Question about GE Refrigerators
My refidgerator door needs adjusting
When the door is closed, it does not seal all the wy and you cn see light coming through the top of the door
    Champion:
    Habit-Forming:
  • 275 Answers
Adjust by loosening the screws on the top hinge & lifting the door accordingly, tighten when in place. Have a look at the bottom hinge point too, make sure it's not worn or broken.
Posted on Nov 22, 2013
  • 1462 Answers
SOURCE: Door not closing properly.
take door off and pack bottom hinge with washers. make sure hingebrackets on cabinet are tight. however, door hanging a bit should not really affect sealing. if seal is gapping, one solution is to warm with a hairdryer and pull outwards gently
Posted on Mar 31, 2007
  • 116 Answers
SOURCE: side by side door
Depending upon your model it could either be a sagging door hinge (requires replacement) or the fridge my not be level. If you remove the toe-kick panel there will be a couple of bolts which are used for leveling ( they should be indicated as such or shown in your owners manual). Alternately there may be screw type legs which are used to level your fridge.
The seal should improve once the doors are properly aligned.
Posted on Jul 28, 2008
SOURCE: Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Posted on Jan 23, 2009
tborn6
  • 700 Answers
SOURCE: Kitchen Aid Superba - door needs adjustment
there is two bolts oin the very front of the unit behind the kickplate the oiu can turn clock wise until there is a slight tile toward the back of the unit so that the cams on the doors will have a little bit of gravity to helop them stay shut.
Posted on Mar 26, 2009
buddymcl777
  • 67 Answers
SOURCE: freezer door not sealing
replace the seals and / or have the hinge adjusted
Posted on May 01, 2009
596.77277790 freezer ice buildup in front top corner
If your refrigerator is fairly new, the seals probably are OK. More likely, the door alignment has to be adjusted.
Jan 01, 2014 | Kenmore 22.4 cu. ft. Bottom Freezer...
Door won't lock
If your dishwasher door won't lock, it could be a problem with the latch adjustment or the door seal. Some latches are designed to be adjustable, and yours may be set too tightly. Look at the owner's manual for specific instructions or follow these basic steps for adjusting the latch:
1. Spray WD-40 or other lubricant onto the latch.
2. Slowly open and close the door several times, noticing whether the door hits the strike plate (the metal plate on the top of the dishwasher frame). Use a hammer to lightly tap the strike plate to move it as needed.
3. If possible, adjust the depth of your latch by unscrewing the latch assembly using a screwdriver and reseating it. Work with the adjustment until it latches correctly.
Note: If your latch is permanently fixed, have a qualified professional address the problem.
The door seal-also called a gasket-can also cause problems if you have a brand new dishwasher or door seal. The good news is that the door seal will mold to the door's shape over the first week or so. Operating your dishwasher with the highest level of heat will help this process happen more quickly. Because the material is pliable, and because heat will soften it, it will seal to the door more securely after those first few loads.
On the flip side, an old door seal can also keep your door from closing correctly. Check the seal for signs of warping or damage. If the seal needs replacing, arrange for service, or consider doing it yourself. In most models, it's a relatively easy DIY project. See Dishwasher gasket replacement for step-by-step instructions.
For more troubleshooting steps, see Dishwasher door repair. I hope this helps!
Oct 08, 2012 | Jenn-Air 24 in. JDB1100AWS Built-in...
Is your service free of charge? if yes what cause smowy ice around the freezer door in a refidgerator
This is caused by excess room air getting into the freezer because of leaky door gasket which should seal snugly on a dollar bill inserted between the gasket. Frequent or prolonged door opening will also allow room air in. The higher moisture content in the air freezes on the surfaces of the food etc.
Mar 12, 2011 | Refrigerators
The refrigerator door does not close properly to make a seal. i have to lift the door up by the handle and close it to get it to seal and turn off the inside light. the door has dropped significantly. i...
There should be a hinge plate on the top outside of fridge and at the bottom. Loosen these then close the door and make sure it is seated properly. with door closed tighten top hinge mount the open door if needed to tighten inside mount. May need to be done a couple of times to get correct fit
Jan 10, 2011 | Hotpoint Refrigerators
Refrigerator isnt cooling, freezer is working fine. Vacuumed out underneath, turned cooling system off, unplugged for some time and plugged back in and reset temps. I can hear the fan running, and have...
light switch could be stuck on, to check that open the door somewhere on the side or bottom, there will be a little button, push it in & hold it, to see if the light goes out, if it does not go out, push it a couple of times more to help it to come unstuck, if the light will not go off the switch has to be replaced
the thermostat could be set to low, adjust to a higher number
check the door seal,; open the door 1/3 way,,& let go of the door,,see if it closes on it's own,, it should be a little hard to open after it's been shut,, also stick a dollar underneath the door seal & close the door,, then pull the dollar bill out & there should be a little drag,,if it pulls out to easy then the door needs adjusting,, or the door seal is bad...
to see if the seal is bad,,open the door,, & look at the seal,., it should not be flat or squashed in places, it should be firm all the way around,,
to adjust the door,, look on top of the frig,,there will be a door hindge on top,, some have a plastic cover & some don't,, if your has one remove it,, there should be 2 screws,,loosen both screws BUT DON'T TAKE SCREWS ALL THE WAY OUT,, grab the door & move it till it's even with the side & top,,,
then tighten the screws back,, then recheck with the dollar bill,,,
there are 10 other problems that would require a service tech to check & fix
hope this is helpful
Aug 04, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Door to refrigerator will not close properly.
The refrigerator door seal is being broken when you open the freezer door? Sounds like the rubber magnetic strip needs to be replaced on the refrig. door, they wear out after a number of years.
Oct 28, 2017 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Jan 23, 2009 | Amana ABB1927DE Bottom Freezer...
Re Neff B1451 oven door not sealing against oven body at top
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Dec 30, 2008 | Neff B1451 Single circotherm plus Electric...
Refidgerator
Check for possible products keeping door from fully closing, Check level of refrigerator and possibly raise the front adjusters found at bottom front near each corner.
May 02, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
