Question about Midland Radio Communications
Cb modulation low modulation otput on MIDLAND 48 MULTI EXCEL WHOT IS THE NUMBER FOR AMC ADJUSTMENT POINT
    Genius:
  • Midland Master
  • 1,795 Answers
RV 201
Posted on Jul 28, 2015
5 Suggested Answers
One Wire
  • 126 Answers
SOURCE: converting a different brand of mic for a midland CB
This should be a typical Midland pinout. If you are using a generic 4 pin mic that is wired to cobra/Uniden, all you have to do is switch pin 1 & 2, then 3 & 4.
Not all mics are color coded the same with their wires.
Posted on Oct 06, 2008
  • 67 Answers
SOURCE: Midland alan 42 multi CB Radio
The user manual can be found in PDF form here: http://www.alan-uk.com/cb/manuals/42%20multi%20manual.pdf
Posted on Feb 27, 2010
  • 40 Answers
SOURCE: when driving over rough ground my midland alan 48
Check for loose buttons, could be something loose inside, if its changing on its own when its moving around could be from vibration that something has come loose.
When parked just try shaking the mic first if that doesnt do it shake the cb itself and see if the problem persists
Posted on Jun 20, 2010
Ironfist109
  • 3018 Answers
SOURCE: modulation on 1001Lwx midland cb
hello,
The limiter is what limits the modulation. Often times there is a pot that you can turn to adjust it. To get more power and swing out of your radio do this DM1 is the mod limiter RVM1 is the mod pot. Adjust this for maximum modulation. Spread the coils marked Lt5/LT12 just a little Spread LT7/LT11 a lot.
Regards, Tony
Posted on Apr 14, 2011
How to turn up the power on the midland 78 plus
Midland 78-574: {L209, L212, L214, RV9-AMC, RV201-ALC, RV#-SSB MIKE GAIN, VR4-AM PWR}
Midland 78-976: {L7, L11, L13, RV12-AMC, RV2-ALC, RV11-SSB MIKE GAIN, VR4-AM PWR}
Midland 78-999: {L209, L212, L214, RV9-AMC, RV201-ALC, RV#-SSB MIKE GAIN, VR4-AM PWR}
I put these up due to not knowing which one you have
May 07, 2015 | Midland Radio Communications
How th adjust peek modulation on a midland 1001lwx cb radio
VR 2 is the pot you are looking for an now you need a modulation meter. Speak into the mic at the volume you will be talking on the radio. One one one one while adjusting for 100 percent anymore an you will begin distorting.
Jun 03, 2014 | Midland 1001LWX CB Radio
Midland 48 excel
get a can of electrical freeze,spray it on the final after the radio shuts down and see if it comes back on. Do it to all the IC's to find out which one it is than have a tech look at it and let him fix it.
May 11, 2014 | Radio Communications
My radio 148gtl d has low modulation
The Modulation adjustment is VR5, or you can cut D9, though I do not recommend completely disabling the AMC circuit. If VR5 does not have enough range, lift the banded end of D9 & solder a 1K-ohm resistor in series with the diode, then adjust for 100% modulation or to where the AMC circuit just starts to limit modulation.
Mar 04, 2014 | Cobra 148GTL AM/Single Sideband CB Radio -...
Cb radio modulation
www.cbtricks.com
use the vr adjustment points to adjust the AMC modulation. DO NOT cut the mic audio limiter tr-32 or the modulation limiter tr-54. it will over-modulate and splatter out of band if you do
Feb 15, 2014 | Connex 3300, Deluxe Amateur Transceiver,...
Midland 77-099 Modulation/AMC pot?
the one closest to the power transformer.RV 4 . Have some at a distancetell you which way is best.If you have a scope it would be better.you can also look at your meter on the front and write down the number the needle hits.the turn it the other way.you may wind up turning it back all the way .
May 26, 2012 | Midland 77-099 CB Radio
Garbled modulation midland 1001z. I would like to be able to adjust.
the ANCE is DM1. you can adjust the.modulation by turning it. you can also just back the Mic gain down until the aaudio is cleaner.
Jul 19, 2011 | Midland 1001Z 40-Channels Base CB Radio
Modulation on 1001Lwx midland cb low need to know which pot to adjust
hello,
Regards, Tony
Apr 13, 2011 | Midland 1001Z 40-Channels Base CB Radio
When driving over rough ground my midland alan 48 plus multi cb will sometmes change channel on its own i wondered if this could be a mike problem as you can change channel from the mike
May 18, 2010 | Midland Radio Communications
Poor TX RX range
Since your concern is both on receive and transmit, the common denominator would be the antenna system. The antenna should have a metal mounting to serve as the ground plane. Said mounting/ground plane must be electrically grounded to the rest of the truck. The next area to check would be the PL-259 connector. It should be soldered/connected right with no shorting. Next would be the cable which should be low loss RG-58. Last to check would be the SWR of the antenna. Most mobile antennas could be fine tuned to a specific frequency/channel by adjusting its length. There would possibly be 1 or 2 Allen screws for this purpose. In some cases, it may be necessary to trim off a few mm of the rod.
On your concern re modulation, am afraid that your radio has built-in limiter so as to prevent over modulation and comply with European restrictions. Additionally, the Midland 48 Plus has been programmed to transmit only 1 watt in AM (4 in FM) when the display shows D or D2. Additionally, you might want to consider a power microphone.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 31, 2008 | Midland Radio Communications
Radio Communications Logo
123 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
