Question about Dell 1210S Projector
Dell 1210s projector fan is not working - Dell 1210S Projector
DELL .how do i rotate the sreen 180 degrees
Anonymous,
You should be able to press CNTR+ALT+Down Arrow or Up Arrow on the keyboard to rotate the screens image. You may also go into the projectors main menu to adjust. At the link below is the online manual for the 1210s projector.
http://dell.to/1zEbfMW
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 03, 2015 | Dell 1210S Projector
There are white dots on the screen of my dell 1210s Projector
Dell projectors are known for using extremely cheap display chips... Most probably the pixels are stuck you will have to send it to dell for service
Oct 28, 2014 | Dell 1210S Projector
Dell 1210s turn on and sudenly switch off
clean the sensor under the spectrum reel motor....!!!
Dec 17, 2013 | Dell 1210S Projector
Projector is not on red light is blinking
check the lamp first
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Dec 16, 2013 | Dell 1210S Projector
White pixels or dots on the screen i have a dell 4210x projector
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.I supply the DMD chip and the price is USD200
have a nice day!
Nov 22, 2013 | Dell 1210S Projector
My projector lamp goes off minutes after its been turnrd on and indicates a red light on top of the projector. any idea how to solve this problem?
I would suggest that it has a temperature or the lamp/ballast unit has a problem.
If the cooling fan is blocked then the optical block temperature sensor will shut it down. Make certain the filters are clean and all of the fans are running.
How old is the lamp? If it is quite old, more than 1000 hours, change the lamp, if it is newish then suspect the ballast unit.
The lamp will show black spots around the spark gap, a bit like a bad weld on two pieces of metal.
Hope this helps.
Nov 23, 2010 | Dell 1210S DLP projector 2500 ANSI...
Dell 1210S Projector Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
