Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Power won't come on
I plug it in and there is no power
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
Where do I find the part number on the power board for my LG 47LH40
You have to contact the authorized service centre for LG, to get an original replacement.
Jun 28, 2013 | LG Televison & Video
Wii power light is flashing red
Wii red light going batty flashing like every 1/3rd of a second, and it will not turn on. I FIXED MINE BY UNPLUGGING EVERYTHNIG CARDS, CABLES, FROM EVERYWHERE, AND REMOVE SDCARDS ALSO, AND DISCS, BOTH GC & WII CARDS, SENSOR BAR PLUG, POWER Plug *ALL THAT'S PLUGGED OR INSERTED... Now i plugged everything back in ACCEPT Not Sensor PLUG To back of wii, then the light quit (This is after 4 min break all undone...) And then plugged the Sensor plug and THEN as i finally plugged in the POWER Plug I first held the SYNC red button on the Wii, and then plugged it in and WAH-LAH Isue Resolved Immediately, KUDOS for the hints Cheerz & Peace Love Banish Fear/ hate to not even give it thought in root thoughtfulness.!. www.fb.com/stanleydeanparker/
Dec 29, 2012 | Nintendo Wii Console
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
see this causes and fix it. God bless you
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Sep 28, 2012 | Washing Machines
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
My PC power supply crashed, burnt resistors, Powerman IW-P250A3-1 20 pin plug to motherboard, bought new power source, but the old power source had a white cable to the 20 pin plug which was -5vdc 0.3amp....
For your system to boot up properly, you need an identical power supply for your system. Most likely the reason why your system won't boot up right now is because you purchased a different power supply and it is lacking something(which is the other pin).
Regards
Sep 14, 2011 | Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Truck wont crank. we have put new distributor cap, rotor button, coil pack, plugs, wires, and fuel pump. we also checked our firing order.
you said you repl dist cap that means you don't have a crank sensor you have electronic ing module. remove your elec ing module have it tested most auto parts stores could test your module, or check your coil at the neg terminal. should have power. if not you lost your primary volt from your batt.your secondary power is coming from your electronic ing module from the module to the pos terminal on the coil, when the eng cranks,from the coil to the dist cap , from the dist cap center to the rotor then out to the plugs,this all happen pervided the timing belt or timing chain is ok. the cumbustion chainber needs 3 things , thats fuel, air, and spark.
Apr 17, 2011 | 1996 Chevrolet K1500
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
22 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
