Question about Teac Audio Players & Recorders
My reel to reel will not play.
I push the forward button and the pinch roller moves into position but it does not play. It will however fast forward and reverse.
  • Teac Master
  • 1,267 Answers
You need a new capstan belt or the capstan shaft is glazed as well as you have a hard shiny Pinch Roller. Each of these items need to have friction to work.
Posted on Jan 03, 2015
skywavebe
  • 1267 Answers
SOURCE: teac a-3440 will not play
Hi Gary,
This makes me think the Capstan Shaft is not turning either due to a broken or stretched belt or that the capstan motor itself has stopped working. This may be a job for a Technician. You first determine if the Capstan is turning or not- this is the metal post that contacts the Pinch Roller that rotates and is the way the deck gets it's speed regulation. If it is not turning look inside the deck from the side to see if the flywheel is turning and that the belt is on that flywheel. Lastly make sure the capstan motor is turning.
Beyond that a Tech may have to take over from there. I am in the Chicago area and can repair it if you are close. Many people send me units from all over the USA anyway.
My name is Sam. I operate Skywave Tape Deck Repair
skywavebe@sbcglobal.net if you need my help.
Posted on Aug 19, 2012
robotek
  • 1512 Answers
SOURCE: Teac X1000R Reel to reel
Hi there. It will need a new pinch roller, and has a bias oscillator. problem. From memory, they use a module for the oscillator, and the pinch rollers are easy to get. Sorting out the bias may be the problematic part, and you will need to recalibrate the bias traps and controls if you want max performance from the unit once repaired. I would go about checking things like intermittent tape bias switch, and try wriggling the record play switch( internally) and see if you can get erase and rec back. Noisy intermittent switches can caused the symptoms you have.
If you are able to, I would be seeking a refund. If not, then repairs are feasible. Let me know where you are and I can help you find a repair guy. Cheers
regards
robotek
Posted on Sep 07, 2008
  • 43059 Answers
SOURCE: Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Posted on Sep 24, 2012
skywavebe
  • 1267 Answers
SOURCE: tascam 38 reel-to-reel 8 track- the ff and rew work and cue instantly; it will not move forward when the play button is pushed. It is as if something is stopping it's motion. To my knowledge it i
Hi James,
I am a past Teac Technician. The answer may be a bad capstan belt- is the round metal thing rotating that makes contact with the rubber Pinch Roller? These belts become lose over time and the DC motor become defective in time due to wear- Before they burn out they can be serviced but only by a person with knowledge about how to take them apart. Otherwise the part can be $120 plus installation. I have not seen sticky Pinch Roller linkages in these models so I will say it is probably not that.
If you are near Chicago I can help you out. If you are near New Jersey Russ can help. If you want to discuss, contact me.
I work on all Teac and Tascam units now full time.
I am also known on tapeheads.net as well.
Posted on Oct 31, 2012
skywavebe
  • 1267 Answers
SOURCE: reel to reel will not play
You do not mention the brand or model number which to answer the question effectively is needed- different machines are designed in different ways. The function of the fast wind and the play mode only differs in that in play a capstan is involved that regulates the speed and the reel motors just do the take-up of taper and a little back tension for the supply reel. You may have either a sticky Pinch Roller linkage or a non- rotating capstan shaft that might point to a loose or broken capstan drive belt. There are also the condition of the Pinch Roller surface and the surface of the Capstan shaft that can be glazed or rubber hard and non-compliant. The rubber Pinch Roller can be re-rubbered, the capstan shaft can be reconditioned and the Capstan Belt can be replaced. Capstan bearings and motor bearings need oil once a year as well. I hope this helped to some extent- I have been working on decks now for better than 40 years.
Posted on Dec 13, 2012
Sony taperecorder TC-355 will only run in fast forward. when trying to play in any speed tape moder went into fast forward and would not play tape.
If the speed-controlled roller is not closing to pinch the tape when PLAY is selected, the recorder will play in a fast mode. You will need Isopropyl alcohol, contact cleaner, Q-tips a screwdriver needle-nose pliers and a steady hand to clean every moving part in that Reel-To-Reel and then lightly lubricate the moving parts.
While you are in there I would change the belts as well. Or send it to a qualified repair shop and pay $ 125.00 to $ 200.00 for same thing to be done. Take your time, it's just a big puzzle, make sure you video or document everything you remove so it goes back together correctly. Good Luck!
Nov 11, 2016 | Sony Audio Players & Recorders
Reel to reel will not play
Dec 12, 2012 | Audio Players & Recorders
Tascam 38 reel-to-reel 8 track- the ff and rew work and cue instantly; it will not move forward when the play button is pushed. It is as if something is stopping it's motion. To my knowledge it i
Hi James,
Oct 31, 2012 | Audio Players & Recorders
I Press Play Button, And Tape Goes Into Fast Forward Mode
Pinch Roller linkage is stuck. Clean and regrease and it will work right again- I have done hundreds of them
May 01, 2012 | Teac Audio Players & Recorders
The auto stop mechanism seems to have completely stopped working. When play a cassette, it eats it. When you put the deck into play mode without a cassette and push on the pinch roller with your finger, it...
