Question about Nintendo Wii Console
Need help on wii console
I hooked up my wii to my Sanyo CS-90283-1T and Im not getting color. I went out and bought a new cord for my wii that has the blue, green, yellow, 2 reds and white puts and put them in and still not working. When I which my screen over to the wii that's on component on my screen it's in black and white. How do I get color? Please someone help.
  • 61 Answers
Check your wii configuration to make sure it is set to North America
  • 1 Go to your Wii Channel Menu and select the feature for which you want to change your regional settings. For example, if you want to change the setting for the Forecast Channel, use your Wii remote to select the Forecast Channel. If you need to change the region for the Everybody Votes Channel, click that channel.
  • 2 Go to "Settings" and press "A" to select it.
  • 3 Go to the "Nearest Location" tab and select "Change."
  • 4 Scroll to the bottom of the location list. Select "Choose from other regions."
  • 5 Choose the region nearest you after scrolling through the various regions listed. Select it with your Wii remote and press the "A" button.
  • 6 Select the location nearest you from the list by pressing the "A" button.
  • 7 Click "Yes" when prompted. If you wan to change the settings, click "No" and make the necessary adjustments.
  • Read more: http://www.ehow.com/how_5986398_change-wii-region.html#ixzz2ly09ncmM
    Posted on Nov 28, 2013
    meeknotweak
    • 341 Answers
    SOURCE: tv only has white and yellow inputs. tring to hook
    Just plug the green Wii connector into the yellow TV input, and the white Wii connector in white TV input.
    Hope this helps!
    Posted on Sep 19, 2009
    SOURCE: Nintendo Wii works fine on standard tv but not on hdtv.
    FOUND THE PROBLEM !!!!! The problem appears to be the Freeview somehow interfering with the Wii signal. When the aeriel lead is removed the Wii works fine, and the audio/visual signal is great. When the aeriel lead is in I have the problems. I hope this solution proves to be of use to anyone else having similar problems.
    Posted on Dec 30, 2009
    SOURCE: I have a Television with red, white and yellow
    Red= Video- Put the red to the red
    Green= AV3- Put the yellow to the green
    Blue= Sound- Put the blue to the white
    Posted on Dec 31, 2009
    • 20 Answers
    SOURCE: I can't hook my wii up to my Samsung HDTV. There
    Fiend your solution direct from nintendo. Here is your solution....
    http://www.nintendo.com/wiiconsole/prob676ijt65/solution
    ssss6
    Posted on Jan 19, 2010
    • 50 Answers
    SOURCE: i have hooked my wii up to a new samsung 42"
    Make sure that you have switched the Wii to component video in the system setting menus. Once you have done that, you should have a color picture in 480p! Hope this helps!
    Posted on Feb 28, 2011
    Testimonial: "thanks man i was goin crazy tryin to figure it out you guys rock "
    Hook up to the Wii
    Alright so first of all, you should have gotten a cord with a big, grey power brick attached to it. Plug the end in that goes in a outlet, and the other end should hook up to one of the outlets on your Wii console. Then, there should be a cord with three branches. They should be colored red, orange/yellow, and white. On the back/front or on the cable box for your TV there should be plug-ins that are colored either red, white, green, blue, or orange/yellow. The specifications should be written under the outlets (visual, audio, etc...). Plug the white and red part of the cord in to the "audio" outlet (on your tv). The other cord (yellow/orange) should plug in to the outlet that is labeled "video" or "visual" or "screen" or something along the lines of that. The next step is pretty simple. Your Wii (should have) came with a sensor bar. It is thin, long, and black and has a very long, very thin cord attached to it. Plug one side of the cord into your Wii console, and the actual sensor bar goes on top of your TV. There are small, sticky rectangles that help with the sensor bar sticking to your TV. After you've done all that, your Wii is ready to go! Just push the power button and your ready to start playing!
    Nov 28, 2013 | Nintendo Wii Console
    I got a wii and tried to hook it up to my toshiba tv and when i turned on my wii it was black and white and im positive i have it set up correct or if its just the cords itself the colors are blue green...
    Make sure the plugs EXACTLY match the jacks on the TV. If you plug just the green cord into the TVs yellow jack, you will get black and white. If your tv has a combo jack (uses the green of a component input, make sure that the tv is on the right input (COMPONENT and not VIDEO).
    let me know.
    Jul 04, 2011 | Nintendo Wii Console
    I have hooked my wii up to a new samsung 42"
    Feb 27, 2011 | Nintendo Wii Console
    I have had my wii for a while and it is black and we hooked it up to our flat screen Vizio and it is only in black and white but then when i hook it up to my older tv it is in color and i cant figure out...
    Did you use the Component cables for the new tv? If you did, you need to go into the System Menu of the Wii, and change the output to Component 480p, and that should give you a color picture with a higher resolution. Hope this helps!
    Feb 23, 2011 | Nintendo Wii Console
    How to connect a wii to my tv
    Please take your AV Cord and hook it up to your wii and your tv. There are 3 colors. Red/White/Yellow
    Once hooked up, take your remote and switch the Video Input on your tv. (look for the input button)
    Make sure the Wii is powered on and you should see it pop up on the screen.
    Dec 31, 2009 | Nintendo Wii Console
    TV went to black and white when hooking up the wii
    You probably don't have something hooked up right or connected all the way. If you are using component video cables, make sure that all of the different plugs are plugged into the matching socket on your TV. Also, make sure you have your TV on the right channel (3 or 4) if that's how you have it setup.
    Otherwise, you will want to look at the input settings on your TV and make sure you are receiving the correct input, and if you have your Wii plugged into a VCR instead of directly to your TV, try hooking it up directly to see if it works.
    If that doesn't work, try using a different TV - especially if it's a TV you know works in color with a Wii. If it is still in black and white, you might need to take it back to the store and exchange it for a new one.
    Nov 23, 2009 | Nintendo Wii Console
    Wii display black/ white only
    I had this problem too. It was just because I had the wrong cord that goes from the Wii to the t.v. I had a green, blue, and red for the video. And a red and white for the audio, while my T.V. only took yellow for the video. I just went out and bought the right cord that instead of having green, blue, 2 reds, and a white, just had a yellow, red, and white.
    Hope this helps.
    Aug 23, 2009 | Nintendo Wii Console
    Wii component cable - how to connect it?
    on your tv, there should be color coded ports that tell you which cords go where but im almost 100% sure that the red and white cords are for sound and the blue and green cables are for hd video hookups.
    Oct 14, 2008 | Nintendo Wii Console
    Hooking up wii
    you can do it multiple ways. like putting the cords into the dvd then putting the dvd cords into the tv, or put it into the tv, or hook it up to satilitte and hooking up to the tv. your choice.
    Dec 26, 2007 | Nintendo Wii Console
    Nintendo Wii Console Logo
    53 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
