Question about RCA RT2870 Theater System
Sound goes off cannot turn reciever off have to unplug to reset it
Model: PGX2L5644-662MHz. Its causing a loud sound as if its lost or is loosing frequency even if I am standing with the mic close to the reciever. The ready light comes on and also the signal light when I...
Reset the channel/group on both the mike and the reciever. Shure reuses frequencies by groups so if the group is different, but the channel is the same then you aren't on the same actual frequency.
There should be an auto-set option on the recievers display as well as the mike. Turn them both on, and then just hold the mike up to the reciever so that the little IR window can see the reciever and the 2 with sync together.
If they are both on the same group and channel then turn the mike off, and adjust the squelch control until static is heard, then turn it back until it just goes away.
Feb 28, 2011 | Shure LX2 / Beta58 Microphone
My 2001 Mitsubishi Medallion recently stopped recieveing HD channel from my FIOS HDTV Box. When switching from standard channels(they work) to an HD channel, the screen shows scrambled mutltiple images and...
If the TV works in the "Other" modes than I would suspect, that the FIOS HDTV box has developed some fault. When a TV goes to a "Blue Screen" this means that it cannot interpret a proper signal, maybe you need to reset the FIOS, anyway check that out, the TV itself, I do NOT think is faulty, check connections, antenna and to TV as well. Unplug ALL from wall wait 5 mins, and power back up, this often fixes a lot or problems.
R - Restore: Restore default settings E - Environment: Change your environment, remove from media cabinet, try different media, try different equipment (TV, router, hotspot, etc.). P - Power Cycle: Power cycle by unplugging your networking equipment from wall for 2 minutes to reset. A - Access this Knowledge Center for useful articles to resolve issues. I - Install the latest System Software Update. R - Resolved: In most cases these steps can resolve your issue.
Apr 01, 2010 | Televison & Video
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
My yamaha reciever has a power problem in that when i switch it on, it only goes on for a few seconds and thereafter goes off.
As long as you're sure the power cord is firmly plugged in, it sounds like the protection circuitry of the unit has likely been activated. This happens when there is a short circuit in one of the connections. Check your speaker wiring connections and make sure all of them are firmly and carefully grounded (i.e. the copper of the wire touches nothing but the proper terminal, and that the wires do not touch each other). Check the connections on the speakers as well. If protection circuitry is the result of a shock or power surge (lightning, strong static, etc.), you can reset it. Turn it to standby mode, unplug it, wait for 30 seconds, then plug it back in.
Jan 20, 2010 | Yamaha HTR-5630 Receiver
No Power From My Reciever
Mook_trakzz, your device is most likely roasted and ready or scrap. Sorry.
Guest, check if the cables are connected properly, specially the cable between the device and the sub is quite easily shifted thus losing your sound.
timtlc, seems you have had some powerfailure during that night, you can try to remove the powercable for at least 15 seconds, that should reset the device.
to all, information from Philips on this device:
  • Press the STANDBY ON button on the front of the DVD system to turn on the power.
    If the device powers on at the unit and not the remote, the unit may have been turned off with TV selected as the source on the remote. The standby button on the remote will operate most Philips TV’s when TV is selected as the source. Change the source to disc or any other source than TV on the remote.
  • To completely reset the player, unplug the AC cord from the AC outlet for 15 seconds.
Feb 21, 2009 | Philips HTS3450 System
I have an old 5 in one reciever sony; i dont see any fuses and my problem is that after turning on it goes to the protect mode flashing prptect. i disconted the entire reciever so i know there are no...
No reset will help this. The problem is an internal short most likely in in one of the amp circuits. This is a relatively simple repair for a service shop. Expect a parts cost in the $40 range. Add in the local labor rate for the total repair cost.
Dan
Feb 01, 2009 | Sony STR-DE475 Receiver
DCT6200 Receiver Resets when looking at guide
Its your cable box.  You are going to have to swap it with another one.
Aug 27, 2008 | Arris DCT6200 DTV Receiver
Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Aug 04, 2008 | Bose Acoustimass 15 System
Htr-5730 yamaha reciever
try another outlet sounds like you may have a short in either your power cord/supply or your outlet is acting up with the wiring
Feb 22, 2008 | Yamaha HTR-5730 Receiver
Should I just Buy a new one?
You have a bad power supply or the audio output circuit has a short in it. You are correct by saying its probably betterv off getting a new unit. Most likly cost you more then a brand new shiny unit would . Good Luck PS Please do not forget to rate this thread
Dec 10, 2006 | Yamaha HTR-5740 Receiver
RCA RT2870 Theater System Logo
26 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
