Question about Gateway M285-E Notebook
The time on the clock keeps losings time
I keep resetting but it loses minutes as the day goes on
3 Suggested Answers
  • 3 Answers
SOURCE: I keep losing time. everyday
It shoulds like the timer in your PC has gone bad, that happens sometimes and you have to get it replaced.
Posted on Oct 13, 2008
  • 12 Answers
SOURCE: My belking keeps losing connection during games?
If your wireless you probably need to change broadcast channels on the router ( to the last channel) if its hard wired, you probably need to port forward the ip address for the Xbox
Posted on Nov 24, 2009
Tip
REGULATION TIPS FOR THE 400-day and 1000-day clocks
CLOCK REGULATION TIPS FOR THE ROTATING REGULATOR
These Regulations tips are useful for regulating the rotating regulator. This is to include most 400-day and 1000-day clocks.
The following information is copied from SCHATZ (tm) OWNER'S HANDBOOK.
Time Regulation Tip:
On the top of the pendulum is a disk on which numbers are engraved 1 - 16 and two arrows marked F - S. The small indicator hand will be pointing to a number on the disk at which the clock was regulated before leaving the factory. Should you find it necessary to regulate the clock, observe the number to which the indicator hand points. The distance between each number is equivalent to 1/2 minute in 24 hours + or -.
FRROM MY PERSONAL SHOP NOTES:
If your clock loses two minutes per day [24 hours] and the indicator hand points to number 8 on the disk - move the disk in the direction of the arrow marked F until the indicator hand will point to number 1.
NOTE:
Before attempting adjustments to the regulator disk, first lock the pendulums by using the lever located on the front of the base. By so doing, you will avoid damage to the delicate suspension wire while turning the regulating disk.
Keep A Regulation Record:
Keeping a short Record of regulation and maintenance on your clock will make it much easier for you to keep it well with in its optimum time-keeping ability. We have found that using the guideline below helps.
Date: +/- in min: How much adjust in Degrees +/-: Personal Notes:
We recommend logging only the times the clock was wound, and any time the clock is regulated or reset.
Times of regulation will include any time the clock has exceeded a 3 to 5 minute error.
Use only ONE form of time references for this, a QUARTZ clock that is known for keeping good time is recommended.
Over time you may find the clock needs only slight regulation; for example, if it has run for approximately 3 weeks and the error rate is under 3 minutes adjust regulator only slightly or simply RE-set.
TEMPERATURE and SEASONAL CHANGES
Temperature fluctuation can affect the time-keeping abilities of your clock.
Never allow direct sun light to come in contact with your clock. This will over heat the clock and it will not only affect the time-keeping qualities, but also dry out the oil and cause premature servicing requirements.
SPECIAL NOTES: REGULATION TENDENCIES
It is very difficult to look at the hands of an analog clock and still determine if the clock is running correctly, therefore I recommend allowing the time error rate on the clock to remain UN-touched until the error rate has exceeded + or - 3 to 5 minutes. This is because 1 minute is very difficult to observe and calculate effectively.
One little known fact about the Rotating Regulator: After the clock is restarted it can take up to 3 or 4 hours for the pendulum to settle down into regular beat rate. Example: If the pendulum is under rotated the clock will run fast and will take some time to bring it up to speed. If over rotated it will run slow. RECOMMENDATIONS ARE: Look at the actual clock time and reset it as closely as possible to real time after the clock has run for about 3 to 4 hours but don't disturb the pendulum. ONLY RESET THE CLOCK IF the actual clock time is off by 1 or 3 minutes.
If you must reset the clock every 3 to 4 weeks, and it is FOR EXAMPLE always slow, Slightly RE-Regulate the clock to compensate for this rate of error. Simply reset the clock several times just to make sure that no mistakes are made.
How to Calculate the Adjustment:
Calculating how much to turn the regulating nut on the rotating pendulum by using the following calculations.
Link to data base located at http://antiqueclock.clockstop.com/Regulate.html
Hope this tip helps.
r/David
on Feb 17, 2010 | Watches
How to fix the clock of 2015 Mazda3 which loses time
check your fuses, your losing full time power to the clock
Oct 22, 2015 | 2015 Mazda 3
Why is my toshiba Satellite P-850 clock loosing time
It *might* be
- that the "CMOS battery" (normally a coin cell about 13mm in diameter) is dead, in which case you should replace it.
- The crystal which stabilizes the RTC has drifted.
- If this problem has always occurred it may be the that the RTC chip is defective, but this is highly unlikely, and even less likely to have developed a fault with time.
- if you connect to the internet frequently (several times per day) the above can be ruled out (I think).
See for example (just one of thousands) http://www.makeuseof.com/tag/3-reasons-windows-computer-loses-time-date/
Search the internet on terms similar to "real time clock in pc loses time" for more ideas
28.July.2014
Jul 28, 2014 | Toshiba Satellite Computers & Internet
Losses Time
what frequency does Jordon use on their power is it 50 hz are the clocks 60 Hz designed power usage.
may need a device to convert 50hz to 60hz
search google for
50 hz to 60hz frequency converter
Apr 15, 2014 | Sanyo R-6800 2-IN-1 ALARM CLOCK AND RADIO...
Uniden clock not keeping time, needs to be set
This model phone will not keep time. You can reset it, re-register it or WHATEVER. Next time the phone rings, it loses track of time again and has to be re-set.
Piece of junk
Mar 18, 2010 | Uniden DECT 6.0 Cordless Phone ID
Clock Losing Its Memory
Our oven clock does the same thing every time the power blips, but we live way out in the boonies and expect occasional problems. Do your lights blink too? Check with your neighbors to see if they have power problems. If this is a chronic situation, contact your power company to see if they can repair the situation.
Sep 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Car clock won't keep accurate time. I keep
OK now you sized it down the ignition on it lights the numbers but the unit needs the power from the battery and that has to be seperate and direct wirh some type of fused protection. Just like if you had the battery out or dead everything resets to its origin.
Always had to reboot a computer in the old days... Now a days it is our cars Tommy Tech the Wreck
Jul 29, 2009 | Electronics - Others
Gateway M285-E Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
