Question about Exercise & Fitness
Cannot get the belt centered on my incline trainer x9i! So frustrated.
I can adjust it so that it is centered at the top, but then the back is off by 1.5 inches!
3 Suggested Answers
2manyhobbies
  • 127 Answers
SOURCE: i have the Incline Trainer X7i. i lost the
Find the allen key that came with the treadmill. It is used to assemble and adjust the treadmill.
Locate the 2 adjustment screws at the rear of the machine. If the belt is shifting to the left, tighten the left screw (turn clockwise) and the same if the belt goes to the right, tighten the right.
Only turn the screw 1/2 turn and move the belt manually to shift the belt. If it requires more, turn another 1/4 turn, very little adjustment may be required to straighten the belt. Once the belt stops rubbing, start the machine running slowly (1-2 mph) and observe the belt FROM DIRECTLY BEHIND THE MACHINE. Carefully adjust the rear roller till the belt is as close to center as possible making small adjustments, 1/8-1/4 turn clockwise of the adjustment screws.
Posted on Dec 15, 2010
ercupa190
  • 12223 Answers
SOURCE: Golds Gym Trainer 410 belt and incline do not work
LUBE THE DECK BELT SEE THE VIDEO ATTACHED
2) RUN THE SOFTWARE CALIBRATION FOR EASY DIAGNOSE, TROUBLESHOOTING AND FIX IT. GO under the HOOD motor, and follow the steps.
God Bless you
Posted on Dec 13, 2012
NordicTrack x9i Terrible banging sound coming from belt roller in back
Try to lubricate the treadmill running belt.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Treadmill walking belt lubrication
Jan 02, 2017 | Nordic Track Exercise & Fitness
Loosen walking belt
Turn the bolts at the end of the treadmill anti clockwise.
Nov 09, 2013 | Nordic Track Incline Trainer X9i...
Walking belt crooked
tighten the belt with machine running .
The side it runs to is the side u will tighten about 45 deg clockwise.
My x9i gives off a burning smell and rattle when running .
I also have an X9i treadmill hardly used .smells like its burning. It also is not acting right while on it. Whats causing this? it cost $2000.00 no joke I thought Norditrak was a better company. I purchased it from Back country.
Aug 15, 2013 | Nordic Track Incline Trainer X9i...
I just bought a Nordic Track X9i incline trainer. Started working well, however after a few hours of use I cannot use any control keys and belt and incline does not work. The touch screen display works but...
You should immediately replace the console. That console will just keep getting worse. This is endemic of this brand, however it usually happens a lot further in the life of the unit. When you call Nordictrack have your model number.
Aug 11, 2013 | Nordic Track Incline Trainer X9i...
X9i incline trainer clicking
Step 1:
RUN the calibration software . and fix it. God bless you
he Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Step 2:
Feb 07, 2013 | Nordic Track Incline Trainer X9i...
Nordic track X9i controls not responding
Dear Sir:
Adjust the reed switch, see the diagram attached, clean, and tight the connector very well.
Anyway I recommend to call the service Help, in the place where you did buy your treadmill.
However you can RUn THE SOFTWARE calibratin for diagnose, troubleshootin, and fix it, follow the steps in your instructions manual.
sincerely. God bless you
May 07, 2012 | Nordic Track Incline Trainer X9i...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