When's the last time it was cleaned? It surely needs it now.
Never touch the any part of the transport that directly contacts the tape with bear fingers.
This sounds like a failure of the take-up (left) reel to take up slack as it's fed in by the capstan.
You can probably trust the machine to fast forward or rewind a tape to test the ability of the reels to manage slack since either action only requires one reel to pull while the other just coasts. Failure would look like stationary tape that eventually would time out and reset the command.
If it won't do fast transport motions that eliminates the capstan/pinch roller.
If it CAN FF and REW then the capstan, pinch roller, heads or something is probably glommed up with sticky tape oxide, which brings us back to the first question.
Jun 30, 2011 | Panasonic RX-FS470 Cassette Boombox
I have a sony TC-660 reel to reel player, it had been in great condition, and i love using it. All of a sudden however, the reels will ONLY move in one direction (clockwise for the left, and counter...
In order to maintain tape control and tension the reels always pull lightly in opposite directions during PLAY mode. The capstan moves the tape in the desired direction at a precise speed. If the capstan doesn't engage the tape BETWEEN itself and the pinch roller you'll get the reels battling over control of the tape. Check the tape routing.
May 25, 2010 | Quantegy 456 Reel-To-Reel Recording Tape
I have a Sony TC 630 Reel to Reel Stereo Tapecorder..Pinch Wheel is sticking and will only move when forced and brushes as well...Any help ?
Sounds to me like your Sony has a common problem among vintage reel tape decks..dried /frozen grease/ and or a lack of lubrication. carefully apply a tiny bit of fine lube oil, like 3in1, on the swing mechanism that carries the pinch roller...(you may have to remove the front metal deck face to fully access the swinging pinch roller mechanism) ) . do NOT get any oil on the rubber pinch roller..(best to make sure after by scrubbing the pinch roller surface with a cotton swab lightly dipped in non chemical household cleaner, like 409, or awesome orange i get at the dollar store. Then use the dry end of the swab to ensure the pinch roller is dry. .The pressure pads should swing upward and press the tape against the heads when in play/record mode..if they do not swing up, they are binding/ or out of adjustment....they are spring loaded so when the reel deck is in the stop position the spring loaded pressure pads are held down...play/record mode releases them to freely swing up and press on the tape against the heads.
May 11, 2010 | Audio Players & Recorders
My Teac 4070G reel to reel tape deck rewind and fast forward functions work, but the play function does not. Any ideas? Could it be a circuit?
Without actually seeing your Teac reel deck, i suggest you verify that all fuzes in the deck are good..not blown. Also with a tape correctly installed..ensure that left and right tape tension arms are held under tension/ closed by tape tension, also ensure the capstan shaft is rotating... look in back to ensure the capstan drive motor is running.. if yes, and tape still will not play... problem could be a stuck/failed solenoid, dirty or corroded push buttons, or corrosion on contacts where rear circuit boards/plugs insert into other boards.
Feb 28, 2010 | Audio Players & Recorders
Sony reel to reel TC -765
I too had this problem with my tc765. I found the two pinch rollers were not lifting up and fully pushing the tape against the rotating capstans in the play/record mode. Solution to my problem involved partly dismantling the pinch roller assembly, cleaning off the old solidified grease and re-lubing with a molybdenum grease. Note: the top plate has to come off first,then the rotating guides and tensioning pegs. Then the cast head cover and flap. It was a time consuming operation, but well within the scope of competent DIY in my opinion.
Sep 24, 2007 | Audio Players & Recorders
Tape is stuck in VCR- Fast rewind and forward
It may need to be cleaned. Mechanical problems are one of the big problems with VCRs they use alot of mechanical moving parts and play for so long they fail. Plastic parts dont help much either. The pinch roller takes up the slack and is usualy the part that fails first because it constantly runs along the tape and builds a coating on the rubber so it doesnt grip the tape and pull it back into the cassette. If its not pulling the tape back in then it hangs up inside and you cant get the tape out. Fastforward uses the reels to pull the tape not so much the roller. Try and stop 2 times then fast forward then eject the tape. Try and eject the tape while its fastforwarding so it doesnt do anything else. Sometimes machines will unload after its been in fastforwad a while then it will eject. You will hear a change in the sound when it unloads, you can hear the mechanical arms move the tape in and out of the cassette. Thats when you eject it. You cant really clean it till you get the tape out. YOu can clean the pinch roller with fingernail polish or paint remover. It is a wheel inside it looks like a black tire. It pinches the tape against the capstan arm this is why it developes a film or a shine on the rubber making it slip.
Apr 04, 2006 | JVC HR-J461MS VHS VCR
197 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
