Question about Mitsubishi UD8350U DLP Proj WuXGA 6500 Lumens 1920x1200 35.3lbs Dual T
BLUE GHOSTING IMAGE - Mitsubishi UD8350U DLP Proj WuXGA 6500 Lumens 1920x1200 35.3lbs Dual T
    Champion:
  • Mitsubishi Expert
  • 225 Answers
If you have a blue shadow then most likely it is a bad monitor cable. ???
Posted on Nov 26, 2013
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Ghosting or a 3D image. A yellow and blue ghosting or shadowing image. Looks much like the top picture in the "picture ghosting image" entry. Is this a convergence problem?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 09, 2011 | Toshiba 50HX70 50" Rear Projection...
RCA 52'' Projection HDTV Blue ''ghosting''
Go to menu ,now go to setup see if convergence is on menu if not then fuse FL231 is opened 0.6 amps it is located on right side of flyback transfomer the fuse in the middle they look like small square capacitors brown there is 3 in a roll.
Dec 11, 2008 | Televison & Video
Blue Ghosting Help Needed
Good Day, jhazelwd;
From what you say it sounds like the Convergence IC's have failed. Part number 267P150010, STK392-570, replace both IC's. They are on the middle board secured to a large heat sink.
Good Luck, big IRISH.
Aug 24, 2008 | Mitsubishi WS-65809 65" Rear Projection...
GHOSTING
go to image revison in menu and try. auto, 0, 1, 2, or 3 for best picture
Jul 05, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Blue stain on the image projected by my PLV-Z3
I had the exact same problem with my z3, Turnes out it was the blue filter.
I used the full service manual, and managed to fix mine using the diagrams, and troubleshooting section.
You can get the full service manual here.
http://yama.co.za/forum/index.php?topic=147.0
Apr 05, 2008 | Sanyo PLV-Z3 Multimedia Projector
Blue shadow or ghosting on screen
  1. First try Magic Focus
  2. if this will not fix problem
  3. then you have a convergence problem
  4. You will need the Converg. Kit
  5. X480295 part number
Nov 12, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Ghosting
Get firmware upgraded.
Oct 30, 2007 | NEC VT465 Multimedia Projector
Mitsubishi UD8350U DLP Proj WuXGA 6500 Lumens 1920x1200 35.3lbs Dual T Logo
69 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
