Question about OKI MICROLINE 8810 Matrix Printer
How to adjust the top of form okidata microline 8810
freetek
  • 5568 Answers
SOURCE: no power what so ever
If memory serves, there is an internal fuse.
If I am wrong, then the power supply needs attention.
Here is a service manual link:
http://www.eserviceinfo.com/downloadsm/14445/Oki_ML%20320%20&%20321%20Turbo.html
Posted on Jul 14, 2008
coolcat_12
  • 259 Answers
SOURCE: How to Connect an Okidata Microline 321 to a new computer
If you have the software I would install it and see if it works if it does not Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} you may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Posted on Jan 26, 2009
SOURCE: microline 391 okidata continous feed leaves a page of space
We have downloaded the manual and will see if we can figure it out.
Thanks
Posted on Apr 07, 2009
  • 8 Answers
SOURCE: how do you replace an okidata microline 521 printhead?
turn the printer off
remove the ribbon
on the right side of the head you will see a silver lever/tab lift up on that it is hinged on the left side
lift head straight out
reinstall in reverse order
Posted on May 08, 2009
JackHeath
  • 1049 Answers
SOURCE: Okidata Microline 320 Turbo Printer - forms don't maintain registration
On older printers, tractor feed edges separate from the page while printing. Sometimes this can be a fluke, but other times it may point to a mechanical problem. Try taking the paper out of the printer and hitting the form feed button a few times. Watch the printer’s tractor feeds to make sure they are moving and are in synch with each other. Some printers use belts to move the tractor feeds and, over time, these belts wear, break, become smooth and slip, or become misaligned.
Environment can also contribute. Paper stored in a warehouse can weaken in intense heat or moisture. Carbon copy paper will especially cause this type of problem as one sheet's feeder edge can break away from the rest and peel slightly back. This will in turn slow the feed on one side as the edge buckles slightly under and may even skip to release pressure causing major alignment problems.
Posted on Mar 22, 2010
My Okidata 320 microline print cartridge is leaking ink. What does this mean?
The Okidata Microline 320 uses a ribbon. If it smears, just back the tension lever off until it goes away. Smearing will happen with multi-part forms unless you back off the printhead.
Jul 25, 2011 | Matrix Okidata Microline 320 Printer
Hello , i have a okidata microline 393c ,its happens that
Could you look in the manual and see what that alarm is for? It has been a while since I have seen a microline printer. Mostly businesses still use that kind of printer.
Id say the ribbon might be out.
Mar 09, 2010 | Office Equipment & Supplies
Microline 391 okidata continous feed leaves a page of space
Thanks
Apr 05, 2009 | OKI MICROLINE 390 Turbo Matrix Printer
Okidata Microline 420
This would be the print head pins not moving forward or the ribbon bunched up at the top.
Sep 23, 2008 | OKI MicroLine 420 Matrix Printer
Okidata Model# GE5253P
An online manual here: http://my.okidata.com/PP-ML320.nsf?opendatabase There is probably a top of form setting which needs to be checked & corrected. I assume you've checked tab/margin settings in your software & printer setup?
Sep 28, 2007 | Matrix Okidata Microline 320 Printer
OKI MICROLINE  8810 Matrix Printer Logo
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
