Question about Toys
Walkera devo 7 how to get it to factory reset
When throttling my infrax qr the blades are going the wrong way
3 Suggested Answers
SOURCE: replace tail rudder blade on walkera cb 180d
yea cut it off longways down the shaft with large parrot nose plyers finish with little ones back up shaft and drive on rotor with small deep well socket simple!,
Posted on Apr 20, 2010
SOURCE: walkera qr w100s After 4 or 5 flights is lost wifi signal. What may be the problem.
Same problem :( I too can't fined information!
Posted on Apr 04, 2014
Where is the Qr code on my phone
Re you looking for a QR code reader for you phone?
Are you using android or apple?
google play on android had "google goggles" or if your using apple you can simply search for a "QR Code reader"
May 11, 2016 | Cell Phones
Tip
Swann wireless cameras will not connect to the cloud after the recent update.
Uninstall the Swann app from your mobile device.
Use a pc or laptop and log into your network connections and navigate to wireless password settings and change the password for the network that your problem camera connects to. This will keep your camera from auto connecting. You will add them back later.
Restart your router. When the network is back online log in again , and confirm that cameras are no longer connected. You do not have to power the camera off.
NOTE: (You will have to repeat the following steps for each camera. Do not use the same qr code on more than one camera)
Open a browser window and navigate to the Swann cloud website. (https://www.swann-cloud.com) and log into your account.
Navigate to the camera tab and check to see if your cameras are in the camera list. Delete all non working cameras from the list and log out. (As a precaution, you should download any events that you want saved to prevent them from being removed. Or only remove one camera at a time when you are deleting cameras).
Reboot your pc or laptop and log back into the website and navigate back to the camera tab and select
Select the option you prefer. (Usually wifi unless your camera is plugged directly into your router wired option is useless)
Enter your wifi logon and password
You should now see the qr code with two options. Select for the old qr code. It should automatically show the highlighted and display a qr code.
Using your cell phone, open the camera and take a clear picture of the qr code, make sure that the picture of the qr code fills the screen so it isn't too small.
Locate the picture in your photo gallery (I recommend that you crop the picture so that only the qr code is visible)
NOTE: Do not log out of the Swann cloud website or close the qr code window from here, it must remain open. Leave the qr code on the screen.
on Mar 23, 2017 | SWANN Home Security
Can't get a qr code on new phone for Motorola migrate.
A QR code reader? What model do you have? Please note: an auto focus camera is required for QR Code readers to work.
May 09, 2014 | Cell Phones
Qr code
QR Code - They are a type of matrix barcode, your can scan them with a smartphone which normally links to a webpage
Dec 25, 2013 | Computers & Internet
2002 chevy trail blazer ,throttle valve qr flap does not open
You people must explain things,,,what is the "qr" flap"?
Oct 25, 2013 | Chevrolet Cars & Trucks
My cadillac deville has a code PO85 on it what does it mean
You just need to clean the throttle body. Take the air duct off and hold the throttle blades wide open (engine off). Spray the throttle bores beneath the blades with carb cleaner and scrub with an old tooth brush. clean the back side of the throttle plate also. The junk and gunk is plugging up the air flow past the blade at closed throttle and the idle speed control is running out of authority to open the blade. It just needs a thorough cleaning. Disconnect the negative battery terminal for 30 seconds when you are done to reset the idle learn offsets.
While you are in there and have the blades of the throttle body wide open....see those two tubes sticking up at you from the floor of the manifold?? Those are the EGR delivery tubes and they are NOT supposed to be full of carbon.... Rod them out with a piece of stiff coat hanger wire and carb spray to get them cleaned out.
Mar 12, 2012 | 1995 Cadillac DeVille
The accelerator pedal is not working properly. Especially when trying to go up hill. I have to keep pushing & letting go, pushing & letting go. even when it starts to move. Also, the right blade...
I am guessing that this was posted in wrong category.
You mention that you have to keep pushing / letting go of the accelerator. Is the engine RPM changing, or is the tractor surging, when you do this? What happens if you keep a steady pressure on the pedal? Isn't the throttle control via a lever on the panel?
Your uneven blade height can be caused by a multitude of issues.
1) If the spindles were changed, the wrong spindle may have been used on one side or the other.
2) The wrong blade adapter has been used on one of the spindles.
3) Mower deck has been bent
4) Mower deck is binding. Try raising it all the way up, and lowering all the way down. See if the uneven cut changes at both levels (all up or all down).
5) Blade is bent on one side, though this would usually cause such a ruckus and vibration it would be quite noticeable.
6) Belt is slipping. Yes, sounds strange, but if blade speed changes significantly, then the position where the grass is actually cut changes because the grass can "lean over" more.
7) Using a mulching attachment in tall grass can cause 1 blade to clog, and the cut grass that is swirling bends over other grass that needs to be cut.
8) Mower deck support bracket has been bent
9) Mower deck wheel has a bad bearing, and doesn't support the deck at same height as other side.
10) Mower deck is cracked / bent at a support location
11) You have lost a retaining pin at a support bracket and the bracket is loose.
12) A spindle's bearings are worn out, and the spindle is "jumping" as it turns.
If the blades are directly beside each other where they blades will overlap, it is normal for a small amount of height difference to occur. But, most decks have off set blades, one slightly in front of the other.
you should be able to raise the deck all the way, and pull the tractor's front wheels up onto something (landscape timber?) to get more access, then measure blade height in relation to bottom of the deck. If different, then you are looking at wrong blade / adapter or a spindle issue. If the blades are the same height, then you are likely looking at a deck support issue / binding in linkage.
Aug 25, 2010 | Craftsman Garden
Can you convert Mavic Crossride 9mm QR to larger
You want to convert to a 15mm through axle? You won't be able to unless you change out the whole hub to the larger one. If you had a through axle and wanted to go down to a 9mm, some manufacturers have reducers for that. double check - call a local bicycle repair shop in your area.
Mar 29, 2010 | Cycling
Sticky throttle on 200 Chevy Astro
There was a recall on the throttle body blade on the 4.3 a few years back for the throttle body to stick in the close position. Yours being 9 years old makes me think that there not going to do anything for it but give you the solution to the sticky throttle blade.
The solution was to change the blade. You can try cleaning the throttle body blade by spraying throttle body cleaner in to the barrel of the throttle body. If you look down, you'll see the carbon build up and it may just need and good cleaning.
If that does not work, you can buy a new Throttle body blade which is only held on by two screws on the throttle blade shaft.
Start with cleaning the blade and throttle body with throttle body cleaner. Just follow the instruction and you'll be fine.
Keep me posted and good luck.
May 31, 2009 | 2000 Chevrolet Astro
Toys Logo
93 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
