Question about Dell Latitude C640 Notebook
LCD PROBLEM I hav a dell latitude C-640 laptop.. The screen got shattered now it's wid a broken LCD and i need to repair it m staying in pune and we do not hav any dell service center near ny need suggestions as to how i can repair and use the laptop again...
  • 661 Answers
If you can get hold of a second Dell Lappy (same model) which is broken (not broken screen) you can swap the broken screen for the good one. It means opening the laptop, but due to the smashed screen the warranty is invalid anyway. There is usually 1 or 2 cables coming from the screen 1 for signal and 1 for power. you can explore the broken lappy to see how the screen connects,
Posted on Oct 08, 2007
SOURCE:
How do I fix or replace a broken Hinge on Dell 500 Laptop
The hinge rarely breaks, the fixings come loose and split the plastic case.
Disassemble the laptop to find out where your problem is,
DELL Vostro 500 PP29L SSD
If the plastic has broken off, I use epoxy resin to repair around the hinge or look on fleabay for a replacement hinge.
Dell Latitude D500 Laptop 14 1 034 Screen Hinges eBay
Feb 06, 2017 | Dell Computers & Internet
Dell latitude c610 broken hinge
go www.dell.com give your service tag, model and download your instr. manula and service manual , parts and fix it.
God bless you
Sep 27, 2012 | Computers & Internet
I AM LOOKING FOR A SERVICE MANUAL FOR A dELL lATITUDE C 640 (laptop) I am changing the screens out and theres gotta be a better way to do it.
http://support.dell.com/support/edocs/systems/latc640/sm_en/display.htm#1001090
This link will take you to Dell's website and gives you information on how to change your LCD screen. Included are pictures and information on what tools you will need. Good luck.
Oct 17, 2010 | Dell Computers & Internet
Laptop Screen Repair
The screen will cost at least $200.00 plus labor (approx. $85).
you will need to remove the upper lcd display casing, remove the screen that hold the screen to the bottom lcd display case, and remove the data and inverter cable.
one website that sells screens is:
http://www.lcds4less.com/DellLaptop__Dell_Latitude_E4300__laptop-screens.html
Feb 27, 2010 | Dell Latitude E4300 Notebook
My Dell D600 laptop screen won't stay up. The
I dont see much that can be done, short of replacing what is broken.
Nov 22, 2009 | Dell Latitude D600 Notebook
Replaced screen computer comes on, but screen stays black.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 22, 2009 | Dell Latitude D600 Notebook
Dell Latitude
If the system still works on an external monitor and functions normally otherwise, you might be able teo replace the LCD assy for about $150.
If the system no longer works on external either, then I'd say the system is no longer viable as an item to repair as it will be cheaper to replace it then to repair it. (New laptops start at around $500)
Feb 08, 2009 | Dell Latitude CPX Notebook
Have a broken lcd for a dell inspirion 1500 help!!!!!!
Is your laptop under warranty/extended warranty for accidental damage? If it is inquire from Dell about the procedure to send it to them and getting it fixed click here to get the contact info. If its not under warranty you can inquire Dell for your area dealer/repair shop to get the LCD replaced.
You can also get an estimate for replacing the LCD screen from your local area repair shop to have an idea. In most cases I have seen the technical job performed by the manufacturer is far more superior (Please do not take me wrong, its my experience).
Sorry could not be of much help then to guide you to a right path.
Hope that helped!
Nov 06, 2008 | Sony VAIO V505BXP Notebook
Screen was shattered
notebooks like toshiba's are hardware and software specific. Other hardwares will work but not guaranteed to provide full and satisfying results. Drivers may fix the problem. But I suggest you get a orginal Toshiba LCD
Oct 11, 2008 | Toshiba Satellite A15-S127 Notebook
Dell Latitude C640 Notebook Logo
501 people viewed this question
Ekse
Clive
Clive
