Question about Broan-NuTone Kitchen Ranges
How do I turn off the indicator "beeps" that occur when I turn on the range hood or change the setting?
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Frigidaire gas range error message....F1
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
#$%Tf
Posted on Oct 01, 2010
Range hood beeping at random intervals
Turn home braker on and off.
if that don't work you have a program board problem
we need more info model # we can get more info for you
Dec 05, 2013 | Dryers
Brian range hood model CJD130SS fan light on display flashes with fan off or on.
I believe that's the "change or clean filter" indication. Clean the aluminum filters in the dishwasher, replace the charcoal filters if non-ducted, press the fan light over 3 seconds and it should reset.
Sep 02, 2013 | Broan-NuTone Broan Elite E661...
'02 Rendevous beeping randomly, no lights or trouble indicatiors on. Beeps when parked, beeps while driving, no rhyme or reason apparant. sometimes goes 10 or 15 minutes without beeping, other times beeps...
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the left front speaker. The radio receives audible warning requests via the class 2 serial data line from the IPC or body control module (BCM). If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime--200 pulses per minute
Medium rate chime--150 pulses per minute
Slow rate chime--50 pulses per minute
Single chime
Is the sound heard different from typical Audible Warnings ?
Fasten Safety Belt Warning
The radio activates the fasten safety belt audible warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, slow rate and duration (5 pulses). The fasten safety belt warning sounds and the fasten safety belt indicator illuminates when the following occurs:
• The ignition switch transitions to ON.
• The inflatable restraint sensing and diagnostic module (SDM) detects that the driver's seat belt is not buckled, signal is low. The IPC receives a class 2 message from the SDM indicating the driver's seat belt status.
If the seat belt is buckled when the ignition is turned on, the chime does not sound. If the seat belt is buckled while the chime is sounding, the chime stops. If the seat belt is unbuckled after the initial transition to ON, the chime does not sound.
Headlamps On Warning
The radio activates the headlamps on warning as requested by the body control module (BCM). The BCM sends a class 2 message to the radio indicating the chime frequency, fast rate and duration, continuous. The headlamps on warning sounds when the following occurs:
• The ignition is OFF.
• The BCM determines that the driver's door is open, signal is low.
• The BCM determines that the headlamp switch is in the park or head position.
Key-In-Ignition Warning
The radio activates the key-in-ignition audible warning as requested by the BCM. The BCM sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The key-in-ignition warning sounds when the following occurs:
• The ignition switch is OFF.
• The body control module (BCM) determines that the driver's door is open, signal is low.
• The BCM determines that the key-in-ignition switch is closed, signal is low.
Turn Signal Reminder
The radio activates the turn signal warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The turn signal warning sounds when the following occurs:
• The ignition switch is in the RUN position.
• The turn signal switch is in either turn position, sensing, within 1 second, an open to B+ transition in the turn signal control circuit, left or right turn.
• The vehicle has traveled a distance of 1.2 km (¾ mi) by counting pulses on the vehicle speed input circuit.
The IPC turns OFF the turn signal reminder when either the ignition switch is turned to the OFF position, or the turn signal switch returns to the OFF position, sensing, within 1 second, no transitions from open to B+ in either of the turn signal control circuits, left turn or right turn.
Additional Chimes
The following chimes will turn ON when an associated indicator/message turns ON in the IPC/DIC:
• ABS indicator
• AWD Disable indicator
• Battery/Charge indicator
• Brake indicator
• Change Engine Oil indicator
• Door Ajar indicator
• Hot Coolant Temp indicator
• Low Brake Fluid indicator
• Low Fuel indicator
• Low Oil Level indicator
• Low Oil Pressure indicator
• Low Tire Pressure indicator/reset
• Low Washer Fluid indicator
• MIL (Service Engine Soon) indicator
• Oil Life Reset
• Park Lamp Out indicator
• Rear Hatch Ajar indicator
• Service Traction System indicator
• Service Vehicle Soon indicator
• TRAC OFF indicator
For a description of an indicator refer to Indicator/Warning Message Description and Operation .
For diagnosis of an indicator refer to Symptoms - Instrument Panel, Gages and Console .
Did the Mechanic check for DTC'S - diagnostic trouble codes in the BCM or insturment cluster ? Did you try a Buick dealer ?
Jul 09, 2017 | 2002 Buick Rendezvous
There is a constant beebing in my ear every 3/4 seconds and sometimes my customer can here this too How can i stop this???
Usually, that's an indication that the battery is dying. You need to recharge it. If the headpiece is not holding a charge anymore, you need to replace the battery. Model of battery is CPP-512Q. If the unit is fairly new, you can try reseting the battery by taking off the cap on the headset and then unplug the battery and plug it back in. Good luck.
Mar 03, 2011 | Plantronics CS60 Professional Headset
Oven will be off f1 comes up and beeping have to turn it off at breaker to use turn breaker on and have to turn oven on low setting to use range if oven is not on then f1 and beeping oven does not get as...
Hi
Thanks for using FixYa. F1 error indicates that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 25, 2010 | Ovens
Beep when changing channels
press menu, settings, key beep - can be toggled on or off
Feb 07, 2010 | Grundig GUFSAT02SD
Probe indicator beeping. Can't turn off.
there is a continuous beep on my oven and it says enter the probe temperature. I never used and would like to cancel...how?
Oct 09, 2009 | KitchenAid KGST307 Gas Kitchen Range
Press the ?filter? button to turn off the indicator light !!!
Try pressing and hold the filter button for about 15 seconds. See if this works for you. If I can help further, I am here......Eric Campion
Feb 26, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Light and blower speeds malfunctioning
Hi mutt750,
I'm Harvey the Master Plumber.
I agree. It sounds like your neighbor is doing well. I would replace the control board too. Sounds like a nice guy. Time to invite him over for a bbq?
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 07, 2008 | KitchenAid KWVU205YBA Kitchen Hood
Oven control panel
Lok at your manual tp view all the possible control options. However, the solution could be; The touchpads, in conjunction with the dial, are used to select an oven mode,
set the oven temperature, set the time(s) and to set up your range. To use the
touchpad, press the center part of the pad with the flat part of your fingertip. A
beep will sound to indicate that the selection has been made. Turn the dial to the
desired setting and press START.
Pull the plug or flip the circuit breaker, wait five seconds and plug in the range or flip the circuit breaker to on. Always set the clock after installation or after a power failure. Once power returns to the oven, the clock defaults to 12:00 am.
Clock time display can be turned off. The default display is on.
1. Access SELECT FUNCTIONS Menu.
2. Turn knob clockwise until CLOCK DISPLAY is displayed.
3. Press START.
4. Turn knob to select ON or OFF
5. Press START to accept new selection.
Reset the Factory Settings This feature is used to change all the “Select Functions” settings back to the original factory settings (or defaults).
2. Turn knob clockwise until RESET DEFAULTS is displayed.
3. Press START. Display reads SELECT FUNCTIONS.
Dec 03, 2007 | Bosch HES 24 / 6HES 242 / HES 247 Electric...
Kitchen Ranges Logo
57 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
