Question about Uniden 2.4Ghz Cordless Phone
I want to permanently disable the beep that indicates that there is a message on the machine
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
What model?
Posted on Nov 20, 2013
Disable answering machine
You can turn the answering machine on/off by pressing the [ANSWER ON] button as described on page 34 of this manual. This will only turn it off until it's turned back on again. To disable it permanently you'll have to epoxy the button in place or cut the wires going to the button or some other surgery.
Mar 29, 2013 | Panasonic KX-TG9344T 1.9 GHz Quad 1-Line...
How to turn off alarm on GE radio Model 7-4853c
The manual says to "DISABLE THE ALARM PERMANENTLY" you should:
"Press and hold WAKE 1 or WAKE 2 until the green indicator disappears."
I did this and the light indicator to the right of the clock digital readout went out after a few seconds. I won't know until tomorrow if the alarm is permanently disabled.
Jan 17, 2012 | GE Audio Players & Recorders
My washer is showing dE message what is this mean?
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
Jun 17, 2011 | LG WM2455 Front Load Washer
I have an Acer Aspire Z series desktop PC. By default it gives off a beep when booting. How can I disable the beep? The OS is Win 7 and the BIOS is AMT. Thanks in advance.
Is it giving you any problems? If not, then I don't think you can. But if there is any way to disable it, it would be in the bios. However, I wouldn't disable it if I were you. That beep likely indicates the status of that computer. One beep probably means "all systems go" or something like that. When you encounter certain problems, such as RAM problems, It will beep a certain number of times. You can determine the problem from those beeps. Just sayin.
Apr 01, 2011 | Acer Aspire™ T180 PC Desktop
'02 Rendevous beeping randomly, no lights or trouble indicatiors on. Beeps when parked, beeps while driving, no rhyme or reason apparant. sometimes goes 10 or 15 minutes without beeping, other times beeps...
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the left front speaker. The radio receives audible warning requests via the class 2 serial data line from the IPC or body control module (BCM). If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime--200 pulses per minute
Medium rate chime--150 pulses per minute
Slow rate chime--50 pulses per minute
Single chime
Is the sound heard different from typical Audible Warnings ?
Fasten Safety Belt Warning
The radio activates the fasten safety belt audible warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, slow rate and duration (5 pulses). The fasten safety belt warning sounds and the fasten safety belt indicator illuminates when the following occurs:
• The ignition switch transitions to ON.
• The inflatable restraint sensing and diagnostic module (SDM) detects that the driver's seat belt is not buckled, signal is low. The IPC receives a class 2 message from the SDM indicating the driver's seat belt status.
If the seat belt is buckled when the ignition is turned on, the chime does not sound. If the seat belt is buckled while the chime is sounding, the chime stops. If the seat belt is unbuckled after the initial transition to ON, the chime does not sound.
Headlamps On Warning
The radio activates the headlamps on warning as requested by the body control module (BCM). The BCM sends a class 2 message to the radio indicating the chime frequency, fast rate and duration, continuous. The headlamps on warning sounds when the following occurs:
• The ignition is OFF.
• The BCM determines that the driver's door is open, signal is low.
• The BCM determines that the headlamp switch is in the park or head position.
Key-In-Ignition Warning
The radio activates the key-in-ignition audible warning as requested by the BCM. The BCM sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The key-in-ignition warning sounds when the following occurs:
• The ignition switch is OFF.
• The body control module (BCM) determines that the driver's door is open, signal is low.
• The BCM determines that the key-in-ignition switch is closed, signal is low.
Turn Signal Reminder
The radio activates the turn signal warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The turn signal warning sounds when the following occurs:
• The ignition switch is in the RUN position.
• The turn signal switch is in either turn position, sensing, within 1 second, an open to B+ transition in the turn signal control circuit, left or right turn.
• The vehicle has traveled a distance of 1.2 km (¾ mi) by counting pulses on the vehicle speed input circuit.
The IPC turns OFF the turn signal reminder when either the ignition switch is turned to the OFF position, or the turn signal switch returns to the OFF position, sensing, within 1 second, no transitions from open to B+ in either of the turn signal control circuits, left turn or right turn.
Additional Chimes
The following chimes will turn ON when an associated indicator/message turns ON in the IPC/DIC:
• ABS indicator
• AWD Disable indicator
• Battery/Charge indicator
• Brake indicator
• Change Engine Oil indicator
• Door Ajar indicator
• Hot Coolant Temp indicator
• Low Brake Fluid indicator
• Low Fuel indicator
• Low Oil Level indicator
• Low Oil Pressure indicator
• Low Tire Pressure indicator/reset
• Low Washer Fluid indicator
• MIL (Service Engine Soon) indicator
• Oil Life Reset
• Park Lamp Out indicator
• Rear Hatch Ajar indicator
• Service Traction System indicator
• Service Vehicle Soon indicator
• TRAC OFF indicator
For a description of an indicator refer to Indicator/Warning Message Description and Operation .
