCE: Refrigeration vegetable drawers freeze.
unload you fridge to much product in it would cause the air flow to to be redirected.. low charge causing excessive low temp...use a thermometer to measure temp you should be 35 to 40 degree F.
check stat adjustment
Posted on Nov 14, 2009
omaharox
  • 166 Answers
SOURCE: Freezing in left crisper drawer.
If you have had a DOE upgrade the fix is availiable from LG
Here is the service buliten # CREF20090877.
Contact LG @ 1 800 243-0000 for repair.
In the mean time remove crisper dware and look on the back wall of the ref. you will see a dime sized hole on the center tower. Cover the hole with tape and reinstall crisper.
Posted on Jan 20, 2010
  • 161 Answers
SOURCE: Freezing in the bottom draw of my LG Refrigerator
Pull the drawers out and locate the vent hole on the back wall and put a peice of tape over the vent hole re-assemble and problem solved.
Posted on Jan 24, 2010
  • 794 Answers
SOURCE: Im getting water under the vegetable drawer inside
Hi boris_sal495,
There are two things that you can check if you are getting water under the vegetable drawer. Kindly refer on the details below:
Reminder:Before doing any checking or repair unplug the refrigerator from power and remember your safety.
1. Clear the Drain Tube - Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of 1/4 inch or smaller flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
2. Leveling a Refrigerator - It is important for the refrigerator to be level.Check that the refrigerator is level from side to side.If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An icemaker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then tighten the screws.
Hope it helps.
Thank you for using Fixya.
Posted on May 04, 2011
Testimonial: "Thanks for the answer. It worked!"
Water build up
Good Afternoon Friend,
I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Frigidaire Refrigerators
Water leaking inside the vegetable drawer
What is your model number? Also what year, series etc.
Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
Fruits or vegtables freeze in crisper drawers
Hi
The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try:-
If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
Please check the link bellow to have a detailed idea of how to store food or in what temperature in refrigerator:-
http://www.ehow.com/way_5670387_storage-tips-vegetables-humidity-drawers.html
Please get back to us if you have further query else please accept the suggestion.
Feb 01, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our refrigerator is about 7 years old. The vegetable drawers (clear plastic) are very difficult to pull out. We have washed and dried them, cleaned the tracks, etc., but to no avail. Is there a...
Normally, all vegetable doors can easily be pulled out as there are minimum 1/8" allowance in both side. I think, your refrigerator got corroded with where indoor compartment is fixed. Please check any dental in iron side of the door, If not, just clean drawers both side with an emery (salt) paper to enable it to enter inside freely.
Jan 22, 2011 | Amana ARB8057C Bottom Freezer Refrigerator
Kenmore Model #106.53552201: Replacement Vegetable drawer?
You can get part`s for your fridge at searspartsdirect.com. part number I found was 2188656 (labelled as a crisper pan) and it list for $90. The other drawer, labeled as a meat pan is 2188664 and listed at $47.
Hope that answer`s your question. You could also take your old drawer into a local used appliance shop (if one exist`s in your area) and see if it can be matched up with a used one, it`s made by "whirlpool".
Hope that help`s.
Thank`s for visiting "fixya" today. Good luck.
macmarkus :)
Feb 10, 2010 | Kenmore Refrigerators
Jan 19, 2010 | LG LFX25960 Bottom Freezer French Door...
VEGETABLES FREEZING IN LOWER LEFT DRAWER. I have an LG model LFX25960. If I raise the temp to 45 in the refrigerator it will be 34 in that drawer but that also makes the rest of the refrigerator too low a...
Nov 07, 2009 | LG Refrigerators
Bosch Refrigerator ice forming in vegetable drawer
Emptied drawers and cleared the drain hole. Drawers were then refilled BUT MADE SURE THAT THEY WERE NOT OVERLOADED
Jul 28, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Mar 24, 2009 | Refrigerators
    LG LRFD25850 French Door Refrigerator Logo
    52 people viewed this question
    Top LG Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a LG Refrigerator Expert? Answer questions, earn points and help others