For diagnosis of an indicator refer to Symptoms - Instrument Panel, Gages and Console .
Did the Mechanic check for DTC'S - diagnostic trouble codes in the BCM or insturment cluster ? Did you try a Buick dealer ?
Jul 09, 2017 | 2002 Buick Rendezvous
Our phone says that we have a "message waiting" but we cannot access it. It says in our directions that we would have needed to set up a message system with another company which is something...
Your phone service provider is sending a signal on your phone line that is activating the message waiting on your phone. Likewise the beep-beep-beep you hear is called stutter dail tone which is sent by your phone service provider to indicate that you have a message in voicemail for phones that do not have message waiting or message waiting light ability. To cancel the message indicators, you'll need to call your phone service provider customer support and have them disable voicemail. Nowadays, voicemail service is often automatically added by service providers, especailly if you have recently changed service providers or your service provider has upgraded their switch equipment.
Mar 15, 2011 | Vtech T2326 Cordless Phone
My hard dive beeps when i make a mistake even though I have disabled all of the sounds in the control panel. Mostly happens on Outlook.
The sound is coming from the speaker that is attached to the motherboard.
Sometimes you can disable the speaker by following these steps:
  1. In Control Panel, System, Hardward
  2. In Device Manager click View and click "Show hidden devices"
  3. This should make "Non-Plug and Play Drivers" visible in Device Manager.
  4. Expand Non-Plug and Play Drivers by clicking the plus and double-click Beep.
  5. Within the "Beep properties" window click the Driver tab.
  6. Under the driver tab if you wish to temporarily disable this device click the Stop button. If you wish to permanently disable this device under the Startup Type select Disable.
Please let me know if this solves your problem or if you would like any additional assistance. Thank you.
Sep 18, 2009 | Acer Computers & Internet
SW Bell FA-980 Answering Machine
Here is a link to a similar model: http://www.swbfreedomphone.com/ib/ibansw/fa970.pdf Here is what it says: TONE REMOTE OPERATION Remote Security Code To access answering functions from an outside line, you will need to enter the three digit security code located on the bottom of your unit. Write this number on the Remote Access Card, which you can keep in your wallet. Remote Turn On If you forget to turn on your unit: 1. Call your unit from a touch-tone phone. 2. Wait 12-14 rings until the machine answers. 3. The FA970 will automatically answer by playing your greeting. You may hang up the phone, and subsequent calls will be answered. Remote Message Playback 1. Call your unit from a touch-tone telephone. 2. After your FA970 answers, it plays the outgoing greeting and beeps once. Dial your three digit security code within 20 seconds after the beep, pressing and holding each digit for 1-2 seconds. Allow a 2 seconds interval between each digit. 3. Your FA970 will sound one beep to indicate the code was entered correctly. (If there are no beeps, enter your code again.) 4. You can press the following buttons on your keypad: Option Press Playback Mailbox 1 Messages (1) Playback Mailbox 2 Messages (2) Record Memo Message (3) Record New Greeting (8) Turn Off Answer Mode (9) If you press ?1? or ?2? (to playback messages), you have the follow options: Option Press Erase Current Message (0) Repeat Current Message (4) Repeat Previous Message (4) repeatedly Stop Message Playback (5) Skip to Next Message (6) To SAVE messages, hang up the telephone. Note: Your FA970 will sound a series of beeps if there are no messages. Remote Record New Greeting If you press 8 (to record new greeting): 1. When you hear a beep, begin recording your new greeting (up to 30 seconds). 2. When you have finished recording your new greeting, press (5). The unit will beep, and the new greeting will playback to you. 3. Hang up the telephone. Remote Record Memo If you press 3 (to record memo message): 1. Within three seconds of pressing ?3?, press ?1? or ?2? to select Mailbox 1 or Mailbox 2. Otherwise, the memo will be recorded in Mailbox 1. 2. When you hear a beep, begin recording your memo (up to 60 seconds). 3. When you have finished recording your memo message, press (5). 4. The corresponding Mailbox message count will be increased by one. To Retrieve Messages when Recording Memory is Full 1. When the message capacity is full, the unit will sound 3 beeps after answering the phone. 2. Within 20 seconds after the 3 beeps, dial your 3 digit security code. 3. Your FA970 will sound one beep to indicate the code was entered correctly.
Mar 22, 2007 | Southwestern Bell FA970SN Digital...
Uniden 2.4Ghz Cordless Phone Logo
22 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
